Apexi afc neo air fuel controller universal
Discussion in 'Buy / Sell / Trade' started by streetcustoms, Nov 19, 2009.
  1. Nov 19, 2009 at 2:24 PM
    streetcustoms
    streetcustoms [OP] Well-Known Member
    tujunga , ca
    prerunner sr5 trd off road
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/74196-my-build-so-far.html
    CALL OR TEXT ANYTIME (818)606-1543
    BRAND NEW OUT OF BOX
    UNIVERSAL FIT
    SELLS FOR 450 BRAND NEW SELLING FOR 175
    ECU TUNING KIT
    ENGINE MANAGEMENT
    ~IN ONE~
    A'PEX introduces the first digital fuel computer that combines fuel computer functions with a VTEC engagement controller.
    The V-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points.
    The Fuel Adjustment function considers wide/narrow throttle and low/high camshaft settings, from which four different fuel maps are created (wide-low, wide-high, narrow-low, narrow-high).
    The integrated VTEC Controller adjusts the point at which the engine switches from the Lo to Hi cam during acceleration, as well as when the engine switches from the Hi to Lo cam during deceleration.
    Features:
    - Compact "Piggy-Back" Fuel Management Computer (+50% ~ -50%).
    - Unit incorporates both the SAFC and the VAFC.
    - NEW "Easy" (8-Point) & "Pro" (16 Point) Modes.
    - NEW Color FED Display & Interchangeable Button and Background Colors.
    - Inverting "anti-glare" screen allowing view from both angles.
    Monitor Mode: - RPM, Throttle, Battery Voltage, Correction %, Air Flow %, Pressure (Kpa), Karmann, VTEC
    Setting Mode: Air Map, Air Map Graph, Throttle Point, Deceleration Air, VTEC Control, VTEC Unmatch
    Etc. Mode: MOdel Select, Mode Select, Sensor Select, Analog Select, Warning Set, Display Set, Sensor Check
  2. Nov 19, 2009 at 2:33 PM
    streetcustoms
    tujunga , ca
    Located in tujunga ca 91042
  3. Nov 19, 2009 at 3:29 PM
    P-Dub
    P-Dub Well-Known Member
    Paul
    SF Bay Area
    06 Blue 4x4 TRD Sport DC LB
    TRD skid plate, OEM roof rack, OEM running boards, TruckCovers USA rolling tonneau cover, 3000K HID Foglights
    That looks purty! And a great price.
    I paid $250 for the first gen V-AFC for my civic a few years back and it was used.
    Do you also sell harnesses for different applications so I don't have to splice/tap any wires on my ECU?
  4. Nov 19, 2009 at 3:31 PM
    streetcustoms
    tujunga , ca
    it comes with everything it came with their is 2 plugs at the end of the wire
