Anzo Headlights for 2016 - 2018 Tacoma SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MJ99, Jul 20, 2018.
  1. Jul 20, 2018 at 2:08 PM
    MJ99
    MJ99 [OP] Member
    Jay
    2018 Tacoma SR
    Hi ALL,
    I've got a set of ANZO 111377 for 2018 Tacoma SR. It has a White Outline Tube but that is not the DRL. The DRL is 3 Tubes that also are the turn signals. They're Amber at all times. The Amber tube has small chip boards (LED Chips) behind the tubes. My question is, is it all possible to convert these Amber strips to a switchback style WITHOUT opening the headlights??? Say a diode or something (I'm not even sure what a diode does besides blocks a current from going both ways in the line. I'd love to have these Amber DRL's running White as most DRL's are, and only Blink Amber when the signal or flashers are engaged.
    Knowledgeable about the mechanics of vehicles and have a basic understanding of lighting/wiring but am scratching my head here. Any help would be much appreciated - in layman's terms please :)
    Thank you in advance
  2. Jul 20, 2018 at 4:32 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If it's not factory switchback, you're SOL unless you want to crack open the lights
  3. Jul 20, 2018 at 4:37 PM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    If the white is not DRL and the ambers are turn, when does the white come on?
  4. Jul 20, 2018 at 6:48 PM
    MJ99
    MJ99 [OP] Member
    Jay
    2018 Tacoma SR
    The white and amber turn on in the DRL position. The amber is the turn and hazard lights. The amber turns off when the headlights are in the On position but the white outline stays on with the headlights.
  5. Aug 8, 2019 at 4:27 PM
    Bigkevsmooth
    Bigkevsmooth Member
    Kevin
    The Anzo part number for SR models Switchback DRL is 111396. If you get the 111397 for an SR model they won't work.
  6. Aug 8, 2019 at 4:31 PM
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    What are you doing with your OEM headlights?
  7. Aug 8, 2019 at 5:03 PM
    Bigkevsmooth
    Bigkevsmooth Member
    Kevin
    Nothing until I make sure these work as described and are good qualit .
