Application of Fluid Film
Discussion in 'Technical Chat' started by BBYE V8, Jul 15, 2012.
  1. Apr 10, 2013 at 5:50 AM
    #41
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It gets black on a vehicle frame because it collects road grime. I sprayed my receiver and it's doing the same thing.
  2. Apr 10, 2013 at 10:06 AM
    #42
    burair
    burair Member
    I don't have access to an air compressor. Would any of those electric sprayers work for applying the undercoating?
  3. Apr 10, 2013 at 10:21 AM
    #43
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Just get the attachment wand and use with the spray cans in places you cant reach. That is what I am planning on doing.
  4. Apr 11, 2013 at 6:36 AM
    #44
    bob1008
    bob1008 Active Member
    Yes, just about any time of airless paint sprayer will work. Some better than others.... but I have not heard of any paint sprayer that will not work. The Wagner sprayers or Harbor Freight sprayers have all been reported to work well with Fluid Film. Fluid Film NAS formula is about the same viscosity as a latex paint. You can see the viscosity of NAS at the link below:
    http://www.kellsportproducts.com/nasviscosity.html
  5. Apr 11, 2013 at 6:48 AM
    #45
    bob1008
    What color is your receiver ? Fluid Film is solvent free so there is no evaporation process, which prevents it from getting sticky or tacky. You will get a light dusting on the outer surface, but it will not build up. I believe the frame pictures earlier in the thread were coated black. That is not from the Fluid Film.
  6. Apr 11, 2013 at 7:14 AM
    #46
    Pugga
    Massachusetts
    No, I wasn't implying that the Fluid Film turns black over time, but that road grime, brake dust, etc eventually seem to stick to the Fluid Film and make it look very dark. My receiver was orange and rusty when I applied the Fluid Film and now, quite a while later, it's back to a very dark color and if you touch where the Fluid Film was applied, all the dirt, grime, etc comes off leaving your finger black.
    I also coated a section of black iron propane line that sticks out of my house with the Fluid Film. Since that is not exposed to the same road spray, that application has not changed color at all.
  7. Apr 12, 2013 at 12:07 PM
    #47
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    How long before its rust protection wears off and it needs to be reapplied?
  8. Apr 13, 2013 at 4:35 AM
    #48
    bob1008
    FLUID FILM penetrates to the base metal, providing a lasting, protective barrier from the corrosive effects of salts, calcium and sodium chloride, pesticides and fertilizers. Offering an easy "no drip" application, FLUID FILM offers a cheaper and more effective alternative to the standard hard-underbody coatings. Protecting undercarriages from metal deterioration, FLUID FILM also remains soft and pliable, making it self-healing, non-drying, and impossible to crack. FLUID FILM migrates to inaccessible areas, providing up to a full year of solid protection.
    Many of our undercoating locations tell me that they treat their customers vehicles every Oct / Nov and it easily gets them through the season.
  9. Apr 13, 2013 at 4:54 AM
    #49
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    What's the best way to re apply? Spray on top or remove old layer? And if so how.
  10. Apr 15, 2013 at 3:58 PM
    #50
    BBYE V8
    BBYE V8 [OP] Please keep TW beautiful: search & stay on topic
    Brian
    StL, MO
    07 AC 4x4 2.7 5sp SR5
    It is straw or brown in color. But when thin it's pretty much transparent. What you see in the pictures I posted of freshly applied Fluid Film is the factory color of the Tacoma frame: black. If you look at the pictures of the coated floorboards, you will see they are silver (my truck is silver), with a slight brownish tint of the Fluid Film. Even after a year of driving floorboards did not turn black with any road grime; look at my recent pictures in the first post. After over a year of use: my silver floorboards are still silver, just a lot dirtier. BUT: if you rub your finger on mine, you will get a finger full of very dirty Fluid Film...almost as black as grease.
    I have had mine on for a year and 5 months; it's still on there but wearing thin on the parts of the frame that are closest to the road. A little surface rust is forming on the bolt heads. I wish I had done some touch up application after one year; I simply ran out of time before this past winter.
    I just plan on blasting the underside of the truck with the hose to clean off dirt, grime, gravel etc., that has collected over the year, then letting it dry a day and spray on a new coat of Fluid Film the same way I did the first time.
  11. Jun 6, 2013 at 7:15 PM
    #51
    amberger
    amberger New Member
    How many aerosol cans do you need to do a Tacoma?
  12. Jun 7, 2013 at 4:47 AM
    #52
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    If your willing to take your time and stretch the fluid film out you could do an entire truck with 2 cans.
    By "stretch out" I mean spraying a little and then spreading it out with a foam or bristle paint brush and spreading it all over for an even coat. A little bit of FF goes a long way, you will be surprised.
  13. Jun 10, 2013 at 1:59 PM
    #53
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Would this be a good thing to coat a set of coilovers with so the adjusting nuts stay free and dont seize? Also maybe it will protect the finish on the shocks?
  14. Jun 12, 2013 at 9:20 PM
    #54
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    That's what i have been doing for my coilovers, just don't apply too much or it'll attract too much dirt.
    How should i remove fluid film inside the front of the frame where it's boxed up?
    I already applied fluid film in there but i want to apply the eastwood internal frame coating as i have some light surface rust inside the frame, then spray some fluid film again.
  15. Jun 12, 2013 at 9:29 PM
    #55
    Recker
    Recker Well-Known Member
    Recker
    Indiana
    07 Tacoma 4x4 Indigo Ink Pearl
    Needs whoring LOL
    Awesome, I'm getting some!! Thanks OP
  16. Jul 28, 2013 at 4:12 PM
    #56
    MACHINE
    MACHINE Well-Known Member
    Canada
    TRD Sport
    Just about to purchase this..Is the stuff in the aerosol can the same as the gallon jug? The stuff out of the OP's gallon container looks thick can't imagine it coming out with aerosol that thick..
  17. Jul 28, 2013 at 9:05 PM
    #57
    BBYE V8
    Brian
    StL, MO
    I never thought much about how to remove this stuff. I'm sure lots of degreasers will work with the help of a brush, but you can't brush inside the boxed section of the frame. Try brake parts cleaner, it's one of the most effective degreasers I know of. But I don't think even that will remove Fluid Film completely.
    Same stuff different viscosity. The Fluid Film "NAS" that comes in buckets is thicker than the aerosol. I think the aresol cans are the easiest to use, the jugs are the most cost effective.
  18. Jul 29, 2013 at 12:14 PM
    #58
    MACHINE
    Canada
    TRD Sport
    Thanks, I am going to give it a try.
  19. Jul 30, 2013 at 5:44 AM
    #59
    bob1008
    Below is a link for Fluid Film removal instructions.
    "Fluid Film can also be removed by warm water detergent wash or with a commercial-grade biodegradable cleaner. When choosing a cleaner, one formulated to remove tough grease and grime deposits is advised."
    http://www.kellsportproducts.com/removefluidfilm.html
  20. Jul 30, 2013 at 5:48 AM
    #60
    bob1008
    Below is a link to a description of the many Fluid FIlm formulas:
    Fluid Film Aerosol Spray "AS"
    "When Fluid Film NAS is combined with a propellent and put in a spray can, it becomes Fluid Film "AS" "NAS" and "AS" are the same. "
    http://www.kellsportproducts.com/fluidfilmformulas.html
