Anytime Backup camera quit and factory reverse camera quit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SSgtRock, Mar 30, 2024.
  1. Mar 30, 2024 at 7:00 PM
    SSgtRock
    SSgtRock [OP] Member
    Rock
    East TN
    2021 White Tacoma TRD
    I installed the anytime camera from running for tacos website a couple months back and it’s been working just fine but as I was getting out of the truck today, I noticed my switch was going in and out like the power was and then the head unit camera pic started doing the squiggly line stuff an then went black so as I started to research and look at what I had done and I noticed that the ground wire had come loose. Could that have caused both the reverse and the front anytime camera to stop? I have checked all wires and connections and I still have nothing now I’m a rookie at being a mechanic so do I need to check fuses to the radio works fine but I get no feed from the back or the front cam any advice, or answers would be greatly appreciated. Thanks guys
  2. Mar 31, 2024 at 6:04 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I cannot speak to your specific issue, but Electrical Troubleshooting 101 teaches to always start with checking applicable fuses / relays. Also check for loose wires / bad connections (which it sounds like you did). Then if possible, return everything to factory configuration to see if the mods you installed are causing the problem.
    As my Dad taught me, when in doubt start with the easy/ cheap and go from there. Good luck.
    Stevie17 and TacoSR523 like this.
  3. Mar 31, 2024 at 4:50 PM
    SSgtRock
    Rock
    East TN
    Thanks
