Anyway to add a steering stabilizer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fyremanpat, Oct 12, 2012.
  1. Oct 12, 2012 at 11:32 AM
    fyremanpat
    fyremanpat [OP] Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    yes it drives right. with larger tires added it grabs the dips in the road now. before i put a stabilizer on and it solved the problem. i never said nobody elses truck doesnt do that. all i asked if there was akit available. a simple no could have fixed that. yes i have a print out and according to the numbers posted above it is correct. this is my first taco so assuming that kits are only available for the older trucks then they had a different steering setup
    Flori-duh Taco and chadstacoma like this.
  2. Oct 12, 2012 at 11:34 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    it's all good. I am a dick.... especially when people call me skip.
    Sorry OP just trying to help you out. For people like you I would advise calling a shop. They will be able to hook you up with everything you need.
  3. Oct 12, 2012 at 11:35 AM
    XXXX
    sKiP
    05 Prius
    Hows your tire pressure? 60PSI by chance?
    Flori-duh Taco likes this.
  4. Oct 12, 2012 at 11:36 AM
    fyremanpat
    Pat
    757
    a db?..defensive?yes. im not gonna be talked to like a kid.
  5. Oct 12, 2012 at 11:36 AM
    fyremanpat
    Pat
    757
    48psi all the way around
  6. Oct 12, 2012 at 11:36 AM
    Beast Mode
    Beast Mode Well-Known Member
    PDX
    12 DCSB Sport 4x4
    RCD lift, Pro Comp, 285/70/17 Destination AT, LR UCA, magnaflow muffler, LEER 180, Flyzeye, Clazzio covers, N-Fab steps
    Looks like the OP got his answer so excuse my hijack, but I believe it pertains to the topic at hand. XXXX, you posted the specs that lifted Tacomas should strive for and it is probably the reason I'm experiencing the same thing the OP is feeling. I feel like my front end is too stiff and feel everything (more so than on my last two lifted tacos). Here are my caster specs:
    Left: 1.6
    Right: 2.0
    Camber is 0.4 on both sides.
    From your experiences will the caster deviation of 1 degree provide a harsher ride?
    Thanks
  7. Oct 12, 2012 at 11:37 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    what are the caster numbers?
  8. Oct 12, 2012 at 11:40 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Low caster creates a wandering problem (grabbing grooves in the road) because the mechanical trail is reduced, reducing the tendency for the wheel to self center. Think of it like a caster wheel on an office chair, if the pivot was right in the middle of the wheel it would not be as stable as if it were offset (like they are).
  9. Oct 12, 2012 at 11:52 AM
    XXXX
    sKiP
    05 Prius
    way to high IMO.
    I'm running much less then that and my truck is fully armored. I would run some stripes of chalk across the tires and then air them down until you are getting full contact. right now your driving in ice skates
    Sorry...I'm an asshole
    hell yea
    bwahahahahaha
  10. Oct 12, 2012 at 11:52 AM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    okay, that makes sense, thanks for the info. with my lower caster I don't wander at high speeds or grab grooves. I still plan to go back and get the desired specs. BTW, the shop I went to specializes in lifted trucks too.
  11. Oct 12, 2012 at 11:57 AM
    XXXX
    sKiP
    05 Prius
    doesn't matter. every shop will have the same specs on the computer and it all depends on the mechanic. Personally I got my first alignment done by a guy who does just about everyone's Taco in the NE and also sets up MJP2's truck. He put me on 0, 0, 2.9. Unless they are testing and tweaking the alignment for a particular model and take note of the sweet spot they won;t know anything more then what the computer says. Even with that said your trucks not in specs for a stock truck if my memory is correct.
  12. Oct 12, 2012 at 12:36 PM
    Kdawwwg
    Kdawwwg Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    its everything combined
    1st its a spacer lift ,witch removes allot of the available down travel,tire rolls into a dip ,no travel left ,you well feel it in the wheel ,i know i had the spacer lift, there junk
    2nd 48 psi ,omg, try 35
    3rd no UCA's,we all no there is no way the stock arms can get caster that high with 285 size tires he can be at 2.5 /2.8 is better an be OK, but no way you can get 0 toe 0 camber an caster 2.5 or higher on stock arms,
    get rid of the spacer an get 5100s at 1.75,an you wont need UCA's,but would be better with
    have a nice day:)
  13. Oct 12, 2012 at 12:39 PM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    exactly! My mistake was not knowing the desired specs beforehand and telling the tech to get me there. Hell, I bought the damn LR UCA's for propper specs so I better get them.
  14. Oct 12, 2012 at 12:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Too high
  15. Oct 12, 2012 at 2:36 PM
    #35
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    My alignment greatly improved with UCA's.
    I have
    Camber @ 0 to -.01
    caster left 2.4 right 2.9
    toe is .05 on each side
  16. Oct 12, 2012 at 2:50 PM
    #36
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Treat others how you wish to be treated. Your new and immediately you call people names, and you expect to be treated like an adult? And also if you had used the search function (or at least google) you would have found this has been asked before
  17. Oct 12, 2012 at 3:38 PM
    #37
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    This, kdawwwg naiked it!!! ^…
    I should have paid more attention to the type of lift the OP has..spacer lift takes away down travel just as kdawwwwg mentioned. And no aftermarket UCA's ? Sorry OP but the shop you were at maybe a "very reputable shop". Unfortunately it appears they don't have any experience working on newer tacomas.
  18. Oct 12, 2012 at 4:50 PM
    #38
    fyremanpat
    Pat
    757
    Name calling?...his name says Skip so yes I'm guilty of calling him by his name....Yes im new to this forum good observation. I asked a simple question and got some useful info and some not so useful.... also i did use the search button and googled it but there was NO info on a 2013.
  19. Oct 12, 2012 at 5:00 PM
    #39
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    FIFY
    and Pat, settle down, breath.... XXXX was actually giving you some good advice, his delivery may not be the best, but he tries.
    Steering stablizers are just band aids for a bigger problem. Read Kdawwwg's post, it pretty much spells it out.
  20. Oct 12, 2012 at 5:30 PM
    #40
    fyremanpat
    Pat
    757
    I will re check my pressures. lowering my truck with the 5100's will give me more problems than i have. its fact that larger/wider tires grab the road more than stock and that stabilizers are a fix not a band aid...im guessing everyone is reading this wrong and/or i didnt explain well enough...it doesnt rip the wheel out of my hands I just feel it more than stock...its not a huge deal to me. i was wondering if the make a kit...and im assuming no. thank you to eveyone who has helped me
