Apparently Tacomas don't use rear brakes….
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rtilton12, Dec 7, 2022.
  1. Dec 8, 2022 at 1:15 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I have had very good results with resurfaced rotors from Oreillys - on oem rotors and on good quality rotors like EBC. Resurfacing on cheap Wagner rotors only lasted two years before they began vibrating again. Oems have gone 70K+. The EBC’s in my Tacoma are only at 5K but they are good quality rotors and the tech guy that resurfaced them said the rotors, which had 70K, were still pretty thick. I’ve never had drums resurfaced but I am not too suspect of the OP’s, yet.
  2. Dec 8, 2022 at 2:33 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If they only changed the rear shoes and left the rear drums as is (you said rotors surfaced so I assume fronts on those) the drums are probably out of round or heat scarred so that may be your problem.
    They also have to recheck the springs back there as if original they may have broken one or it fell off (what a noise that creates contacting drum and backing plate). Then the parking brake cable pulls an adjuster strut lever that is usually rusted/frozen after 10 years so hope they freed it up and greased it. The correct way by the book to adjust is lock adjuster wheel clicking down till shoes locked on drums then back 15 clicks (not turns).
    I put a link to my recent rear brake replacement so you can see what is really back there when talking to the dealer or looking at yourself.
    Rear Brake Replacement Tips | Tacoma World
    DG92071 likes this.
  3. Dec 8, 2022 at 4:27 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    If the person your talking to doesn't know that the hydraulic line running to the rear brakes is connected to the same master cylinder that the hydraulic line running to your front brakes is, I think you are wasting your time talking to that person. Nothing constructive is going to come out of a conversation with a person who doesn't understand the basic principles of a braking system. Find someone at the dealer who knows how stuff works. If you used to work there, high probability you know who that person is or can easily find out.
    fb40dash5, Williston and DG92071 like this.
  4. Dec 8, 2022 at 9:28 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They are idiots if they are saying this.
  5. Dec 8, 2022 at 9:38 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    If your truck is like mine I'd then be asking why Tacoma has an ABS system.
    Williston likes this.
  6. Dec 8, 2022 at 10:13 AM
    DG92071
    DG92071 Well-Known Member
    Because everyone has money to throw away. (Sarcasm.)
    I don't see any connection between the current year and wasting money for absolutely no reason. If a drum is warped then yes replace it otherwise have it turned on a lathe (assuming it's not worn past its useable lifespan).
    HondaGM likes this.
  7. Dec 8, 2022 at 10:19 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    This is comical the rear def does work, but it's not overall. Have you checked the e-brake line? I have heard folks note that the line can sometimes stick and needs to be lubed or changed. Is it really cold where you are, and possibly you have a pad sticking?
    HondaGM and DG92071 like this.
  8. Dec 8, 2022 at 10:23 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    quick question...does it have pads and emergency brake shoes on the inside of the rotor?
  9. Dec 8, 2022 at 10:24 AM
    nudavinci64
    Robert
    Tacoma drums are braking and parking brakes.
    Cars with rear discs have a drum parking break inside the rotor.
    - Robert
  10. Dec 8, 2022 at 10:26 AM
    DG92071
    Excellent point. I had that issue after the last lift in the back. Ebrake line was binding. A simple slight re-route corrected the issue.
    HondaGM likes this.
  11. Dec 8, 2022 at 10:29 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Labor rates are going up. There comes a point where there's more value in just replacing with a fresh drum instead of wasting time at the lathe
    Kolter45, golfindia, Jimmyh and 2 others like this.
  12. Dec 8, 2022 at 10:32 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    oh ok...he said the shoes where parking brake only is what made me ask...
  13. Dec 8, 2022 at 11:44 AM
    nudavinci64
    Robert
    imagine a tacoma only having front brakes. like any other vehicle. Maybe time for a new dealer.
  14. Dec 8, 2022 at 11:47 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Its pretty brazen to respond with "oh, these trucks don't even use the rear brakes"
    It's like dude, I didn't ask if these trucks use the rear brakes. I asked why my truck is shaking like a mf every time I touch the brake pedal.. after you guys worked on it!
    Williston, Jimmyh and nudavinci64 like this.
  15. Dec 8, 2022 at 11:48 AM
    #35
    nudavinci64
    Robert
    well said
  16. Dec 8, 2022 at 11:53 AM
    #36
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I don't normally push for yelp reviews and stuff like that but that's the kind of response that higher up managers need to know about. Terrible service writing ..
  17. Dec 8, 2022 at 12:17 PM
    #37
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Yeah the cars that have rear rotors have small drums with no wheel cylinders in the center that are only for parking and ebrake. The small calipers do the braking.
    Our tacomas use drums with wheel cylinders for both braking and parking.
  18. Dec 8, 2022 at 12:19 PM
    #38
    nudavinci64
    Robert
    For anyone that has considered or or looking at it. The rear conversions and 4runners for example the rear discs are drum e breaks (smaller than stock but still drum). I have the SOS Big Brake rear disc setup on my truck now. and can say the rear def "brakes" the e brake is useless (so far at least)
  19. Dec 8, 2022 at 12:33 PM
    #39
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    This is true Especially for folks who don’t do the actual brake job themselves. After turning a rotor it’ll not have the same life span as before, same with drums because you’re removing metal from a heat sink.
    fb40dash5 likes this.
  20. Dec 8, 2022 at 12:36 PM
    #40
    TireFire
    Olympic Peninsula
    That’s the trade off with any rear disc setup pretty much. Much smaller drum and much smaller shoes to hold the car/truck. But most people don’t use the e-brake much anyway. I do on my Taco (unless it’s freezing outside) mainly to keep the shoes adjusted.
