Apple Qi charging concerns
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ctmedic, Apr 17, 2018.
  1. Apr 17, 2018 at 9:37 AM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Good point. Too bad I'm out of warranty period. I'll have to try it with wifey's phone.
  2. Apr 17, 2018 at 9:39 AM
    elistan
    elistan Active Member
    2017 TRD OffRoad V6 manual.
    I have not experienced that. Do you have a case on the phone and if so how thick is it? I've heard that thick cases produce enough distance between the components that charging is difficult, so I could see that causing overheating if it's trying too hard to compensate...
    (I did get flashing LEDs on the charger right after turning it one once when I had an iPhone 7 sitting on top of an iPhone 8 sitting on the charger...)
  3. Apr 17, 2018 at 9:44 AM
    WOTaco
    I have an extremely thin plastic case. I'll try it without but if I have to remove it every time I'll just plug it in.
  4. Apr 17, 2018 at 9:45 AM
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    Sales staff training... see below
    Most fail
    Herniator[QUOTED] likes this.
  5. Apr 17, 2018 at 9:58 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    I had this happen to me once so far this weekend. I was on a road trip, and had the phone (Samsung S7 in Ringke slimline case) on the Qi charger with the screen on and Google Maps running. The charge rate was just enough to keep the battery charge level essentially constant. After about a hour or so, the Qi charger started chiming sporadically. The first few times I heard the chime, I didn't know where it was coming from. After about another 10 minutes, the chime was going off constantly and the light on the Qi charger was alternating between amber and green. At that point, I took the phone off the charger and it was quite warm to the touch, but not any worse than charging the phone with a cable while it laying in direct sunlight. The charge level was around 55%, so the chime/lights were not due to the phone being fully charged.
    I let the phone cool down for a little bit and then put it on the Qi charger again with the screen off and it was fine for the rest of the trip.
    I think if I were to do this again, I would take the phone out of the case so that it can dissipate heat faster, or just use the cable. If I was using the phone simultaneously as a hotspot, nav aid and music player, the Qi charger probably wouldn't be able to keep up anyway. I'll have to try it out on the next road trip though, and see what happens.
  6. Apr 17, 2018 at 10:12 AM
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    My iPhone 8+ works fine. It needs to be positioned with the home button facing the driver side, with the phone ALL the way to the right rear of the charging pad. I've been using it for almost 6 months with no issues.
    Flash1034 likes this.
  7. Apr 17, 2018 at 10:30 AM
    WOTaco
    That's weird. Mine has never chimed, just both LEDs flashing. When I looked it up in the manual it didn't say anything about a chime.
  8. Apr 17, 2018 at 12:37 PM
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    I have a iPhone 8 with a tech21 case. I use my '17 Sport QI charger regularly on the road, and a Belkin BoostUP Charging Pad at home without any issues!
  9. Apr 17, 2018 at 1:24 PM
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    In my '16 with a Galaxy S8, after about 15 mins it beeps real loud and stops charging. When I take the phone off the charger its almost on fire.
  10. Apr 17, 2018 at 4:05 PM
    itrsteve
    itrsteve Well-Known Member
    NC
    18 LC/15 GT3
    I use mine all the time, unless I need a quicker charge, then it gets plugged in.
    I’ve had mine on the Qi pad on numerous three hour trips and nothing has caught on fire, not even once.
  11. Apr 17, 2018 at 8:40 PM
    pinem56
    NE
    2018 TRDOR DCSB AT
    It could have been the phone beeping. Difficult to say where the noise was coming from.
  12. Nov 9, 2018 at 8:35 PM
    thebadrouter
    thebadrouter New Member
    Wesley
    NSDC
    2018 MGM TRD OR
    I use mine consistently as well with an iPhone 8+
    No issues, and it charges fast enough considering I’m not exactly using my phone heavily while driving. I do consistently pull it out to change music since I usually listen to Spotify.
  13. Nov 9, 2018 at 9:02 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    No problems here with my iPhone 8 Plus.
  14. Nov 9, 2018 at 9:15 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    My wife has the X10, she says it doesn't work all that great, the wireless
    Tacoma charger. I have an SE iphone and I plug my phone into the deally...first time I really gave it any thought was just now. PS...had to ask the wife, just now, what phone she had...
  15. Nov 10, 2018 at 5:34 AM
    #35
    DESportTRD
    No issue with the iPhone 8. Prior to my 8, my iPhone 6 with a QI phone cover worked perfect also.
  16. Nov 10, 2018 at 5:53 AM
    #36
    Boricua
    Boricua Well-Known Member
    Jack
    2018 TRD Sport
    Im with you on this one, I have an iPhone X as well and use the Qi all the time with no hiccups and love it!
