Apex Overland Recovery Points
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChipsAHoy, Feb 19, 2024.
  1. Feb 19, 2024 at 9:45 PM
    ChipsAHoy
    ChipsAHoy [OP] Member
    Chad
    2022 Tacoma Sr (SX)
    Has anyone tried the Apex Overland recovery points? They seem to have a smilar design to the ARB but $100 less for a pair of them (driver + passenger side) as opposed to the single ARB point. I know the ARB is considered the best but over $300 is a little ridiculous. It looks like the Apex mounts to the sway bar bolts... I'm not sure if that would hold up the same as the ARB but it must be a lot better than the factory crossmember hook right?
  2. Feb 20, 2024 at 7:20 AM
    eurowner
    eurowner Duke Sky
    Scoty
    ARB designed their bumpers and recovery points to work with the crash engineered systems of the vehicles. No USA company does that at this time.
    For $300, the trust in ARB is worth it.
  3. Feb 20, 2024 at 8:03 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    You looking at them for your 4Runner or FJ? I don’t see any compatible with tacomas on their site.
  4. Feb 20, 2024 at 8:53 AM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Sway bar bolts?? Sounds sketchy
    K9tacoma and Chew like this.
  5. Feb 20, 2024 at 12:13 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    ARB is only $100 more……and it’s a PROVEN rock solid part. The decision is an easy one.
  6. Feb 20, 2024 at 1:32 PM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    They look plenty beefy, quality hardware and solid mounting, but I'm also not seeing Tacomas listed as compatible on their website. People act like the ARB is the only option, and I agree, $300 is a lot of money for something 99% of people will never use. If you do plan on using a recovery point a lot, ARB is well worth the money. It's either that, or spend the money on a proper bumper with recovery points, which is significantly more expensive.
    If these were for the Tacoma, I'm sure they'd be fine. Personally, I'd just invest in some quality soft shackles and a kinetic rope, and plan on hooking up to the lower control arms or something similarly beefy underneath that has no chance of letting loose and turning into a projectile. Seems to be all Matt's Offroad Recovery needs for most of his recovery jobs on vehicles with no proper recovery point.
  7. Feb 20, 2024 at 5:01 PM
    3rd gen AC SR5 4x4
    I got the ARB installed after using the tractor to pull chains from my LCA in the winter many times.
    So much easier with the ARB
    TacoGranny[QUOTED] likes this.
