Anytime Backup Camera Switch Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gulkana, Apr 27, 2022.
  1. Apr 27, 2022 at 3:30 PM
    Gulkana
    Gulkana [OP] Active Member
    2017 Tacoma Double Cab 4WD SR5
    Hi,
    Vehicle: 2017, Tacoma
    Thanks to some great support from the Anytime Backup Camera folks I now have it installed and it appears to work perfectly, except...
    When I select the Forward position on the switch both the Front and Rear amber switch lights are illuminated. (Head unit displays front camera.)
    When I select the Rear position on the switch only the Rear amber switch light is illuminated. (Head unit displays rear camera.)
    For those that have Anytime Backup Camera with a front camera, does this match up with what happens for you?
    The Anytime folks say this is normal operation. Just wanted to double-check.
    Thanks so much.
    Dam325 likes this.
  2. Apr 27, 2022 at 3:41 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Yup
    Tacospike likes this.
  3. Apr 27, 2022 at 3:42 PM
    caribe makaira
    Caribbean, Puerto Rico
    Post a pic of the rear of the connector so I may see the wires.
  4. Apr 27, 2022 at 3:59 PM
    jayavilak5
    jayavilak5 Well-Known Member
    Jay
    Phoenix, AZ
    2018 TACOMA TRD OFF ROAD 4x4
    Mine does the same thing. I guess as long as it functions not a big issue.
  5. Apr 27, 2022 at 6:08 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    That’s the way mine works.
  6. Apr 27, 2022 at 6:21 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Mine does that too but I never thought it was weird because it does what it's supposed to do, displaying what I chose
  7. Apr 27, 2022 at 10:21 PM
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    It does that because the whole system is designed to supply a signal to the HU when in reverse...except the truck isn't actually in reverse, the ABC harness just powers the line the HU recognizes as "hey, we're in reverse now. Imma display the camera". Combine this with the relay: unpowered, the relay just lets in the reverse camera feed. Powered, it switches to the front camera. No matter which camera you select, a signal is supplied on the orange wire which is what goes to the HU. I guess the PCB for the switch internals just wasn't designed to distinguish between "trick HU into thinking we're in reverse, show me rear camera" and "trick HU into thinking we're in reverse, show me front camera". I think it just routes the front selection through the same entire circuit as the rear, hence why both lights illuminate.
    Kinda annoying, but doesn't affect use.
    Taco_mike73 and roboturner like this.
  8. Oct 16, 2022 at 6:00 PM
    SYTY
    SYTY Member
    My front camera when switched on the front position stays on in park, drive and reverse. Isn’t the reverse cam supposed to come in reverse no mater what position the switch is in?
  9. Oct 16, 2022 at 6:04 PM
    Gulkana
    No, the switch will override.
    Tocamo and Taco_mike73 like this.
  10. Oct 16, 2022 at 6:17 PM
    SYTY
    SYTY Member
    Ok so the front cam does override the reverse cam even when in reverse. I thought i wired up something thing wrong.
    Thanks Gulkana
  11. Oct 16, 2022 at 6:19 PM
    Taco_mike73
    York, PA
    It should go to the rear when the switch is off. But I believe that if the front set that overrides. I have to to experiment with mine
  12. Oct 16, 2022 at 6:29 PM
    SYTY
    SYTY Member
    Yea with the switch in the off position the camera goes on in reverse, & The reverse position stays on all the time in any gear just like front cam switch. I was thinking that the front cam should switch to the reverse camera in reverse.
    My non problem is solved I just need to switch off the front camera when backing up.
  13. Dec 3, 2023 at 1:15 PM
    timee
    timee New Member
    Tim
    2023 Tacoma TRD Off Road
    Anytime Backup camera
    I took apart the switch to see how it worked and was able to come up with a modification to get each LED to work independently. You need to cut a trace on the PCB and solder in a diode.
    Here's my instructions on how to do it: https://timee1994.weebly.com/anytime-camera-switch.html
    End Result:
    Tocamo, FLAK-TAC, dilbert and 4 others like this.
  14. Dec 3, 2023 at 6:12 PM
    RTedder2
    RTedder2 Well-Known Member
    Roger
    Inferno '17 TRD Offroad
    Great work Tim
  15. Dec 5, 2023 at 8:04 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Good job. This always bothered me when both lights were lit. I will be in for one. Simple as easy as wrapping out the switches.
  16. Dec 20, 2023 at 6:08 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    Just installed this switch. Works great. Anybody with a little OCD will want this switch. I know it wasn’t a big thing having both front and rear indicators lit at the same time but yet it bothered me. Now everything is perfect. This switch should replace the switch that comes in the kit.
    helix66 and timee like this.
  17. Dec 20, 2023 at 6:30 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    The way it should have been from the beginning. You can tell they didn’t spend the time to actually make it work the way intended. Anyways.
    I’m having issues with mine. I think it’s the connection at the switch. Sometimes the picture is not clear and or the colors are off.
    Also when I have needed it the most (when off-road) the signal is lost and it displays a black screen. It only seems to do it when I’m off-road for some reason because I have turned it on in the highway and it functions fine. That gets me confused all the time. Or maybe it overheats or something.
  18. Dec 20, 2023 at 9:06 PM
    roboturner
    Colorado
    Did you tape the RCA? I had the same problems until I went back and taped the connections
  19. Dec 21, 2023 at 7:45 PM
    Panchovilla6192002
    Arizona
    At the camera end correct?? I already went and looked at the connection a few months ago but I don’t remember if I taped it. I’ll have to double check. Im wondering in what way the tape helped, I remember the connection being nice and firm.
  20. Dec 23, 2023 at 12:36 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    pretty sure that RCA connectors are for indoor use.
    Maybe the tape helps prevent a moisture issue and stabilizes the connection too?
    I was thinking of using heat shrink but that’d be a pita to undo.
