AP LT or part out and Raptor???
Discussion in 'Long Travel Suspension' started by RacerAV, Jan 25, 2013.
  1. Jan 25, 2013 at 8:42 AM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    From what it sounds like u guys are missing the point, he wants good on road handling, more so than really good off road performance. Op sounds like he would sacrifice lt for mt if it meant he had a tight handling truck on road.
  2. Jan 25, 2013 at 8:42 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Raptor
  3. Jan 25, 2013 at 8:52 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  4. Jan 25, 2013 at 12:30 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    From you're OP it looks like you are leaning more to the want of comfortability. The raptor is extremely smooth to drive, very comfortable interior and is very powerful/fast. And with some changes (deaver leaf pack to get rid of the block and bumpstop kit) the raptor is extremely fun.
    I also have my doubts about the all-pro LT kit being worth it as a "long-travel kit" And you're tacoma will not drive the same if it is "fully" built.
    I love my tacoma without a doubt, Its just not as comfortable to drive as it once was. And will require multiple mods to get it even close to that.
    As said my dad owns a 2011 4-door raptor and loves it, I have also driven it vigorously on and offroad. It is very capable out of the box. But again, as said, a fully LT'd tacoma like mine has almost twice as much travel and is A LOT more fun in the desert than the raptor (but thats because I go balls out)
    At the end of the day you have to decide what you are going to be doing with you're truck, And choose appropriately/
  5. Jan 25, 2013 at 12:37 PM
    PLC721
    Patrick
    Chandler, Az
    What mods do you need to do to make your truck more comfortable?
  6. Jan 25, 2013 at 12:45 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    lighted cup holders and heated seats.
  7. Jan 25, 2013 at 1:02 PM
    Monster Coma
    Corey
  8. Jan 25, 2013 at 1:25 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Not even sure if its fixable. Need to figure out how to get rid of all the vibes, Solid mount to keep my alignment in spec so my truck doesnt dog track after trips, reweld core support, rebalance wheels and tires for wheel shake after trips & weights fall off. (sometimes). Find and fix all the annoying noises. Just usual TLC.
  9. Jan 25, 2013 at 1:27 PM
    PLC721
    Patrick
    Chandler, Az
    Gotcha, im fighting my truck now to make it quiet and comfy as stock and still be what it is.
  10. Jan 25, 2013 at 1:28 PM
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Its a hard battle. But damn worth it.
  11. Jan 25, 2013 at 1:31 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Solid mounting is easy, LSK's approach to it is so far the best (of what i've seen) for that as they don't actually weld anything besides the Cam Tabs.
    Some extra bracing & tubes would be good for the core support easily done since you're 2WD.
    As for the balancing maybe try some Dyna beads for balancing as then there's no weights to be loose etc :cool:
  12. Jan 25, 2013 at 1:36 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    But, when you actually take a Raptor to the desert and beat on it these things are going to happen too. The Raptor doesnt have special alignment cams, core support, wheels, tires or frames. If you actually want to beat on a Raptor your going to have to put more money into it, and address the bending rear frame immediately
    The question is do you want to spend money on? Do you want it to actually perform in the desert? Or do you want to look like you perform in the desert while driving a luxury truck?
  13. Jan 25, 2013 at 1:39 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I've been in that raptor and its WAY smooth! Icon 3.0 system all around in OEM locations with bypass' and jounces in the back! Hit up Serena (SDHQ vendor here) she was selling it months ago!
    As much as I really like the raptors, I don't have the need for a full sized truck and get a chub everytime I see a built taco! Like RJ's, JD's and all the other LT's in here....I know that's weird but no homo! :D
  14. Jan 25, 2013 at 1:40 PM
    PLC721
    Patrick
    Chandler, Az
    Yeah ive primarily taken care of every outside rattle, now i just have a few interior ones to find and fix. i went through and re-torqued skids and bumper and rear springs. drove around windows down radio off and the truck was stealth mode!
  15. Jan 25, 2013 at 1:43 PM
    #35
    Monster Coma
    Corey
    Haha I like it too but Id rather build my tacoma for cheaper than the $80k that was in that truck lol
  16. Jan 25, 2013 at 1:49 PM
    #36
    Cr250jumper
    The moon
    50 shades of tan©
    That is the key right there. I dont hate Raptors, but if you want a full size truck to perform like a LT Tacoma your going to spend at least double the money
  17. Jan 25, 2013 at 3:03 PM
    #37
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    Just to update you all, Serena's truck was sold about a week ago. BUT, we are building another double cab ecoboost raptor for someone now. He is also selling his 2012 Raptor that we have done all the suspension, bumpers, ect for a very good price given for what he has into it.
    BTW, we have a 2010 Tacoma in right now getting some TLC. Ex Lucas Oil pace truck as well as a Tundra we are building to ship over to Dubai.
    Now for comparing a LT Tacoma to a Raptor it's really 2 whole different animals. Ya you can have a LT truck to go play with cheaper with a Tacoma, but it still takes some time to get everything on, I think it's enough HP for a smaller truck, and love tacomas personally. But then on the other hand, That $50K price for the raptor your getting a warranty for a truck you can go play with after you drive it off the lot, then drive out of state with the family in it. Your getting a ton of comfort and power, more space, and the sky is the limit after that.
    Either way your gonna have a blast driving both.
  18. Jan 25, 2013 at 3:06 PM
    #38
    Monster Coma
    Corey
    Nice, you may not want to get into pricing here but Matt Farah made a comment that it was 10k to upgrade the eco boost but 20k to put an ecoboost in a raptor is that right?
  19. Jan 25, 2013 at 3:20 PM
    #39
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    Pretty much, mainly because the frame length is different for that extracab so there was a lot more labor involved. The double cab we are doing will be easier because the bed length and everything swaps over much easier, and a bit cheaper in the aspect labor wise. We also did the first one because it was one of a kind, and still is to this day. You will have a bit stronger trans and gearing with the Raptor start though. Once we get further along in the double cab we will have a much better aspect on costs.
  20. Jan 25, 2013 at 3:32 PM
    #40
    Monster Coma
    Corey
    Very cool, great work btw that truck looked awesome.
