Apparently Tacomas don't use rear brakes….
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rtilton12, Dec 7, 2022.
  1. Dec 7, 2022 at 4:24 PM
    rtilton12
    rtilton12 [OP] Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    got my rear shoes replaced and rotors turned about a month ago from the dealership. i noticed the rear brakes “grabbing” while braking almost immediately after i had left and took it back and explained while braking the truck bed shakes all crazy. they said it wasnt the rear brakes because theyre drums and tacomas dont use the rear brakes while braking which i think is complete BS. ITS NEVER DONE THIS BEFORE. they claimed they re surfaced one side and i was on my way. safe to say its doing it again and even worse than before, also making a loud squeaking sound from the RR drum while coming to a stop. taking it back tomorrow and going to have a manager ride with me. they also blamed the front brakes which are at 7mm and i changed them less than a year ago. ive had no issues with the rear brakes until now. i only serviced them cause they were recommended when i hit 100k miles.
  2. Dec 7, 2022 at 4:34 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Lift the rear and spin the tires. They should spin relatively freely. I suspect the adjusters need adjusting. With the wheels off you should only feel a very slight drag inside the drums, if any. I just did my rears and had the opposite effect - my adjusters were too loose and had to open them up a bit.
    An easier test - when you apply the parking brake, does it grab right away? If so, the adjusters are too opened.
  3. Dec 7, 2022 at 6:22 PM
    rtilton12
    Robert
    Texas
    yes sir grabs right away and they keep saying the truck doesnt utilize the rear brakes while stopping
    SR-71A likes this.
  4. Dec 7, 2022 at 6:26 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The front brakes do about 75-80% of the work, but the rear brakes do assist. Depending on how you drive you probably didn't need anything but an inspection at 100,000. I had new pads put on my rears at just under 200,000. The drums didn't need anything done to them.
    Something isn't adjusted right.
    SR-71A likes this.
  5. Dec 7, 2022 at 6:30 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Did they tell you what they ARE used for?:rofl:
    What a bunch of bs.
  6. Dec 7, 2022 at 6:35 PM
    Bishop84
    Bishop84 Well-Known Member
    Kinda hard to understand, do you think they are over adjusted?
    I just installed a new set today (at a dealer lol) and I adjusted them to about 6 clicks on the pull style ebrake. You can't really sense them working, you just get a firm pedal and they hold on steep hills with the brake engaged.
    You can't install tacoma shoes in the wrong direction, each shoe can only be installed one way. Maybe they messed up the hardware, or a spring is weak. Hopefully you get this fixed.
    PzTank and rtilton12[OP] like this.
  7. Dec 7, 2022 at 6:37 PM
    rtilton12
    Robert
    Texas
    they said used for parking brake only lol its even on the reciept they give you when u pay and leave
    PzTank[QUOTED] likes this.
  8. Dec 7, 2022 at 6:38 PM
    rtilton12
    Robert
    Texas
    yes, I totally agree with you. I’m pretty sure it is the hardware just because when I am breaking, it seems like the sound of those little springs that push the shoes apart are squeaking really loud and it’s definitely on the right rear wheel but I took it in a while ago and they said that it was the front brakes when clearly it’s the rear.
  9. Dec 7, 2022 at 6:41 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
  10. Dec 7, 2022 at 6:45 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    This was a Toyota Dealership?
    rtilton12[OP] likes this.
  11. Dec 7, 2022 at 6:46 PM
    rtilton12
    Robert
    Texas
    YES SIR. i used to work there years ago too.
    PzTank likes this.
  12. Dec 7, 2022 at 6:49 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Where the techs young?
    rtilton12[QUOTED][OP] likes this.
  13. Dec 7, 2022 at 6:53 PM
    rtilton12
    Robert
    Texas
    I honestly have no idea I never saw or met with them. I just had the great pleasure of dealing with an advisor that didnt seem to care
    PzTank likes this.
  14. Dec 7, 2022 at 6:55 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    You have to watch the service advisors to…they’ll try to use aftermarket stuff to make them more money… not saying they did that but you gotta watch them
  15. Dec 7, 2022 at 7:22 PM
    Chuy
    Lakeside, CA
    Silver Taco
    If the parking brake grabs by the 1st click, I strongly suspect the adjusters are too opened - meaning, they are spreading the shoes apart too much and need to be closed a couple clicks or so. The parking brake pedal should go down about 2-3 clicks, or about 1/3 of the way down; I would accept half way down. I am not 100% sure how the self adjusting mechanism works on the Tacomas; traditionally, brake shoes self adjust if the adjusters are closed too much, meaning if the shoes are too loose. But, they won't loosened if too tight except by wear/tear which would shorten their life, but could also overheat the rear brakes.
    PzTank likes this.
  16. Dec 7, 2022 at 8:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    They're blowing smoke. Somebody botched the drums on the lathe and it's causing a severe pulsation. Sounds like you've given them several chances to fix it and now they're making shit up. Next conversation is you bringing them a bill for reimbursement after you have a different shop fix it properly. It might need new drums
  17. Dec 7, 2022 at 8:16 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    When you load down the truck or hook up a trailer, the rear brakes do a lot more work than that.
    I would never let them touch my truck again after hearing them claim that “the rear brakes are for parking only” or some such hogshit.
    they probably botched the resurfacing which is suspect anyway. Do dealers have their own lathe? I would pay less for a new drum than for machine shop labor to get one resurfaced…
  18. Dec 7, 2022 at 8:17 PM
    TireFire
    Olympic Peninsula
    And them actually paying it is pure fantasy
    Kolter45 likes this.
  19. Dec 7, 2022 at 8:29 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    That is a load of BS. The technicians must have never worked on drums before as they probably only work on rear rotors in small cars or on newer tundras. The shoes on those are only for parking brakes.
    treyus30 and DG92071 like this.
  20. Dec 7, 2022 at 8:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    As soon as somebody start talking about resurfacing a drum I'm shaking my head. Either reuse it or replace it, it's not 1989 anymore.
    arbezee, Kolter45, scootter82 and 9 others like this.
