Anytime Locker Mod wire questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbkonkle, Nov 21, 2008.
  1. Nov 21, 2008 at 3:37 PM
    dbkonkle
    dbkonkle [OP] Member
    Springdale, AR
    09 4x4 TRD Off Road
    I've got a suitable relay and would be ready to procede, but have some confusion over which end of the wires are to be connected to the relay after cutting. Can anyone tell me if the connector end or wiring harness end of the wires is connected to the relay and if the other side of the cut wires is just left unterminated.
    I'm just trying to figure out which side of each of the cut wires is attached before cutting. Any help would be greatly appreciated.
    David
  2. Nov 21, 2008 at 5:25 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    The wire harness side. Yes, the terminal side are to be the loose ends.
  3. Nov 21, 2008 at 8:19 PM
    dbkonkle
    Springdale, AR
    09 4x4 TRD Off Road
    Thanks, that's what I was thinking. I Just didn't wan't to assume anything and start chopping on a truck that's less than a week old.
    David
  4. Nov 21, 2008 at 10:06 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
  5. Nov 22, 2008 at 7:06 PM
    dbkonkle
    Springdale, AR
    09 4x4 TRD Off Road
    At this point I'm leaning toward the relay because I would prefer the locker to engage when I engage the button and not have to flip a secondary switch first. If I'm reading correctly it can cause some issues with the indicators blinking if you forget to flip the switch off before starting the truck.
    I'm not opposed to cutting wires on a week old truck, just wanted to clarify the connections before cutting.
    David
