Anytime backup switch that matches OEM Toyota light blue?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shaggy135, Jan 27, 2022.
  1. Jan 27, 2022 at 1:29 PM
    shaggy135
    shaggy135 [OP] Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Search didn't show up with anything. Does anyone make a dual camera switch that matches the light blue switch color? The switch that came in the kit is a darker blue. Matches the CH4x4/CaliRaised switch color.
  2. Jan 27, 2022 at 1:32 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Crack it open and change the LED to ice blue?
  3. Jan 27, 2022 at 2:38 PM
    jbiscuit
    jbiscuit Well-Known Member
    Jake
    Portland
    2021 LR Pro
    elaudtr likes this.
  4. Jan 27, 2022 at 2:40 PM
    shaggy135
    jbiscuit[QUOTED] likes this.
  5. Jan 27, 2022 at 4:46 PM
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    I'm not sure if all LEDs can be removed and replacements soldered in, but if it's possible you might consider a used OEM Toyota switch from ebay or something, and pop that open and use the proper blue LED from that.
  6. Jan 27, 2022 at 4:57 PM
    mrkabc
    Art
    Corona, CA
    I have actually done this since I wanted "ice blue" switch for my light bar. It's not that hard. Let me find the thread and I can link.
    EDIT: Here's the link.
    https://www.tacomaworld.com/threads/aftermarket-toyota-switches.683291/#post-25112178
    Amazon sells "Treedix" LED assortment for around $10 or so that includes ice blue LEDs. They have SMD, 3mm and 5mm assortments. I wasn't able to source them individually on Amazon though, had to go through Ali Express to get them.
    It's really not that hard if you have basic soldering skills and a bit of patience.
    japjoe7 and jsackspot like this.
  7. Feb 4, 2022 at 10:18 AM
    jsackspot
    jsackspot Well-Known Member
  8. Feb 4, 2022 at 10:21 AM
    shaggy135
  9. Feb 4, 2022 at 10:31 AM
    jsackspot
    Ah, are you saying their blue is not a match?
  10. Feb 4, 2022 at 10:37 AM
    shaggy135
    Correct. There blue is a darker blue. AOB has the light blue that matches OEM.
    jsackspot[QUOTED] likes this.
  11. Feb 4, 2022 at 10:50 AM
    jsackspot
    Alas, they don’t have tall switches.
  12. Feb 4, 2022 at 10:51 AM
    shaggy135
    I reached out to AOB about that. They responded saying they were going to start getting them in January. But I'm guessing they're delayed just like everyone else.
  13. Feb 17, 2022 at 4:19 AM
    ssmann
    ssmann New Member
    Hello all. I emailed them a few days ago and they replied with "we will have them in three more weeks".
    markram likes this.
  14. Feb 18, 2022 at 9:29 PM
    mrkabc
    Art
    Corona, CA
    It's easy to change out the LED to ice blue. No need to wait for "someday."
  15. Feb 18, 2022 at 9:30 PM
    jsackspot
    details? I really couldn't figure out what the end-all be-all solution was with the resistor thread.
  16. Feb 18, 2022 at 9:40 PM
    mrkabc
    Art
    Corona, CA
    You don't need a resistor other than the one that comes with the switch (meaning you can just trade out the LED for an ice blue one). I didn't like how bright the ice blue LED was, so I wanted to tone it down a bit. So I replaced the resistor with a 1/4 watt 51k ohm one. Perfect level of brightness that matches the stock ice blue lighting. Note that I used a 5mm LED which is brighter, when I should have gone with a 3mm instead (they weren't available at the time) TBH I think you'd be fine leaving the stock resistor and just plugging in the ice blue 3mm LED and calling it a day.
    You can get the Treedix 3mm LED package here:
    Treedix 750pcs 3mm LED Light Emitting Diode 15 Colors x 50Pcs LED Lamp Assortment Set Kit White/Warm White/Cold White/Red/Green/Blue/Ice Blue/Yellow/Pink/Purple/Multi Color Fast Flashing: Amazon.com: Industrial & Scientific
    750 LEDs is probably more than you can use in your lifetime but for ten bucks so what. Ice blue is included with the kit, and you'll have extras for next time. As I mentioned in my thread here:
    Aftermarket Toyota switches | Tacoma World
    (Post 10), it's pretty simple to crack open the switch with a small screwdriver to access the circuit board and make the LED change. The LED can be oriented however you want it to make the lighting more focused on the text, or offset to reduce brightness. Your call.
    Good luck!
  17. Feb 19, 2022 at 8:01 AM
    ssmann
    ssmann New Member
    I did change out my leds to 3mm ice blue and changed the resistors to 10k on 1 Cali Raised switch. It worked well. May still be a tad to bright to match the OEM and OCD may get the best of me.
    I changed out the leds on another switch that was from Amazon and it was too bright. Got a bit too anxious I guess with the resistor change and screwed up the solder pad on one side. I'm out 10 bucks. Will try again when the replacement comes in tomorrow. Thanks for the posts showing the details.
  18. Feb 20, 2022 at 4:31 PM
    jsackspot
    Excellent; have soldering iron, will replace!
  19. Jul 15, 2024 at 9:18 AM
    mathew206
    mathew206 Active Member
    2023 SR Access Cab
    Treedix LED replacement worked perfectly! Thanks everyone for your posts! especially @mrkabc
    mrkabc likes this.
