Anytime Foglight mod explained electrical (diagrams)
Discussion in 'Lighting' started by Crom, Dec 6, 2009.
  1. Jan 30, 2017 at 6:55 PM
    #221
    TacoSupremeo
    TacoSupremeo Well-Known Member
    Michael
    2005 Tacoma Double Cab 4x4
    I just did this mod, thanks for sharing! Works great!
    jivewalker[QUOTED] likes this.
  2. Feb 3, 2017 at 2:06 AM
    #222
    NorthGeorgiaTaco
    NorthGeorgiaTaco Well-Known Member
    Joshua
    Chatsworth, Ga
    2015 Tacoma SR5 Prerunner MGM
    Is there anyone in north ga that can show me how to do this?lol
  3. Feb 3, 2017 at 3:06 AM
    #223
    TacoSupremeo
    Michael
    I will be traveling from knoxville to macon next week for work...
  4. Feb 3, 2017 at 3:54 AM
    #224
    NorthGeorgiaTaco
    Joshua
    Chatsworth, Ga
    Do you know what day? If I'm off I could meet up with you if you're cool with that.
  5. Feb 3, 2017 at 7:36 PM
    #225
    TacoSupremeo
    Michael
    I will be traveling in on tuesday morning, need to be onsite in macon by 12 noon, i will spend the night somewhere between there and chattanooga then drive home wed. Where are you located?
  6. Feb 4, 2017 at 3:21 AM
    #226
    NorthGeorgiaTaco
    Joshua
    Chatsworth, Ga
    I'm in Dalton/Chatsworth. Exit 336 on 75. Tuesday works good for me.
  7. Feb 4, 2017 at 6:02 AM
    #227
    TacoSupremeo
    Michael
    You can message me with you phone number so i can let you know when i will be coming thru, if you want to.
  8. Jul 23, 2017 at 1:31 PM
    #228
    highriserkaiser
    highriserkaiser Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
    So that I can really have you rack your memory - any idea what size those connectors are? I'm thinking .110, I drove all over town looking for some with no luck. Did this hold up well? Sorry if I'mbeating a horse others have left dead...
  9. Jul 27, 2017 at 6:25 AM
    #229
    TacoSupremeo
    Michael
    i didnt have the thin ones either... but im a redneck, so i took my regular spade connector and thinned it down a bit on the bench grinder.
  10. Nov 12, 2018 at 1:01 PM
    #230
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Thread revival!
    Question, instead of running the wire from the fog relay to a scotch lock or blade terminal to the light green ignition wire, couldn’t you just run the wire from the fog relay to an add-a-circuit on an ignition fuse?
    @Sleipnir any input on that idea?
    Edit: I see a few pages back someone did do an add-a-circuit but just curious on why that’s not the common no-splice way to do it?
  11. May 1, 2019 at 12:34 AM
    #231
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Can someone tell me the guage of the red wire that jumps over the the relay
  12. May 1, 2019 at 11:33 AM
    #232
    caribe makaira
    Caribbean, Puerto Rico
    Use 18awg. it's the coil side your messing with...
    Pibbles99 likes this.
  13. May 1, 2019 at 12:51 PM
    #233
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Thanks
  14. Sep 20, 2019 at 1:17 PM
    #234
    Taco_koma
    Taco_koma Well-Known Member
    Ben
    SE Michigan
    2012 Tacoma SR5
    Just did this in like 10 minutes, worked like a charm! :yay:
  15. Jun 2, 2020 at 6:36 PM
    #235
    UnrestrictedPilot
    UnrestrictedPilot Well-Known Member
    Josh
    2008 Tacoma Double Cab
    Okay Everyone here is my Anytime Fog Light MOD done the easiest way I think possible. Literally 5 min start to finish.
    As you know from reading others on here, there is no simple way without splicing wires or tapping into the wire port until now!
    This will allow you to have the foglight on any time. The only catch is that even when the ignition is off, the foglights will still be able to be turned on unlike the other method which requires the ignition to be on. Do not leave then on and drain your batteries....especially if your not running LED's
    This is 100% reversible and no wires are cut! Only the one tab on the foglight relay is bent!
    You will need to purchase one of these for 10$ on Amazon
    ATM Add-A-Fuse (Same Function as Bussmann BP/HHH) ATM Fuse Tap
    https://www.amazon.com/gp/product/B007FFG5YI/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
    Step 1: Remove the Fog like relay and bend back the tab as shown.
    Step 2: Cut off the end of the add a fuse which is meant for a wire crip and instead crip on a general plug that will attach to the fog light relay metal part that we bent over earlier
    Step 3: Pull out the horn fuse, put 2 10 amp fuses in the add a fuse slots and then re-insert this into the horn fuse slot. Then attach the end of the wire to the fog light relay tab that we bent earlier and you will be all done.
    Disclaimer, someone did this by attaching the 10 amp fuse off of the EFI circuit. I tried this and it made the truck run rough and turned on the check engine light, which is why I moved to the horn fuse.
    2013XSPX likes this.
  16. Jun 6, 2020 at 11:24 AM
    #236
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    @UnrestrictedPilot what 10A fuses are you using? The ones in the stock slot don't have deep enough teeth and these 10A's I had in the garage have teeth that are too wide.
    Any assistance will be appreciated!
    Oh...and does this Denso Relay only control the Fogs? My slot in your pic says "AI VALVE"
    I have a 2013 4x4 SR5. I do see a slot with a 15A fuse labeled "FR FOG"
    Thanks everyone!!
    [​IMG][​IMG][​IMG][​IMG]
  17. Jun 6, 2020 at 11:29 AM
    #237
    UnrestrictedPilot
    Josh
    So I do not have the original box the fuses came in to reference but i do remember getting them from either an auto parts store or walmart that carry the general automotive fuses. Please let me know if you need any more help. I looked and could not find a name or identifier on the fuse unfortunately.
    2013XSPX[QUOTED] likes this.
  18. Jun 6, 2020 at 11:31 AM
    #238
    2013XSPX
    GA/FL Border
    2013 XSP-X
    Ok. Thank you!
    Do you know the name of the Denso Relay you tapped into and bent the blade? I appreciate it.
  19. Jun 6, 2020 at 1:20 PM
    #239
    UnrestrictedPilot
    Josh
    is your truck a 2013 like your username says? If it is you may have to look at the posts that are specific for those years since it’s a little different but on my fuse box it’s says it a fog light relay
  20. Jun 6, 2020 at 1:22 PM
    #240
    2013XSPX
    GA/FL Border
    2013 XSP-X
    It is. Will do. Thank you so much!
