Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 18, 2020 at 9:13 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Plasma Table : Langmuir Crossfire
    Plasma Cutter : Hypertherm Powermax 30 XP
    Air Compressor : 60 Gallon husky with 13CFM/90PSI
    I had not one single bit of knowledge of CAD software when I purchased my table. The Langmuir website has great tutorials for Autodesk Fusion 360 and it made the learning curve much easier for me. I find it relatively easy to do most parts now. But plasma cut parts are pretty basic since they’re all 2D (besides the thickness of the material). You should be fine learning how to do it all. I feel like I picked it up pretty quick. If you have any other questions feel free to ask!
  2. Dec 19, 2020 at 3:21 AM
    Pyrotech
    Pyrotech Well-Known Member
    Seems to a pretty solid machine for the price. But I have not used any other tig machines so nothing to compare to.
  3. Dec 19, 2020 at 8:24 AM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Thanks for the input.
    How long have you had it, any notable issues with it?
    What would I expect to pay for something similar?
  4. Dec 19, 2020 at 10:23 AM
    BoomBam
    BoomBam Well-Known Member
    PNW
    I’ll be in the same boat, never TIG welded before so I’m trying to gather as much information as I can so I can buy one. Definitely a good option though, thanks.
  5. Dec 19, 2020 at 10:45 AM
    svdude
    svdude Well-Known Member
    jonathan
    Anyone else have the feeling of metal work like you hate it and love it at the same time? I’m doing more work on the front axle of my Jeep and it’s a pain grinding in some areas, it’s a mess, and flat annoying. At the same time, it’s accomplishing and I really enjoy it.
    Just my random thought of the day.
    Tacman19 and EatSleepTacos like this.
  6. Dec 19, 2020 at 11:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I feel the same way, depending on the job. Doing stuff on the workbench I love. Stuff on the truck is more lovehate.
    Zebinator and svdude[QUOTED] like this.
  7. Dec 19, 2020 at 12:35 PM
    svdude
    jonathan
    I do really enjoy bench work much more than on vehicle work. I used to do a fair amount of sheet metal work on aircraft, that was probably one of the more enjoyable on vehicle(ish) work that I’ve done.
  8. Dec 19, 2020 at 1:52 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Mother Fucker!
    Again?!
    D2., gpb, Tacman19 and 1 other person like this.
  9. Dec 19, 2020 at 1:55 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ooof
    malburg114 likes this.
  10. Dec 19, 2020 at 1:55 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    So need to notch my frame to recess the bump stop in. The bump stop can is 2 1/4 and I would like to use a hole saw to notch it to make sure it’s even all the way through but i only need like a 1/4 of the frame notched. Any ideas how to do it and keep the hole saw straight without something to run the pilot bit through? If not, I’ll just use the plasma and grind to fit.
    Picture of said bump stop
  11. Dec 19, 2020 at 1:57 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    These bars came out better than I could have imagined. Holds that tent nice and loowwwww
    ABC73EBF-E109-487E-AC48-033293CA336B.jpg 5734DEA2-4CE5-494E-9E62-2468045F53F3.jpg 86D3D1F3-4F74-42B3-82ED-179CCC43ADF3.jpg 911E575D-557E-42DA-A530-2BDFB1C368A8.jpg
    D2., jjsul, Bigdaddy4760 and 9 others like this.
  12. Dec 19, 2020 at 2:02 PM
    koditten
    Kirk
    Central Michigan
    I would tack weld a piece of sheet metal over the gap, then drill into the sheet metal with the pilot drill, then keep on cutting with the hole saw notching out the x member with the hole saw. I hope that makes sense.
    malburg114[QUOTED] likes this.
  13. Dec 19, 2020 at 2:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was thinking the same thing but it would be hard to keep it straight all the way down. Maybe do that on the top and bottom to get the nice curve, then cut straight lines on the face of the frame rail.
  14. Dec 19, 2020 at 2:05 PM
    malburg114
    Las Vegas, NV
    That’s kind of the idea I had. I didn’t think about doing it on the top and bottom and the just cutting the fronts with a cutoff wheel. May try that.
    EatSleepTacos likes this.
  15. Dec 19, 2020 at 2:09 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    I must say, I'm not surprised based off the condition of that box.
  16. Dec 19, 2020 at 2:23 PM
    koditten
    Kirk
    Central Michigan
    I violated my own rules.
    Never buy wire unless it's on a metal or wood spool. This is the second time I got bent over buying wire over the 'net.
    Hopefully they work with me. I don't like doing nasty reviews.
    Guerrilla[QUOTED] likes this.
  17. Dec 19, 2020 at 2:26 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    Guess if you're getting a slammin deal, maybe it's time to weld up a universal spool.
    Pyrotech likes this.
  18. Dec 19, 2020 at 2:33 PM
    koditten
    Kirk
    Central Michigan
    I tried running wire from a broken spool to good spool years ago. It doesn't work. You still get binding when you are welding. It sucks when you are trying to get stuff out the door.
    Thankfully my other welder has a brand new 44 pounder and is working fine. The above was for my spare welder, so I'm not losing money or time. Just Uber annoyed.
    Bigdaddy4760 and Guerrilla like this.
  19. Dec 19, 2020 at 2:36 PM
    svdude
    jonathan
    Worst case, dispute the charge with your cc company. That’s one of the reasons why I use my cc for absolutely everything.
    koditten[QUOTED] likes this.
  20. Dec 19, 2020 at 2:38 PM
    svdude
    jonathan
    If it were me, I’d get a scrap piece of 2 1/4 tube and notch it for the size of the frame. Then use that as a template to mark the frame and cut by hand. This ensures the top and bottom notches are perfectly aligned.
