Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Apr 15, 2020 at 1:18 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Couldn't that introduce a bunch of risk though? Like if it was a lease, would I take on the previous owners bill? Or can they just take the tank from me? Been reading about stuff like taking my tank, I did get a great deal on the welder and tank so it's not like it's a huge loss, but I do like having that big of a tank. I still have my smaller C25 too.
  2. Apr 15, 2020 at 1:23 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Cyberweld.com. Bottle gets dropped off on your doorstep:)
    gpb, GARSHA91[QUOTED] and Drainbung like this.
  3. Apr 15, 2020 at 2:26 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Without being sure of if the tank was leased or not it is hard to say. Even some tanks that have company names on the top can be "owned tanks"....swing the tank by a competitor or other shop that fills/swaps tanks out. I wouldn't worry about it.
  4. Apr 15, 2020 at 2:34 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Had to dig the welder out. Got a job to do at work tomorrow that I won’t be able to get to with the mig welder outside.
    will.i.was, irayfz6 and snowboard704 like this.
  5. Apr 15, 2020 at 2:35 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    I’ve taken other shops bottles to different shops and they swap out the tanks no problem. All they do is take the other shops sticker off and slap one of theirs on it haha
  6. Apr 15, 2020 at 4:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    How do you do exchanges?
  7. Apr 15, 2020 at 4:47 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Just saw I can get a full 80cf bottle for $250 shipped. That’s not bad at all.
    la0d0g[QUOTED] and Drainbung like this.
  8. Apr 15, 2020 at 4:57 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    When was the last time it was used ??
    Really embarrassing if it does not start or if the brushes are stuck.
    Nothing worse then the ignition switch left on for a few weeks.
    six5crèéd[QUOTED] likes this.
  9. Apr 15, 2020 at 4:59 PM
    la0d0g
    That was just the initial purchase and fill :D. Drive down the street to the local weld shop for a fill.
    Drainbung likes this.
  10. Apr 15, 2020 at 5:00 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhhhh that makes more sense.
  11. Apr 15, 2020 at 5:03 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    In this day and age with so many of the old school people retiring who were more based on customer service then making sure the Paper work is perfect and the physical inventory and computer is spot on.
    I see differences in the same companies between different branches all within 25 miles of each other.
    I venture big difference in NJ compared to most other places.
  12. Apr 15, 2020 at 5:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I always wondered about this, but my understanding of the leased tanks is they don't track each individual tank. You just pay to lease a tank, doesn't matter which one. So if you ended up with it, I would assume you'd be fine.
  13. Apr 15, 2020 at 5:12 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I keep a battery tender on it and crank it once a month.
    Wyoming09[QUOTED] and Drainbung like this.
  14. Apr 15, 2020 at 5:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I don't think that's the point.
    Leaving the key on while not running can burn out the coil.
    Been there, got the t shirt.
    six5crèéd likes this.
  15. Apr 15, 2020 at 6:09 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Gotcha. It don’t have a key. It has an ignition switch that starts it and it has to be turned off to cut the engine off. Hopefully it’s never been left on, hasn’t since I bought it new that I know of about 18 years ago.
    koditten[QUOTED] likes this.
  16. Apr 15, 2020 at 6:42 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I am new to TIG welding, so I am regularly f'ing up my electrodes. Decided to cut down on my walk time back and forth to the belt sander. Added this cute little 3" 80 grit HF wheel to my cart.
    I plan to wire it into one of the incoming 120v legs, so I won't need extension cord.
    $23.00 with 20% coupon. And, it's just damn cute.
  17. Apr 15, 2020 at 6:48 PM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Hey everyone,
    I'm planning on building some adjustable UCA's pretty soon and wanted to get some opinions on what wall thickness I should go for. I can't find any info on what major companies like camburg and total chaos use, plus they use chromoly so I will probably want to go a little thicker because I'll be using mild steel.
    I'm thinking 3/16''. Thoughts?
  18. Apr 15, 2020 at 7:16 PM
    koditten
    Kirk
    Central Michigan
    I was thinking 3/16" as well.
    They can't be much more than 12 gauge from the factory.
    austinmtb likes this.
  19. Apr 15, 2020 at 7:20 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    My buddy just did some Arms for his 1970 GMC and used 1.25” DOM 1/4” wall
    austinmtb[QUOTED] likes this.
  20. Apr 15, 2020 at 7:37 PM
    austinmtb
    Austin
    Southern Oregon
    @koditten that was my thought as well, stock is thin and can take a lot of abuse.
    @Shmellmopwho I'll definitely use DOM. 1/4'' seems like it's overkill but it would certainly add peace of mind. Might just go the overkill route.
    Nice username btw :rofl:
    Shmellmopwho[QUOTED] likes this.
