Anytime Rear Camera, Non OEM Head Unit.
Discussion in 'Audio & Video' started by Unchained 5150, May 21, 2019.
  1. May 21, 2019 at 9:40 AM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So I just put an RTT under the Softopper and obviously it blocks the rear view camera. Is there a way with my Kenwood Head Unit 672BH to make it so I can turn the rear camera on and leave it on while driving?
  2. May 21, 2019 at 9:49 AM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Just took a look at the manual, if you have the rear camera plugged into the AV Input slot, you should be able to select "AV-IN" from the "ALL SRC" menu. If it's plugged into the reverse camera spot, you can turn it on when "AV Key Long Press" is set to the "R-Cam" setting.
  3. May 21, 2019 at 9:58 AM
    Unchained 5150
    Rick
    Auburn Ma
    Hmm I'll have to check that as it's the OEM Camera
  4. May 21, 2019 at 11:26 AM
    CttAznRanger
    Brandon
    Boston, MA
    Its most likely plugged into the reverse camera spot I assume. Assuming you can still use it while reversing. Give it a go and let us know how it goes.
  5. May 21, 2019 at 11:37 AM
    Unchained 5150
    Rick
    Auburn Ma
    AV In shows nothing so it must be in the reverse spot.
  6. May 21, 2019 at 11:46 AM
    CttAznRanger
    Brandon
    Boston, MA
    See if you can go into the settings menu, and change the "av key long press" function to "R-Cam". Once that's set, try and hold the AV button
  7. May 21, 2019 at 11:55 AM
    Unchained 5150
    Rick
    Auburn Ma
    Thanks I'll do that in a few
  8. May 21, 2019 at 2:43 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    R-cam interrupt on at initial setup and long press av button.
  9. May 21, 2019 at 3:06 PM
    Unchained 5150
    Rick
    Auburn Ma
    Wow that is a lot thanks. Guess I'll take it to my installer to fix it.
  10. May 21, 2019 at 3:07 PM
    Unchained 5150
    Rick
    Auburn Ma
    Or I could reset it and go from there
    DirtJumper14 likes this.
  11. May 21, 2019 at 4:21 PM
    DirtJumper14
    SoCal
    2005 TRD OR
    It's easy to do
  12. May 21, 2019 at 4:24 PM
    Unchained 5150
    Rick
    Auburn Ma
    Should I reset it first
  13. May 21, 2019 at 5:27 PM
    DirtJumper14
    SoCal
    2005 TRD OR
    Yes. It should save all of the settings (maybe not radio stations). Once you can see the image I believe you tap on the bottom of the screen to turn it off. Or if yours has 2 inputs like mine you tap the top to switch between front/rear.
  14. May 23, 2019 at 8:43 AM
    Unchained 5150
    Rick
    Auburn Ma
    Looks like I have to take the radio out to fix this yippeeeeeee
  15. May 23, 2019 at 8:58 AM
    CttAznRanger
    Brandon
    Boston, MA
    What happened now? It seems like it's going to be a pain in the ass.
  16. May 23, 2019 at 9:25 AM
    Unchained 5150
    Rick
    Auburn Ma
    Non of the suggestions worked, but I'm getting a newer model now anyway so I can use Waze on the receiver with my phone.
  17. May 23, 2019 at 10:14 AM
    CttAznRanger
    Brandon
    Boston, MA
    Well, that works.
  18. May 24, 2019 at 10:56 AM
    DirtJumper14
    SoCal
    2005 TRD OR
    That is a good solution too. I want to replace my dnx890hd. Nav just stopped working. Guess some memory card internally goes out. What model are you going to get?
  19. May 24, 2019 at 11:16 AM
    Unchained 5150
    Rick
    Auburn Ma
  20. May 26, 2019 at 11:30 AM
    Unchained 5150
    Rick
    Auburn Ma
