Anyway to fit 15s?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scosh, Jul 8, 2010.
  1. Jul 8, 2010 at 7:18 AM
    Scosh
    Scosh [OP] Well-Known Member
    Scotty
    New Iberia
    02 Prerunner SR5
    Bilstein 5100's all around, Limo Tinted windows, Moto Metal 951 wrapped in Revo 2's 265/70/16, clear corners, dual Magnaflow muffler, Turn signal mod, more to come...
    My friend gave me a free set of TSL Super Swamper 33s with 15 inch rims. The lugs line up and everything, but they do not extend out far enough to where I can put on the lug nuts. The rims are 15s and my stock rims are 16s. So is there anyway I can fit them on my 02 Prerunner? I have them up for sale on craiglist for $500 in case there is no way I can fit them.
  2. Jul 8, 2010 at 8:48 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you talking about wheels or tires?
    TSL Super Swampers (33) is a TIRE.
    But you're asking about wheels...???? Do you know what kind of wheels they are? Got the link to your craiglist...??
    As far as I know, the only 1st gen tacoma that came with 16" wheels were the SRunner. The rest of them came with 15" wheels.
    Got any pictures of what they look like when you try to install them?
  3. Jul 8, 2010 at 8:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    2001 and up came with 16" wheels.
  4. Jul 8, 2010 at 9:05 AM
    Janster
    Jandy
    Lancaster, PA
    I'm not trying to doubt you on that....but why does it say in here that they came with 15" wheels as standard features?
    http://www.trdoffroad.com/articles/pdf/01_tacoma.pdf
    The SRunner & offroad package came with 16" wheels.
  5. Jul 8, 2010 at 9:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well dang gum! I guess the base wheels were 15"....
  6. Jul 8, 2010 at 9:59 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    go to the tire shop and tell them you need a different set of lug nuts. I had the same issue on one of my tacomas and they got me a set of lug nuts that grabbed plenty of thread.
  7. Jul 8, 2010 at 10:13 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I'm not sure I would believe everything in that PDF. There are several things that don't seem correct or are clearly inaccurate. For instance, the color swaths for Radiant Red and Impulse Red Pearl are the opposite of what they should be. IRP is the darker of the two. Also, that document lists the v6 as coming with a 3.91 gear. All the v6's in 1st gens I've ever seen had 4.10s stock.
    As for 16" wheels, for 01 to 04 Tacoma models, all of the Toyota alloy wheels were 16s.
  8. Jul 8, 2010 at 10:53 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    up to 2004 can fit a lot of 15" wheels, but if the lug bolts are not long enough to reach the nuts there is something else going on... if the backspace is 4.5" or greater, the bigger tires could be sitting up against the stock spindle and keeping the wheel from going completely on...
    if the wheels are from a chevy the bore is too small and the wheel is not completely on the hub...
    pics and specs on the wheel would be great...
  9. Jul 8, 2010 at 11:04 AM
    Digiratus
    Roaming the PNW
    The RedHead
    It could be the lug nuts you are using. The stock lug nuts typically don't work with aftermarket alloy wheels. More info about the wheels would help.
  10. Jul 8, 2010 at 11:34 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    The 5 lug "base" wheels are 15". I'm guessing once you get up to the 6 lug models the wheels are all 16".
    Holy shit I knew something Chris4X4 didn't! :eek::eek::eek:
  11. Jul 8, 2010 at 11:38 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    by buddy's base model 04 xcab 4x4 came with stock 15x7s
    then again, it also lacked power windows and doors...
  12. Jul 8, 2010 at 11:48 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    scratch that... he went reverse... it came with 16s but he now runs 15s to save on tires... haha
  13. Jul 8, 2010 at 11:59 AM
    blitz10
    blitz10 Active Member
    My son's DC 4x4 came with 15'' wheels, aftermarket. The spare was a 16''. The window sticker was in the glove box, 16'' wheels are an upgrade from the standard 15''. I have since put the 16'' wheels and tires off of my 2004 on it. I did notice that the lug nuts were far recessed into the wheel on the 15''. We did not get the lug key and had the drive a smaller socket on the keyed lug to get it off on all 4 wheels. Wheels appear to be Discount tire brand, MB center caps. Those 15'' wheels look really nice, just wish the were 16'' though.
  14. Jul 8, 2010 at 12:03 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    no the 6 lug base models still came with 15" on 2001s unless its an srunner
  15. Jul 8, 2010 at 12:17 PM
    Janster
    Jandy
    Lancaster, PA
    Ok...so here's another one directly off Toyotacertified.com website. I couldn't get a brochure any earlier than 2004 - same results.
    15" wheels standard.
    16" wheels as an option
    16" wheels standard on the SRunner
    http://www.toyotacertified.com/ebrochures/04_tacoma.pdf
  16. Jul 8, 2010 at 12:55 PM
    Scosh
    Scotty
    New Iberia
    02 Prerunner SR5
    This is the link for the sale.
    http://lafayette.craigslist.org/pts/1828137425.html
    And Im 100% sure my wheels are 16'' because my current wheel specs are 265/70/R16 and the swampers are 33''x12.50-15LT.
    Im getting them sold tomorrow so Im not upset at all, besides I got them for free and Im making a $500 profit!
  17. Jul 8, 2010 at 2:04 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    looking at the ad, I was thinkin the right thing...
    the wheels are from a Chevy, which has a smaller center bore than the yota, so the wheels were not mounting on the hub correctly, which is why the lug bolts were not coming all the way through...
    it was nothing wrong with the truck, just with the wheels...
  18. Jul 8, 2010 at 2:22 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    thats decent:)
  19. Jul 8, 2010 at 3:34 PM
    rwilhite07
    rwilhite07 Well-Known Member
    Florida
    ya id say if u can get those sold for $500 do it!
  20. Jul 8, 2010 at 3:35 PM
    rwilhite07
    Florida
    and toyotas center bore is 4.25'' keep that in mind if buying rims they have to be that size to fit over the hub.
    if im remembering correctly in MM toyota center bore is 108mm and chevy is 101mm.
