Anytime front camera electrical wiring question.
Discussion in 'General Tacoma Talk' started by Chrisx8182, Jul 24, 2025.
  1. Jul 24, 2025 at 11:33 PM
    Chrisx8182
    Chrisx8182 [OP] Well-Known Member
    Los Angeles
    2022 Tacoma 4x4 sport
    IMG_0692.jpg Hello,
    Total noob question. I am installing an anytime front camera and I have to extend some of the wiring for the camera switch to reach on the side panel. I think they made it for it to fit right under the ac controls. But I have no room for a switch there. So just wondering if I can use solid wire instead of stranded wire that’s included in the kit. Will it be an issue if I combine the two?
  2. Jul 25, 2025 at 12:00 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You generally don't want to use solid wire in the automotive environment. Vibrations could lead to the wire breaking.
    soundman98 likes this.
  3. Jul 25, 2025 at 7:42 PM
    Chrisx8182
    Los Angeles
    Thank you. Thats being worst case, just them breaking and having to change em out? I’m more worried about it causing a fire or something haha. I already have em installed and everything seems to be working ok so far..
  4. Jul 26, 2025 at 7:04 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    you've got a $60k pickup truck, and you're throwing discount household romex at it?
    just get some stranded wire, and do it correctly. there's a reason it's the correct method.
    there's the risk of the wire breaking, but depending on the gauge of solid core, the added stiffness of the copper can potentially cause chaffing issues on other factory wires, which could result in massive repair bills-- because the official shop procedure for damaged wires is to replace the entire harness, not repair small sections.
  5. Jul 26, 2025 at 7:10 AM
    Chrisx8182
    Los Angeles
    It’s just what I had laying around at home while I was doing the install. lol
    But thanks for the info.
