Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jun 16, 2020 at 2:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  2. Jun 16, 2020 at 2:59 PM
    svdude
    svdude Well-Known Member
    jonathan
    koditten likes this.
  3. Jun 16, 2020 at 3:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I regularly rip off mirrors on trees so the amount of fucks for me to give is pretty low luckily
    koditten, svdude[QUOTED] and Littles like this.
  4. Jun 16, 2020 at 3:09 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    According to a chart online, 1.75x.120 is 2.09 lbs per foot, making a 20’ stick weigh 41.8 lbs. split in half, 20 lbs resting on the mirror. Not too bad
    Tacman19 and svdude like this.
  5. Jun 16, 2020 at 3:28 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Every inch you move the bracket forward reduces that amount as well.
    I like it.
    I end up taking my aluminum fishing boat to haul 20' lengths of iron.
    Drainbung and EatSleepTacos like this.
  6. Jun 16, 2020 at 3:28 PM
    svdude
    jonathan
    For a trail rig, yea... who cares. But a 40k truck that’s a street queen, that’s a lotta nope for me.
    True, 20 lbs may not be much but hit a bump or two then you have more than 20 lbs of force hitting the mirror. Then factor in the density differences between the two objects and the mirror will be a weak link and take the abuse.
    I do think it’s a better option than a full overhead rack and way better that having 15 feet of tube hanging out of the rear.
    Drainbung likes this.
  7. Jun 16, 2020 at 3:33 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah very true. Move the back bracket forward and the tube back so it’s barely on the mirror. Would be almost no weight.
  8. Jun 16, 2020 at 4:02 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    @EarSleepTacos Make some brackets to carry the tubes on the underside of your truck. seriously!
  9. Jun 16, 2020 at 4:04 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You know I saw that when I was researching options for transporting tube! Pretty ingenious.
  10. Jun 16, 2020 at 4:51 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Haha! I did pretty much the exact same thing on my F150, side mirror and everything. That mirror was scratched to shit when I traded it in.
    :bananadead:
  11. Jun 16, 2020 at 4:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Haha! Didn’t protect it with a towel or anything?
    GHOST SHIP[QUOTED] and Drainbung like this.
  12. Jun 16, 2020 at 8:03 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Not 20 footers but I recently acquired this rack that has a soft top that goes over it. Already loving it for hauling metal.
  13. Jun 16, 2020 at 8:12 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Got some links?
    I’ve been needing to find a new solution
  14. Jun 17, 2020 at 4:36 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not really. I just did a google search and poked around a couple of car forums talking about roll cages. Look at the google images too. There really aren’t too many options to transport it.
    YamaDirtrider[QUOTED] likes this.
  15. Jun 17, 2020 at 4:46 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s cool. I’d considered building something like that vs buying another softopper but went the easy/light route and just got a used softopper.
  16. Jun 17, 2020 at 4:47 AM
    soggyBottom
    soggyBottom Well-Known Member
    I have a welder I bought in Australia a few years ago. The plug is the standard household plug they have there with a 3 wire hot-hot-ground. The
    plug for my oven and dryer are both hot-hot-neutral. I know that the neutral and ground wires are bonded at the breaker so it would likely work but I don't really understand the why.
    Would it be a safety hazard to switch out the plug?
    Can anyone explain how a ground wire is different if it's just bonded to the neutral wire at the main breaker?
    Also the welder does support 60Hz
  17. Jun 17, 2020 at 5:02 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    the difference between a ground and a neutral is that a neutral carries current and a ground doesn’t. The proper term is ‘grounded conductor’ for a neutral and ‘grounding conductor’ for the ground. Neutrals and grounds in a residential setting were landed under the same buss once upon a time, but new installations need a separate ground / neutral buss in all except the main service.
    TL;DR
    Neutral carries current and ground doesn’t. You don’t want current traveling through a bare wire.
  18. Jun 17, 2020 at 5:40 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Sorry for the rookie question, but I don't burn through that much MIG gas. I just swapped out a tank with Airgas and asked for MIG mix or C25. I'm not so sure I got a tank with C25 and instead only got CO2. Is this common? I feel like I paid for something I did not receive. There is nothing on any of the stickers to denote the presence of Argon. Not really gonna lose too much sleep over it, just want to know better for next time, in addition it would help setting the welder if I knew the exact gas for shielding.
  19. Jun 17, 2020 at 7:33 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I’d go back and get the 72/25 mix if that’s what you wanted before using a lot of the straight co2 gas
    zippsub9[QUOTED] likes this.
  20. Jun 17, 2020 at 7:52 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I intend to do that, but wasn't sure if there were C25 cylinders that weren't marked with Argon at all or only listed the Non-Flammable warnings for CO2 and nothing mentioned of C25? I guess I want to be sure that my cylinder isn't C25 and I am mistaking it for pure CO2.
    snowboard704[QUOTED] likes this.
