Anytime backup troubleshooting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PRO22, Sep 24, 2022.
  1. Sep 25, 2022 at 5:55 PM
    caribe makaira
    Caribbean, Puerto Rico
    Ok, then the relay is NOT doing the change over. Green wire is not providing power to relay, or relay is AFU or ground is not good (relay)
  2. Sep 25, 2022 at 6:15 PM
    PRO22
    PRO22 [OP] Well-Known Member
    My first assumption is also the relay as I’ve taken the time to carefully solder all connections etc. I’ve tied both grounds together (also soldered) and grounded to head unit. I’m still waiting for anytimecamera support to get back to me, hopefully it’s just a relay swap and not the relay harness as well.
  3. Sep 25, 2022 at 6:20 PM
    caribe makaira
    Do you have a DMM? Verify continuity and relay function. Also the juice from the added harness.
  4. Sep 25, 2022 at 6:23 PM
    PRO22
    I do, can I verify this at the switch side? I may not have access to the relay/harness (at least with a DMM) due to being tucked away.
  5. Sep 25, 2022 at 6:26 PM
    caribe makaira
    Switch, yes.
  6. Sep 25, 2022 at 6:39 PM
    PRO22
    nice. I’ll admit it’s a tad out of my schematic know how, do you know which pins to verify as I try to toggle back and forth?
  7. Sep 25, 2022 at 6:42 PM
    caribe makaira
    First verify there's juice.
    Switch connector pin #4 _DMM (+) to Ground Switch selected to Front camera.
  8. Sep 25, 2022 at 6:47 PM
    PRO22
    the switch camera icon itself illuminates, not sure if this is a telling indicator of power.
  9. Sep 25, 2022 at 6:54 PM
    caribe makaira
    No, switch illumination is not part of actuation.
    Verify switch connector is as my drawing. It might have changed a bit.
  10. Sep 25, 2022 at 6:59 PM
    PRO22
    I think I get it. So pin 4 to GND should read x when toggled to Front, while pin 5 to GND should also read x when toggled to Rear. If rear does not, then this confirms relay inactivity?
    BTW - I appreciate the continued help
  11. Sep 25, 2022 at 7:01 PM
    caribe makaira
    Green (4) is only input to relay for video source change...
  12. Sep 25, 2022 at 8:12 PM
    caribe makaira
  13. Sep 25, 2022 at 8:24 PM
    PRO22
    lol will try tomorrow. Wasn’t home all day but stay tuned and appreciate the help.
  14. Sep 26, 2022 at 8:10 AM
    PRO22
    so I am getting ~15VDC when measuring positive probe to green (pin 4) and negative probe to GND (pin 1) when camera is toggled to front cam. When cam is toggled to rear cam I get 0V.
  15. Sep 26, 2022 at 8:12 AM
    #35
    caribe makaira
    The there's a fail towards relay, relay itself, or relay ground. Must access the relay to verify.
  16. Sep 26, 2022 at 8:15 AM
    #36
    PRO22
    any suggestions what exactly to prob on the relay harness? I can possibly get access, I think.
  17. Sep 26, 2022 at 8:16 AM
    #37
    caribe makaira
    Green wire going into relay to ground, then test relay ground.
  18. Sep 26, 2022 at 8:27 AM
    #38
    caribe makaira
    P.S. You can remove the relay from the base and test the pins, then test the relay away from the base.
  19. Sep 26, 2022 at 8:29 AM
    #39
    PRO22
    ok measured via pins in back of relay harness and confirmed GND is good and green pin to GND is reading ~15VDC in front cam setting and still 0 when toggled to rear.
  20. Sep 26, 2022 at 8:31 AM
    #40
    caribe makaira
    Bad relay, remove it. Test it away from base.
