Anyway around reprogramming an ABS unit
Discussion in 'General Tacoma Talk' started by Steel Mill, Oct 13, 2023.
  1. Oct 16, 2023 at 2:43 PM
    #101
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No problem.
    This has me stumped.
    It’s like you have 2 issues.
    A bad abs unit and hydraulic issue.
    Do you? Maybe.
    But that would be super rare to have both problems “at once”?
    Dm93 likes this.
  2. Oct 16, 2023 at 2:47 PM
    #102
    Steel Mill
    Steel Mill [OP] Well-Known Member
    Greg
    2007 Toyota Tacoma
    Well this is my 3rd ABS unit counting my original. I’m all honestly I thought I knew brakes but this Tacoma has 100% proved me dead wrong.
  3. Oct 16, 2023 at 2:50 PM
    #103
    TnShooter
    Deogee
    STOCK
    Wow……I missed the 3rd “ABS unit” part.
    Now I’m really stumped………
  4. Oct 16, 2023 at 3:01 PM
    #104
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Sorry. I’ve been that way for 4 months now. Thought I knew but guess again. Lol Yeah I was wrong. Not the first won’t be the last.
  5. Oct 16, 2023 at 3:04 PM
    #105
    Steel Mill
    Greg
    2007 Toyota Tacoma
    An for the hydraulic part I’m not sure about. My brake booster is air and my master cylinder is just brake fluid. It doesn’t have hydraulics hooked up to it. But once again I might be wrong. Lol
  6. Oct 16, 2023 at 3:16 PM
    #106
    Steel Mill
    Greg
    2007 Toyota Tacoma
    What is the plug-in that goes to the side of the master cylinder? Where does it go and watch it do ? It’s like plugged in to the side of the reservoir.
  7. Oct 16, 2023 at 3:19 PM
    #107
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    might have missed but for the wheel sensors, are you sure you put them in the right spots? Also did you ever change any wheel bearings? May be unrelated but I had issues with the same code we had swapped in 2 left wheel bearings and the sensors did not like that. we replaced the harness and sensors and it only went away when we put in the correct right. We did it as its easier to carry 1 wheel bearing off grid than 2 which will work just won't work with the ABS. Try replacing the harness too if testing that if you have not.
    Figured toss that in there if you find your ABS is fine. We went back and forth for a few weeks before just going back to OG setup format (net new wheel bearing again).
  8. Oct 16, 2023 at 3:24 PM
    #108
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Well now I’m even more freaking confused. LOL. Well I didn’t change anything but the wheel speed sensors. I honestly thought I put everything in right.
  9. Oct 16, 2023 at 3:39 PM
    #109
    TnShooter
    Deogee
    STOCK
    They only go in “one” spot.
    Once they are plugged in, the go to “separate” pins on the Skid Control ECM.
    You can not really get them in the wrong spot.
  10. Oct 16, 2023 at 3:41 PM
    #110
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Ok then. I got them right. Well at least I hope I do. Lol
  11. Oct 16, 2023 at 3:43 PM
    #111
    TnShooter
    Deogee
    STOCK
    The brake fluid level sensor.
    The brake light will come on if the fluid is low.
    The same brake light as the E-brake uses.
    Dm93 and Steel Mill[QUOTED][OP] like this.
  12. Oct 16, 2023 at 3:46 PM
    #112
    TnShooter
    Deogee
    STOCK
    Nothing wrong with hoping…..:rofl:
    I’ve done lots of thing based on “Hope”.
    Sometimes it works out ok. Other times not so much:eek:
  13. Oct 16, 2023 at 3:58 PM
    #113
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Th
    Thank you. I figured it would have been another relay or something like that I didn’t know about
  14. Oct 16, 2023 at 3:59 PM
    #114
    Steel Mill
    Greg
    2007 Toyota Tacoma
    I’m about to Fred Flintstone this son of a gun.
    TnShooter likes this.
  15. Oct 16, 2023 at 5:15 PM
    #115
    nudavinci64
    Robert
    ok lets not confuse you any further if you only replaced the sensors and they are all in the right spot then you should be good to go on that front.
  16. Oct 16, 2023 at 5:30 PM
    #116
    TnShooter
    Deogee
    STOCK
    I’m semi invested in this now.
    I’m going to go back and read through all the post.
    See if we missed a a clue or two.
    Dm93 is going to be the head on this operation.
    He does this for a living.
    Me? No, no me.
    I just fix stuff once it’s broke. :rofl:
    But sometimes guys like me, who know just enough to to be dangerous, can point out the obvious that gets over looked. Or have ideas just dumb enough that “work”. :eek:
    Anyways, I’ll see what ideas I can add to this.
    Let me read over it all again.
    Dm93 likes this.
  17. Oct 16, 2023 at 5:42 PM
    #117
    Steel Mill
    Greg
    2007 Toyota Tacoma
    Guys I definitely appreciate the help I really do.
  18. Oct 16, 2023 at 5:46 PM
    #118
    TnShooter
    Deogee
    STOCK
    Start with what we know and when it happened.
    We know you have ABS codes, and that the ABS module is activating the ABS.
    This all started after hitting a BIG pothole.
    (Was the pot hole hit with the right wheels?) - (You have codes for those wheels)
    Also, did you replace any wheel speed sensors?
    With fuses installed:
    C0210 - Rear speed sensor RH circuit
    C0278 - OPN/Short in ABS Relay Circuit
    C1235 - Foreign object front FH sensor
    C1241 - Low/High Battery voltage
    Without fuses installed
    What to try (maybe)?
    Your scanner has the ability to read wheel speed and wheel direction.
    I’d start with a short drive while monitoring those data pids.
    Dm93 and DES2009 like this.
  19. Oct 16, 2023 at 7:53 PM
    #119
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Never hurts to check voltage drop with a load (in this case a headlight) on the circuit although usually this isn't necessary as most of the time a bad circuit wouldn't even light a headlight even though it may still show battery voltage on a meter with no load applied.
    Being the circuits load test good I can see no reason the C0278 is setting other than a pin fitment problem or faulty ABS module although I still think the low pedal is a separate issue.
    Well I mean we can't rule out the master cylinder without being able to cap off the lines and see if you have a firm pedal.
    Excellent reacp and good suggestion.
    I would assume this would be obvious but I have to ask at this point, there are no obvious fluid leaks anywhere correct?
    TnShooter[QUOTED] likes this.
  20. Oct 16, 2023 at 8:26 PM
    #120
    TnShooter
    Deogee
    STOCK
    A little more digging and I looks like pulling the ABS fuses doesn’t kill the ABS unit completely.
    There’s still a power at pin 46.
    Does this make a difference? Probably not.
    Also, when all the fuses were installed.
    Did the ABS come on instantly when the brake pedal is pressed?
