Anyway around reprogramming an ABS unit
Discussion in 'General Tacoma Talk' started by Steel Mill, Oct 13, 2023.
  1. Oct 15, 2023 at 4:31 PM
    #81
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't tap into the vehicle wiring but if you had a couple female spade terminals and some wire you could unplug the headlight and attach wires to it that way.
    I'm not sure which one is the ground and the 2 powers on the headlight bulb without looking though.
  2. Oct 15, 2023 at 4:47 PM
    #82
    Steel Mill
    Steel Mill [OP] Well-Known Member
    Greg
    2007 Toyota Tacoma
    Well I can do that. I’ll stop on buy some tomorrow. I know for sure what that is. I would do it now if I had some. I can run a test light to them to see what’s hot and what’s not. Turning on the headlights and try with headlights off. I’ll find the right ones before I tap into them.
    I would say it would be a good idea to get some male ends also for the plug in / wiring harness. My opinion but could be wrong.
  3. Oct 15, 2023 at 7:42 PM
    #83
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Ok. I’m sure you know that old saying curiosity killed the cat. Lol. Well it was getting the best of me. So I went out and pumped the brakes without the truck running. Had a good firm pedal. Started the truck and the pedal almost hit the floor. So is the brake booster good or bad ? I also pulled the master cylinder off it to check for brake fluid. I did find some around the inside ring where the cylinder slides in at. Now with that being said I got a coat hanger and checked the bottom of the booster. Coat hanger was dry as a bone. I just wonder if the brake fluid could have ran behind the master cylinder whenever I was putting fluid into the reservoir ? I wouldn’t think that would be possible but nothing is surprising me anymore with these brakes. So is the master good or bad ? This picture you can see is wet. I did touch it and in my opinion it was 100% brake fluid.
  4. Oct 15, 2023 at 8:11 PM
    #84
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Looking at the wiring diagram it looks like one of the side pins is ground and the other is high beam.
    I'm not sure a standard spade terminal would fit into the ABS connector without damaging the terminal.
    I've never seen a bad booster cause a soft pedal, most of the time when they fail you have a hard pedal due to no assist from the booster.
    Certainly not unheard of for master cylinders to leak into the booster (I see this quite often on GM trucks although the brakes typically still work fine the brake fluid just disappears).
    I mean it could be leaking by internally as well, no way to tell for sure without being able to block off the lines and see if the pedal is still soft or replacing it.
  5. Oct 15, 2023 at 8:33 PM
    #85
    Steel Mill
    Greg
    2007 Toyota Tacoma
    I’ll definitely get some connectors tomorrow after work and make some up. Well at least I knocked 2 other things out of question for the brakes not working. Lol
  6. Oct 16, 2023 at 1:51 PM
    #86
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Wired up to the headlights pictures
  7. Oct 16, 2023 at 1:59 PM
    #87
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I assume the head light light up? Correct?
    If so, the power and ground is not the problem.
    The search continues.
    Dm93 likes this.
  8. Oct 16, 2023 at 2:03 PM
    #88
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Yes sir headlights are correct. I test them with a test light. Looking at the pigtail. Right side ground. Top center low beam which would be power. Left side is high beam which means power.
    Honestly if I’m wrong please correct me.
  9. Oct 16, 2023 at 2:08 PM
    #89
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Also I was using the passenger side pigtail. When I hooked them up in the abs wiring harness the drivers side headlight came on. I assume that is correct and that’s what it should have done. Been wrong way to many times in life and if I’m wrong this wouldn’t be a first.
  10. Oct 16, 2023 at 2:09 PM
    #90
    TnShooter
    Deogee
    STOCK
    For the head light.
    Match the prong on the head light connector to the colors below.
    Pink wire is high beam
    Red/yellow is low beam.
    White/black is ground.
    So for clarification, the head light will light up using the ABS connection to power the head light?
    Dm93 likes this.
  11. Oct 16, 2023 at 2:11 PM
    #91
    TnShooter
    Deogee
    STOCK
    This is easier.
    Dm93 likes this.
  12. Oct 16, 2023 at 2:12 PM
    #92
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Yes sir. When wired up to the ABS connection the lights come on. I greatly appreciate the color code. Thank you
  13. Oct 16, 2023 at 2:13 PM
    #93
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Thank you
    TnShooter[QUOTED] likes this.
  14. Oct 16, 2023 at 2:15 PM
    #94
    Steel Mill
    Greg
    2007 Toyota Tacoma
    I just double checked myself with the wiring and it is spot on
  15. Oct 16, 2023 at 2:16 PM
    #95
    TnShooter
    Deogee
    STOCK
    Yeah, I’m not sure how you are “hooking up” the power to the head light.
    It is good you got them to come on.
    But you want to hook power to the head light bulb. Not the connector.
    If you hooked power to the connector, you back feed to the other build. Not an ideal way to test things.
    Better to just use the bulb next time. :thumbsup:
    Dm93 likes this.
  16. Oct 16, 2023 at 2:23 PM
    #96
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Well with my luck I just messed something up then.
  17. Oct 16, 2023 at 2:24 PM
    #97
    TnShooter
    Deogee
    STOCK
    No, it’s fine.
    You were still fused. And isolated by a relay.
    Unfortunately, the power and ground is not your issue.
    Not if they light up a head light………
  18. Oct 16, 2023 at 2:36 PM
    #98
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Ok. Redone the test with headlight attached. Different numbers by a very little. Hopefully I got it right this time. Lol
  19. Oct 16, 2023 at 2:38 PM
    #99
    TnShooter
    Deogee
    STOCK
    We don’t really need the voltages.
    But it didn’t hurt to include them.
    The whole reason @Dm93 had you use a headlight was to confirm the wires could carry a load (current). :)
    And now we know “they can”….:thumbsup:
    Dm93 likes this.
  20. Oct 16, 2023 at 2:40 PM
    #100
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Hey buddy in all honesty I greatly appreciate the help and any help that you could give. I appreciate all of this.
