Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 16, 2020 at 2:54 PM
    WillTheThri11
    WillTheThri11 Well-Known Member
    Will
    2006 Tacoma Access Cab TRD 4x4
    Bilstein 5100s
    If you think you'll ever do aluminum, you might want to look at AHP and Primeweld Tig machines. I don't weld a lot but I do enjoy it and like having the skills and equipment. I have a Lincoln wire feeder (120V) and recently got a Primeweld AC/DC Tig/Stick that has pulse and square wave frequency adjustments when I needed to weld some thin aluminum. Never tried stick welding and don't really think I'll have a need to but you never know I guess.
  2. Dec 16, 2020 at 2:55 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I should have given a link. I was more talking specs and not brands. I'm really just trying to figure out how much I don't know about welder capabilities
    Running Board Man likes this.
  3. Dec 16, 2020 at 2:56 PM
    AODRN
    STL
    I could definitely see doing aluminum but I have heard that it is more difficult so I don't know how realistic it is to say I want to do that any time soon
  4. Dec 16, 2020 at 3:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Get a 240v machine (or dual voltage I should say). I learned on a 120v and it’s a huge step up in efficiency going to a 240v.
    I had the harbor freight titanium mig 140 and I really liked it. Jumped up to a harbor freight Vulcan migmax 215. It was a great upgrade and I really like the welder. I really like being able to tell the welder what thickness I’m welding and it does all the settings for me.
  5. Dec 16, 2020 at 4:42 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Excited to get my 220 machine, and top it off with gas!
    deeezy, koditten, gpb and 2 others like this.
  6. Dec 16, 2020 at 5:32 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Agreed. I looked at the 140 and decided it’d be worth the bit extra to go to the dual voltage Titanium 170. Figured I could buy once and have something I’d have room for growth, and I wouldn’t have to be in a rush putting 240V into the garage.
    Yes I look at the panel under the door for suggested feed and voltage, but I kinda find myself tweaking them a bit anyway so that’s not been a handicap.
    @AODRN Also plan to get a tank of gas. Makes a significant difference. Flux core is fine when needed but make sure you buy something that can use shielding gas.
  7. Dec 16, 2020 at 6:12 PM
    AODRN
    STL
    I guess that is the smart move. I definitely want to get gas. I keep starting at the low end of the spectrum and talking myself up over $1000 by the end. I guess I've blown money on worse things though.
  8. Dec 16, 2020 at 6:42 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I would also recommend a 240v machine. I have had the smaller Miller 211, running on 240v, and have had instances where it just felt like it was sort of struggling when it was turned way up and welding thicker material. I have a larger Miller 255 now and it lays a nicer bead on the same thicker material. I think that after you get the hang of it, you will run into that and wish you had bought a more powerful welder.
    AODRN[QUOTED] and EatSleepTacos like this.
  9. Dec 16, 2020 at 7:45 PM
    Running Board Man
    Running Board Man Well-Known Member
    I personally love the stuff... But gun angle becomes a big priority
    gpb likes this.
  10. Dec 16, 2020 at 10:26 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Nice display.
    Zim
  11. Dec 16, 2020 at 10:36 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I’m a big fan of dual voltage as well. I think it’s worth the extra money for the options it gives you. No problem on 120v doing thinner stuff but gives you the option to weld thicker material. Also nice to be able to just plug it into a 120v and get started as soon as you get it/be able to move it around as needed. Can then install an outlet or get an extension cord to 220v when you need it.
    I welded my whole wedge camper on 120v b/c it’s just 16ga and it was plenty of juice plus I had to do it in my backyard because it wouldn’t fit in my small garage but I’ll sure as as hell get setup for 220v before I start my rear bumper.
  12. Dec 17, 2020 at 1:57 AM
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    +1 on the Titanium 170 with shielding gas. That's my setup as well and I'm very happy with it.
    gpb[QUOTED] likes this.
  13. Dec 17, 2020 at 3:40 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    You will have no issues (other than duty cycle) building a rear bumper on a 120v machine.
    Tacman19 and gpb like this.
  14. Dec 17, 2020 at 4:13 AM
    gpb
    Atlanta
    You'll get there easy, no worries. :D The welder is a fraction of the overall spend if you're not already set up for metalworking. Welding table (cheap HF one works well enuf to begin with), clamps of various types, magnets/squares, grinders (multiples easier than swapping discs/cutting wheels/wire wheels all the time), welding cart (buy or make), helmet, ear protection & other PPE, metal saw of some sort, etc.
    It all adds up. Well worth it IMHO, as this is pretty fun as a hobby, nice to be able to build / fix stuff.
    And depending on your family/friends it also becomes a bit like being the only one with the pickup - you may find you have new "friends" when you're the one that can weld. :cookiemonster:
  15. Dec 17, 2020 at 6:25 AM
    Pyrotech
    Pyrotech Well-Known Member
    have a coworker who after seeing the bender stand I made, has decided he wants me to build a rack for his utility trailer.
    koditten and gpb[QUOTED] like this.
  16. Dec 17, 2020 at 10:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I ordered a baby cold cut saw today and I couldn't be more excited. I have no way of making 90 degree cuts and currently just eyeball it with an angle grinder. It never works out. I finally had enough last night when I cut out some legs for a bed cage/rack I'm making. Crooked as shit, so enter baby saw. This is the little brother to the evo cold cut saw that everyone loves, except it's less than half the price and will be easier to store away since space is a premium in my garage. It can fit up to 2" round tube which is 99.9% of what I cut.
    https://www.lowes.com/pd/Evolution-10-Amp-7-25-in-Chop-Saw/3386576
  17. Dec 17, 2020 at 11:03 AM
    svdude
    svdude Well-Known Member
    jonathan
    Interesting, that would be perfect for my garage too. I’ve been using a ryobi 10” chop saw for about 15 years to cut metal. It’s worked well but it’s starting to show signs of fatigue. That little chop saw looks nice.
    On another note, I just got my first 4-5” angle grinder. I used it to cut some brackets off of my axle so I can raise my track bar and do a high steer setup on my Jeep. I cannot believe I’ve been using a huge 7” grinder this whole time. It’s a little makita that I got on sale, it cut through 1/4” steel brackets like butter! Never again will I not have a smaller angle grinder. Haha.
  18. Dec 17, 2020 at 11:13 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I love this saw! You might want to pick up a couple blades for it if you can find em though.. My original finally chipped a carbide off and wouldn't cut for shit. Went to Lowes to get a new Rage Blade and couldn't find em. Had to get then from some rando seller on ebay or something.
  19. Dec 17, 2020 at 11:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    While you're at it, just buy another one! It's nice having one with a cutting disc, one with a flap disc, one with a wire wheel, etc. It's nice being able to just swap tools while working.
    That's good to know. I wonder if the blue blade would work on it, I don't see why not. I was comparing the two saws and everything seemed the same except for the fact one was for metal and one was for multiple materials (including metal). I'll have to look around.
    Drainbung likes this.
  20. Dec 17, 2020 at 11:38 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Check the RPMs?
