Anytime front and rear camera.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by navytacoma, Aug 24, 2019.
  1. Aug 24, 2019 at 6:36 PM
    navytacoma
    navytacoma [OP] LCoverland.com
    Jacob
    Phoenix AZ
    2023 TRD Sequoia
    Hello all,
    Just attempted to install my anytime front and rear camera,
    I followed all the wiring steps they showed on the website.
    issue: switch lights up orange indicating rear camera is on when it is in the middle (so no camera is selected) and then turns off when flicked down or up. second problem, it only lit up when in reverse. not sure what the deal is about that. third issue. i now have no light for my e brake, and a fantastic air bag light on.
    anyone run into this issue??
  2. Aug 24, 2019 at 6:42 PM
    ICU1
    ICU1 Well-Known Member
    Should of bought the Car Solution controller from Amazon. I just finished installing this evening. Works great. Plug in play. Uses function button on steering wheel.
    Jayscull and Tocamo like this.
  3. Aug 24, 2019 at 7:17 PM
    navytacoma
    Jacob
    Phoenix AZ
    2023 TRD Sequoia
    oh thanks for the assistance with my issue
    ExplorHer, Turd Hawg and Heyitsclint like this.
  4. Aug 24, 2019 at 7:30 PM
    ICU1
    No problem. I’ve been there done that. I feel for you.
  5. Aug 24, 2019 at 7:31 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Can you link what you bought?
  6. Aug 24, 2019 at 7:36 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    The "on" led gets power from the switch so you probably have your power in and rear camera switch "out" wires reversed.
  7. Aug 24, 2019 at 7:36 PM
    ICU1
    If you go this rout, make sure and order the model for the third gen Tacoma not the second gen. Ask me how I know.
    Act fast because these units go fast.
  8. Aug 24, 2019 at 9:21 PM
    navytacoma
    Jacob
    Phoenix AZ
    2023 TRD Sequoia
  9. Aug 25, 2019 at 3:36 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    1st switch your wiring around and then will work when pressed.
    2nd I believe you have to tap power going into one of the switches next to it for it to be lit up all the time.
  10. Aug 25, 2019 at 5:21 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'm holding out for the model that uses your steering wheel controls, instead of adding a switch.
  11. Aug 25, 2019 at 9:40 AM
    navytacoma
    Jacob
    Phoenix AZ
    2023 TRD Sequoia
    I’ll try that
  12. Aug 25, 2019 at 10:13 AM
    navytacoma
    Jacob
    Phoenix AZ
    2023 TRD Sequoia
    Swapped wires and issue is still the same. In reverse you turn on the reverse camera switch and the lights I want turn on and the airbag light turns off
  13. Aug 25, 2019 at 11:45 AM
    navytacoma
    Jacob
    Phoenix AZ
    2023 TRD Sequoia
    Update. Windows don’t roll down. And ac won’t turn on. Only blows out from defrost
  14. Aug 25, 2019 at 12:26 PM
    Riotfunk
    Taco TRD off road
    Check fuses, I have one like that and wired my own switch and haven't had any issue like you're having.
  15. Aug 25, 2019 at 12:50 PM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    I used a different kit but had a similar issue with no cameras functioning after install including the rear camera when going into reverse. I just unplugged and replugged all connections and then it worked. May sound silly but it's worth a shot. Have you contacted the manufacturer, maybe your harness is defective?
    Did you unplug the battery during install? You may have shorted something and blown fuses which is cause your other issues? Otherwise did you unplug any connections that are part the airbag system?
    Are you sure you have good connections to ground? Some bolts in the interior just screw into a metal insert in plastic so they are not actually connected the chassis.
  16. Aug 25, 2019 at 4:37 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
  17. Aug 26, 2019 at 9:37 PM
    navytacoma
    Jacob
    Phoenix AZ
    2023 TRD Sequoia
    Figured everything out for the back camera. But based on the wiring video they posted and how I wired my front camera up. It shuts off all camera functions when front is turned on.
