Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Apr 3, 2013 at 4:55 PM
    #1481
    Bistineau
    Bistineau Well-Known Member
    Bossier Parish La.
    2013 Prerunner SR5
    Para-bolic mirrors on the outside rearveiws.
    That would be stick welding or stick rod welding. A very common method for all types of jobs. Most pipelines are built with this, as one example. Not so much on aluminum though. It can be done but not as good of results as TIG or MIG.
    Stick can be done in conditions that would preclude the other 2 types mentioned, such as windy areas. It does not require any shielding gas that can be blown away. The shielding is provided by the flux coating on the rod. This would be a good choice if you don't have a dedicated shop area to work in, or may need to weld in many different locations. I have an engine drive welder for this that does not need electrical connections to work, just gasoline. It also doubles as an emergency generator during power outages, and provides power for power tools to work in remote areas.
  2. Apr 6, 2013 at 9:21 AM
    #1482
    smtaco73
    smtaco73 Well-Known Member
    South Louisiana
    2008 and 2009 TRD Sport 4x4 DCLB
    TOYOTA FAMILY Three Tacomas and one corolla.
    Looking for a quick response for the following question?
    What is the FLA on the millermatic 211? I don't know what FLA stands for but my electrician just asked me and I can't find it on the manual unless I overlooked it. Thanks
  3. Apr 6, 2013 at 12:28 PM
    #1483
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    It stands for "Fully Loaded Amps" and what he wants to know is what the maximum current the machine draws.
  4. Apr 8, 2013 at 11:19 AM
    #1484
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Do any of you use anti splatter spray for your mig nozzles? I saw online that PAM works as good as anything. Does it work?
  5. Apr 8, 2013 at 11:22 AM
    #1485
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Nope just Mig pliers clean it up after a few beads I don't like the smell of the anti splatter and you tend to get porosity on the first tack after you spray/ dip it.
  6. Apr 8, 2013 at 11:23 AM
    #1486
    JLee
    Jerry
    Grass valley CA
    I'm pretty sure it's 25amps
  7. Apr 8, 2013 at 11:25 AM
    #1487
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I use some antispatter spray, it helps a bit. I typically clean the nozzle good and then spray it, then its about a once a day clean and spray on for me. Between there, knock off spatter with pliers a few times.
    As Jerry said, I notice porosity if I use nozzle dip, so I've gone to spray but just enough to help with spatter a bit, not expecting it to prevent spatter entirely.
  8. Apr 8, 2013 at 7:23 PM
    #1488
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I use nozzle dip. I just tack a scrap piece before I go back to my project. I leave the scrap by the nozzle dip so I don't forget. I also spray my part with anti spatter if I don't feel like chipping.
  9. Apr 10, 2013 at 10:28 AM
    #1489
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I used Uni-strut bolts.
  10. Apr 11, 2013 at 10:52 AM
    #1490
    medic2230
    Murph
    Bama! Roll Tide
    I used the kit that came with a tonneau cover and took the tonneau hooks off leaving an aluminum bar that was threaded and had bolts with it.
  11. Apr 11, 2013 at 11:49 AM
    #1491
    medic2230
    Murph
    Bama! Roll Tide
    :wave: Yeah it has been.
    This is it apart sitting to the left of the track.
    You mean like this? :spy:
  12. Apr 11, 2013 at 11:59 AM
    #1492
    medic2230
    Murph
    Bama! Roll Tide
    Try calling some of the truck places and see if they might sell them. A buddy got me mine so I don't know if they can be bought separate.
  13. Apr 11, 2013 at 12:31 PM
    #1493
    medic2230
    Murph
    Bama! Roll Tide
    You could just buy a piece of aluminum bar stock and drill and tap it. That would probably be cheaper than the kit.
  14. Apr 11, 2013 at 2:38 PM
    #1494
    medic2230
    Murph
    Bama! Roll Tide
    Use a lift mechanism from under a taco.
  15. Apr 11, 2013 at 2:41 PM
    #1495
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    I think I have a flyer from sema on who makes these I'll check when I get home.
  16. Apr 11, 2013 at 2:52 PM
    #1496
    medic2230
    Murph
    Bama! Roll Tide
    Lift on the bottom standard bed tire mount on top.
  17. Apr 11, 2013 at 3:40 PM
    #1497
    medic2230
    Murph
    Bama! Roll Tide
    Yup
  18. Apr 12, 2013 at 12:14 AM
    #1498
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    These here work really well and fit just right.
    http://www.mcmaster.com/#machine-table-t-slot-nuts/=ma9s2u
  19. Apr 12, 2013 at 7:38 AM
    #1499
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    So, this is something similar to what he wants?
  20. Apr 12, 2013 at 7:43 AM
    #1500
    Btnewman
    Benjamin
    Grand Junction co
    As for being able to alternatively mount the tire on top, he could weld a large nut to the top of the tire rack and make sure its welded over a hole, so a bolt can run through it. Then he just has to get a bolt long enough to hold the spare in place, but he will be able to take it out and keep the top of the rack flat for carrying boxes n such. Just a thought...
    Edit: could just hold the tire on top via ratchet straps....
