Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 9, 2020 at 8:24 AM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    I can't remember if I ask this or brought it up..
    Has anybody had any experience with Fronius Magic Waves?
  2. Dec 9, 2020 at 8:35 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    FYI:
    $15 - https://www.homedepot.com/p/Square-...door-Main-Lug-Load-Center-QO2L30SCP/100157760
    $17 - https://www.homedepot.com/p/Square-...er-with-Cover-No-Door-HOM612L100FCP/100149777
  3. Dec 9, 2020 at 9:04 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I am just a hobby welder, so not a lot of hours on my machines, but I have had one of these for about 1.5 years and am still happy with it. No issues to date. I also have their Cut-60 plasma cutter and same result, no issues.
    I have actually used the arc welding more than TIG, and it is really smooth and consistent. I had only used my Dad's Lincoln tombstone before and always sucked at it. This thing is much easier for me to use.
    In addition to all the control features, I liked the 3yr warranty with postage paid both directions, and the 24/7 US based customer support. I've called it twice on Sunday, just to see if they answer. They did.
    This guy does a pretty thorough review, and in the end, says he would definitely recommend the machine. Foot pedal I believe is his only small beef with it.
    https://www.youtube.com/watch?v=-YkWY3nVAlY
    Again, just a hobby welder, so take my opinion for what it's worth.
    Guerrilla[QUOTED] likes this.
  4. Dec 9, 2020 at 9:19 AM
    svdude
    svdude Well-Known Member
    jonathan
  5. Dec 9, 2020 at 10:08 AM
    gpb
    Atlanta
    I was kinda figuring you'd use the same supply wire whether or not you put a sub panel & breaker where you tapped off for 120V.
  6. Dec 9, 2020 at 10:15 AM
    svdude
    jonathan
    If it was just a single 220 outlet I can get away with 12/3 romex. But if I put in a sub panel I’d rather do it where I can run multiple circuits and get full benefit from it. But the sub panel does sound really good. I’d love to have a few outlets on every wall plus 220, and a dedicated outlet for some of the larger tools. Who knows, maybe I’ll just do that one day.
  7. Dec 9, 2020 at 10:15 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Your wire needs to match the breaker.
    Please consult an electrician.
    Welders fall under a different section of the NFPC, so much confusion is injected to these conversations involving welder plug wiring.
    tcBob, svdude and gpb like this.
  8. Dec 9, 2020 at 11:23 AM
    gpb
    Atlanta
    That was pretty neat to watch, thanks for sharing.
    As a newbie it was interesting noting some of the techniques. Tacking the corners and ensuring equal diagonals before then welding. Using cut pieces as jigs for the drawer slide spacing.
    Also looked like he did multiple tacks and alternated welding spots - guessing to even out heat related expansion and thus helping keep things square?
    ... and is that a tap in the drill/driver to thread the wheel bolt holes at ~3:18? o_O
  9. Dec 9, 2020 at 11:43 AM
    svdude
    jonathan
    12/3 would match the breaker I would use for just a welder. 30 amp breaker with 100 ft of wiring. Am I missing something?
  10. Dec 9, 2020 at 12:01 PM
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    12 gauge is for 20 amp circuits; for a 30 amp circuit you should use 10 gauge wire. If you're just wiring the welder and it's 220 volt, you just need 10/2 wire (2 hots and a ground, the ground isn't included in the wire count). If you're going to also include a 110 receptacle off of it, then you'd need 10/3 wire (2 hots and 1 neutral), but as was mentioned earlier, you want to be careful about putting devices with smaller loads on larger capacity circuits as the circuit breaker potentially won't trip in time if something off the 110 receptacle overloads.
    The way I remember which gauge wire to use is to start at 14 gauge for 15 amp and increase one wire size for the next size breaker:
    15 amp = 14 gauge
    20 amp = 12 gauge
    30 amp = 10 gauge
    40 amp = 8 gauge
    50/60 amp = 6 gauge
    Scott B., tcBob, deeezy and 4 others like this.
  11. Dec 9, 2020 at 12:05 PM
    koditten
    Kirk
    Central Michigan
    Thank you. This needs to be stickied. @tcBob
    This conversation comes up often and being able to refer to this post would be valuable.
    svdude, gpb and Drainbung like this.
  12. Dec 9, 2020 at 12:30 PM
    gpb
    Atlanta
    ... and if the wire run is "complicated", there's something to be said for maybe running one 10/2 for the welder plus a separate 12/2 for 120V outlets (each from their own breaker) instead of wrestling 6/3 through existing construction... :D
    Mojo Jojo[QUOTED] likes this.
  13. Dec 9, 2020 at 12:32 PM
    svdude
    jonathan
    I think there’s a little more involved for longer lengths of wire. If over 50 feet you step up in size right? I haven’t looked at it in a while and anything I said above (minus the 6/3 for the sub panel) was off of memory... apparently I was wrong. Haha.
  14. Dec 9, 2020 at 12:33 PM
    koditten
    Kirk
    Central Michigan
    My hands hurt just thinking about snaking 6/3. No thanks!
    gpb[QUOTED] likes this.
  15. Dec 9, 2020 at 12:46 PM
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Not sure, you'd need to consult the code or an electrician on what distance you'd need to step up.
  16. Dec 9, 2020 at 1:27 PM
    Pyrotech
    Pyrotech Well-Known Member
    Try 3 runs of 500mcm through cable trays... it was only 50 foot runs but it was inside a hot substation control house...
    jubei likes this.
  17. Dec 9, 2020 at 1:29 PM
    koditten
    Kirk
    Central Michigan
    No "likes"!
    Pyrotech[QUOTED] likes this.
  18. Dec 9, 2020 at 2:04 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I just redid my whole garage. Ran 2 6/3 to nema6-50 outlets on each side of my garage, through bored joist holes, ran 12/2 down each wall on seperate breakers, new light circuit for indoor lights, new circuit for outdoor lights, garage door sensors and button wiring in walls/roof. Not too bad of a job except for climbing over all my shit and moving it a dozen times..
    gpb, svdude and Drainbung like this.
  19. Dec 9, 2020 at 2:42 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    Thanks for your input, I watched the whole video... Seems like a pretty legit machine, especially if he gave it a pass.. And especially for that price.
    I guess the only pain if you had a problem would be, not having local support as in taking to the shop where you bought it.. And having to send it in if it had a real bad problem.
    Wsidr1[QUOTED] likes this.
  20. Dec 9, 2020 at 2:47 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    So I went back up to the welding supply shop today, to take the box and rest of the parts to the 205, and when I got there the EASB rep and manager were in the back with the two machines I had turned in and one of his fresh out the box demos (that he wanted to make sure worked before looking like an idiot in front of people).. Now they were welding great., so something is really off because yesterday, both of them tried and weren't able to get it to work..
    They were perplexed as well as myself... I guess the machines have artificial intelligence and like to play with people... CCP warfare at it's finest. Go figure. So weird.
    Drainbung likes this.
