Anytime fogs for 2012
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fractured, Feb 6, 2012.
  1. Feb 6, 2012 at 9:56 PM
    Fractured
    Fractured [OP] FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    I was looking up info on doing the anytime fogs mod on my 2012. After searching, I realized they are only on 05-11? Anybody have a link to doing it on a 2012? Did I miss something in my searches?
    I was going to post this in lighting, but I figured I would get more people with 2012s in this section. If a mod feels it is inappropriate, please let me know.
    Ps. If no one has tried it, I will figure it out and post a how to.
  2. Feb 6, 2012 at 10:00 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    I heard its exactly the same...:notsure:
    It's the same truck anyways...not much has changed :cool:
  3. Feb 6, 2012 at 10:06 PM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    I read a couple threads about people messing things up when doing the 05-11 method. Can't confirm it is different though.
  4. Feb 6, 2012 at 10:17 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    That is what concerned me.
  5. Feb 6, 2012 at 10:39 PM
    Rotorheader
    Rotorheader Active Member
    Don
    Eugene, OR
    2012 Prerunner 4-cyl
    I did one posting with pictures on what I found in December. The lights from the 2011's don't work. The 2012's lights have two tabs on one side, and two Phillips screws on the other side. The closest fit I've looked at is eBay, searching for Corolla or Camry fogs. I haven't gone further than that, and want to follow your thread
  6. Feb 6, 2012 at 10:43 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    I'll see if I can get someone down here with a 2012 to tell me what they did...
    Wait, youre talking about the actual housings...right??
  7. Feb 6, 2012 at 10:43 PM
    himmie
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    I don't think that's what the OP is talking about?
  8. Feb 6, 2012 at 10:46 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
  9. Feb 6, 2012 at 10:56 PM
    himmie
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
  10. Feb 6, 2012 at 10:58 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
  11. Feb 6, 2012 at 11:08 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Ah thread title explains why nothing came up in search. I will perform this this weekend.
  12. Feb 7, 2012 at 5:19 AM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
  13. Feb 7, 2012 at 8:10 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    Use the thread linked by others...I did it and it has worked great...
  14. Feb 7, 2012 at 8:23 AM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    i followed "caribe makaira's" write up and have had no problems.
  15. Feb 7, 2012 at 3:54 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Are you guys still bending the tab for the foglamp relay out to the side? And then installing a female spade connector? Or are you pressing a male spade connector down in there with it?
  16. Feb 7, 2012 at 5:28 PM
    cintocrunch
    MD
    I attached a female connector to the fuse after bending the tab out, ran a wire with a 1 amp in line fuse and a male connector into the seat heater pin...
  17. Feb 7, 2012 at 5:33 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    That's what I will do- I already have the inline fuse. Thanks for the input.
  18. Feb 7, 2012 at 9:09 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    So I couldn't wait and I did this mod tonite.
    My truck didn't come with seat heaters, so I could not get get power to the right of the foglamp relay. Other than that, everything worked great! I used a 2a fuse as well (full size) because that's all I had.
  19. Feb 7, 2012 at 9:25 PM
    DIVERMAN
    Cullen
    Louisiana
    Fractured-- i had to do the same for power, turn them off with the button or they will come back on after sometime. not sure on the time frame though.
