Anytime Fog Light Mod, please help an engineer out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cludwig, Jul 24, 2020.
  1. Jul 24, 2020 at 10:41 PM
    cludwig
    cludwig [OP] Well-Known Member
    2019 TRD Off Road DCSB MT Barcelona Red (fastest color)
    Alu-Cab Explorer Canopy, 23 Zero 72" RTT, Rhino Rack Batwing Awning, ARB Suspension, 235/85R16 K02 tires, Hondo radio knobs, Taco Garage DMM...
    I have a 2019 DCSB MT TRD OR with the tech package. I'd like to mod my fog lights so they stay on when the high beams come on. I'd prefer that they go off with the headlights. That is all I really need.
    I was doing some other work on my truck tonight (adding an input to my DC-Dc charger for solar) and thought I might as well do that fog light mod while I have the hood open.
    So, I popped off my fuse box lid and found the FOG FR relay and yanked it out. I did the following tests:
    1. I started the truck with the low beams on and put the fog switch to on. The end pin on the relay had 13V, then next pin in had no voltage. Of the other two pins (smaller signal pins), one had 13V and the other zero. Ok that makes sense, the two big copper pins carry the load, the smaller aluminum pins drive the coil. I have signal to the coil and power for the load, with that I will turn the lights on.
    2. Test two, shut off the truck and put a jumper between the positive battery terminal and terminal that didn't have 13V on it and the fog lights come on. Great, that is where I send power to the fogs, the load terminal.
    3. I start the truck and put the high beams on, the fogs go off. I yank the relay and check the terminals. Same two were at 13V, one on the supply, one on the signal. Same as before when the fogs were lit! How is that? if that were the case, the power would be going to the terminal that lights the fogs even when the truck is off? I checked this twice. Maybe three times. I even thought maybe the ground is floating on the other side of the coil, but I had 13V across the two coil terminals.
    Now, just so you know that I know my way around a multi-meter, I'm an engineer. I used to be the guy that aircraft electricians called when they couldn't diagnose a FADEC on a helicopter (the brain of the engine). I was the guy the who famously changed the wiring drawings to a flight control system in the field with a red pen and got it approved for install.
    Any ideas how it appears that this relay has the same power on brights and on dims? Is there another relay between this one and the lights that do the high beam cutout? I can't figure out how to complete the mod without understanding why the relay terminal meter out the same with the fogs on and off.
    Any idea what a good source would be for power to drive the FOGs to only get supply power when the lights are on? Would Towing Tail be a good candidate, that should come on and go off with the headlight.
    Access to my fuse box is a pain, you have to unscrew the one end of the shelf that I have my DC-DC charger and battery tie switch mounted on. You can get to the fuse box, but it isn't as easy as I would like. I'm pointing at the relay in question here:
    Any help is appreciated!!
    -Chris.
  2. Jul 24, 2020 at 11:21 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Here’s the wiring diagram for the fogs.
  3. Jul 25, 2020 at 3:44 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    cludwig[OP] likes this.
  4. Jul 25, 2020 at 8:35 AM
    cludwig
    I was afraid of that. They made the mod a PITA for gen 3. Summary of the mod is to bypass the entire wiring of the car. No thanks.
    Thanks for that link!!
  5. Jul 25, 2020 at 11:08 AM
    caribe makaira
    Caribbean, Puerto Rico
  6. Jul 25, 2020 at 11:12 AM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    You would have to tap in to the hi beam wiring as well as run another wire to the battery to be able to make it work the 3rd gens are programmed to not allow the fogs to run with the hi beams and from my experience that’s the only way to do it to by pass that
  7. Jul 25, 2020 at 11:15 AM
    caribe makaira
    NO need for another wire to the battery...
  8. Jul 25, 2020 at 12:01 PM
    Filip38507
    Filip
    Lynnwood Washington
    If you tap into just the hi beam wire you won’t be able to run it both because the hi beam wiring is limited to 15A which most likely won’t sustain both sets of lights running
  9. Jul 25, 2020 at 2:20 PM
    gmdoctor
    gmdoctor New Member
    2020 tacoma
    I think you can tap into the high beam as a trigger to the fog relay. But I'd use a diode so it doesn't back feed
    Filip38507[QUOTED] likes this.
