Applying bulb grease to my 2005 Tacoma taillight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JLK77, Dec 8, 2022.
  1. Dec 8, 2022 at 11:52 AM
    JLK77
    JLK77 [OP] Member
    2005 Toyota tacoma
    Hi,
    I'm wondering if anyone can tell me how and where to apply this bulb grease? My taillight keeps blowing.
  2. Dec 8, 2022 at 11:54 AM
    Tacospike
    Two Trucks
    Dielectric grease? at the electrical connections (plugs)
  3. Dec 8, 2022 at 12:12 PM
    JLK77
    JLK77 [OP] Member
    2005 Toyota tacoma
    Yes it's the dielectric grease. Thanks I'm just a little confused, it says not to put it on metal so I was just trying to clarify exactly where to put it.
  4. Dec 8, 2022 at 12:19 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    It's really not necessary......I've never done it anyways lol. But it needs to go on the connection/contact points....which is most likely metal...
  5. Dec 8, 2022 at 12:31 PM
    JLK77
    JLK77 [OP] Member
    2005 Toyota tacoma
    My taillight keeps blowing and this was one of the troubleshooting methods to stop it.
    I know nothing about trucks or cars and my dad gave me his Tacoma but it's pretty beat up. I'm dyi-ing all the things I can because, like the rest of us, I can't afford to bring it to the shop.
    ToyoTaco25 likes this.
  6. Dec 8, 2022 at 12:39 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    When does it blow? When you turn it on, or when you turn it on with the parking lights on what initiates that bulb to blow is it just by clicking on the blinker switch and is it just one side?
  7. Dec 8, 2022 at 12:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I applied a light coat. Like just a dab and smear to the wire terminals on the bulb.
    The socket for the bulb uses a gasket so you “shouldn’t” need the grease. But I still can’t help my self to use it.
    The grease isn’t likely to resolve your problem. Unfortunately.
    b_r_o, Too Stroked and Chuy like this.
  8. Dec 8, 2022 at 12:52 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    SR-71A and TnShooter like this.
  9. Dec 9, 2022 at 6:06 AM
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    Pull the taillight assembly out and make sure none of the wiring has worn through and is grounding. Then make sure the actual ground for the taillights is still solid. Disconnect that ground and clean it.
    winkel likes this.
  10. Dec 9, 2022 at 6:17 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    ^^^^ This. I live in the rust belt, and we use Dielectric grease to prevent corrosion in the socket and on the bulbs. Even a small amount of condensation in that area will accelerate corrosion. And once it starts, that connection is forever toast.
    As for your taillight bulbs continuously blowing, that's most likely a separate problem.
  11. Dec 29, 2022 at 1:30 AM
    JLK77
    JLK77 [OP] Member
    2005 Toyota tacoma
    I'm sorry guys I forgot to update you gentlemen on my light bulb issue. Ok, so the dielectric grease I bought was for bulbs specifically. So I'm assuming that people do use it on taillight bulbs.
    But fortunately, after reading most of the comments, I went back to the truck pulled the taillight assembly out again and noticed that the bulb on the working side had a different colored bulb on the top and on the side that kept blowing had the same clear bulb on the top and bottom. So I went back to the auto parts store and found out that the yellowish-colored light bulb (which is for the blinker) was what I was supposed to be using in the top part of the taillight.
    I replaced the bulb with the yellow one and I haven't had a problem since.
    Now that little tiny light bulb that lights up the shifter panel, that's a whole other animal. Lol.
    Leomania, winkel and JGO like this.
  12. Dec 29, 2022 at 4:18 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Everybody STOP about the grease!
    Ignore the grease, this dude has a short circuit. LoL
    Oh, when does the bulb blow? While driving, while braking, while the truck isn't even on?
    Details...
    Update- LMFAO, nevermind, he was just using the wrong bulb...
    jackn7 likes this.
  13. Dec 29, 2022 at 4:23 AM
    JLK77
    JLK77 [OP] Member
    2005 Toyota tacoma
    Ummm I'm a female. Lol. That probably explains a lot huh?
    shmn and Jimmyh like this.
  14. Dec 29, 2022 at 6:34 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    My 2014 had its LH headlight replaced (broken plastic brackets) and my neighbor asked why it had a different shade of Amber light than the other side. Much more of a light yellow. Pulled the two bulbs for a look and the numbers didn't match. The number on the new assembly (supposedly Toyota) matched what the auto parts stores listed as a replacement ..... but I found that the "real" replacement should have the exact same number as the RH ....... 3157NAK. Turns out the "K" suffix shows the internal gas is Krypton and the bulb runs cooler for use in the "driving light" service.
    Not all amber lamps are created equal........
  15. Dec 29, 2022 at 8:10 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Probably the biggest mistake you made on the forum lol! Announcing you’re a female…good luck!
    winkel likes this.
  16. Dec 29, 2022 at 9:16 AM
    TnShooter
    Deogee
    STOCK
    No. Women are just as capable as men.
    And probably better in a lot of instances.
  17. Dec 29, 2022 at 1:06 PM
    TegoTaco
    Ontario, Canada
    Nope had nothing to do with that. My wife is actually pretty hands on with her car and around the house.
    I’ve noticed over the years whenever there is a female announced on any forum…thirsty guys go crazy messaging and flirting with them lol!
    jackn7 and TnShooter[QUOTED] like this.
  18. Dec 29, 2022 at 1:09 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you figured it out..so i would say your pretty smart..
    you go Girl
    TnShooter and TegoTaco like this.
  19. Dec 29, 2022 at 9:24 PM
    Chuy
    Lakeside, CA
    Silver Taco
    The clear bulb wouldn't be the reason for the blow outs. The yellow/orange one is basically a painted white one. You either had bad bulbs or you have a bad connection.
  20. Dec 30, 2022 at 5:56 AM
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
    Seeing "bulb grease" in the title reminded me that I need to top off my "blinker fluid." :D
    FishaRnekEd, McPickle and jackn7 like this.
