Apprehensive to put anything other than Toyota parts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nofear18, Mar 22, 2023.
  1. Mar 22, 2023 at 2:40 PM
    Nofear18
    Nofear18 [OP] Member
    Alain
    23 TRD Off Road blue crush
    Ok here is my problem and maybe you guys can help. I bought a Toyota because I don't want to worry about it. I paid for the quality ( Hopefully) . I want to do mods on it, but for some strange reason, I am really apprehensive to put anything other than Toyota parts. Had a pedal commander but sent it back after hearing a FEW people have issues with it. Had a rough country cold air intake and sent it back cuz it's not Toyota. Does anyone have really GOOD experiences with stuff that you feel confident I won't have any issues with? Obviously there's no guarantee. Also, what lift kit out there comes closest to the TRD in? Thanks
  2. Mar 22, 2023 at 2:44 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome, leave it stock. You'll be happier.;)
  3. Mar 22, 2023 at 2:59 PM
    burgershot
    burgershot Well-Known Member
    Avoid rough country
  4. Mar 22, 2023 at 3:15 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    I have rough country seat covers but nothing else.
    98_3RZ_NIC, BMH, musicisevil and 3 others like this.
  5. Mar 22, 2023 at 3:23 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The TRD kit is just a Bilstein 5100 kit with TRD stickers... does that still make it factory at a cheaper price...
    Also lots of parts on your truck are made by aftermarket companies to Toyota's specs. Technically your vehicle is partially built by the aftermarket. Do your research and buy once and cry once. If you are happy with the way your truck is stock then modifications just got nice and cheap.
  6. Mar 22, 2023 at 3:23 PM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    Speaker upgrade was a no brainer and I been smiling ever since.
  7. Mar 22, 2023 at 3:25 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Mod according to your needs. Most of the foofoo crap out there is not needed for every day use.
    I can attest the meso stage 1 LED tail light kit is the best thought out quality product i have added. Aside from running boards I made my mods such as bed rack and bed stiffies.
    Like you i lke the taco for what it is.
  8. Mar 22, 2023 at 3:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol you paid zero extra for Toyota quality as the Tacomas cost in the same range as the Jeeps and Rangers and Nissans of the world.
    Mine is stock for a reason.;)
  9. Mar 22, 2023 at 3:35 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    If repairing/replacing parts - go with oem. The aftermarket stuff is hit and miss on the quality.
  10. Mar 22, 2023 at 3:57 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    In my opinion, good thing you sent that useless stuff back.
  11. Mar 22, 2023 at 4:01 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Exactly that. Many will chime in about making your truck more you etc and not being a "stock pussy" but at the end of the day. Millions/billions were spent on making it what it is... You can bedazzle it a bit with things like tonneau covers and maybe different speakers and tires. But there is always some sort of trade off.
    hiPSI, tcjacado[QUOTED] and Stevie17 like this.
  12. Mar 22, 2023 at 4:21 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Leave it alone. I say that not against modding at all, but I’m very particular about what I’ll allow to be changed at this point. A pedal commander, other than some throttle response, can only really cause issues. The RC “intake” is absolutely worthless and serves no purpose whatsoever, so once again there is no point to it either. Toyota has tons of resources to design an intake that works….there is no way a few guys in the conference room at rough country can cobble up a better intake and sell it for only a few hundred bucks. It helps to realize that the 5.7L tundra motor uses the same air filter as us…that alone should tell you enough about the stock setup for your 3.5L.
    I am picky about modding things that actually affect the truck. I am more of an add-on guy these days, be it lights, tonneau, bed mat, etc. sometimes I’ll get creative and do something permanent but vast majority of the time, no. It mostly comes down to lessons learned on other vehicles. If you change something (intended to be a permanent change), and there’s any chance you regret that change, you’ll be pissed when you’re later reverting back to stock. I’ve been through this about a million times on my Jeep: stock parts are typically well designed and better than most anything aftermarket. There are a few exceptions but that’s it.
    With the way you describe yourself, just leave it alone and only add on things that will be a real improvement.
    RustyGreen and 22Coma6MT like this.
  13. Mar 22, 2023 at 4:21 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    If you want to do a few cosmetic things to make it your own, then go for it. But I personally would do what others have said and leave the rest of the truck stock. Your TRD Off Road is quite capable as is!
  14. Mar 22, 2023 at 5:12 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    You can always mod with Toyota parts. There are a lot of accessories and "performance" parts available through Toyota.
  15. Mar 22, 2023 at 5:56 PM
    Nofear18
    Alain
    Ok the one thing that I would like to do is level (not lift) the truck. Any thoughts?
  16. Mar 22, 2023 at 6:12 PM
    Vlady
    Issy, WA
    Tacoma's rear is weak and sags noticeable after loading with a few 100 pounds. If this isn't bothering you, any adjustable ride hight shocks and a block. Otherwise, may need to figure out the rear and match the front.
    ..and the depth of your pocket
    ..and do it once.
  17. Mar 22, 2023 at 6:16 PM
    Kidlin
    Kidlin Well-Known Member
    2021 SR5 DCSB Cement
    Leave it alone. It’s a great truck stock. If you want to do few mods/customizations that won’t cause any headaches get a bed mat, some black out emblem overlays, your favorite tire and some seat covers.
    kahanabob likes this.
  18. Mar 22, 2023 at 6:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you level it, it will be unlevel as soon as you put 50 lbs in the back and then you will have a squatted truck. The rake is there so when you load it it will level. It's a truck man. All trucks have a rake for loading .
    Get a bed mat. Get some stickers.
    Unicorn stickers are popular on Tacomas.
    RustyGreen and davidstacoma like this.
  19. Mar 22, 2023 at 6:55 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    With a few exceptions, Toyota branded accessories are just rebranded/licensed aftermarket parts that pad the dealers profit margin. You're paying for the logo and not much else.
    I'll say this, I love my Toyota, but I'm also fascinated by this almost cult-like stance that invoking the very name somehow magically wards against breakdowns. It's a solid truck. And there's a thriving industry made up of many enthusiasts, who in turn make many solid products.
    Do what you want with yours. Leave it stock, or modify it to your specific usage, or make your creditors happy and go on a buck wild blind mod spree. It's y'all's truck. As long as you're enjoying yours, then you're doing it right.
  20. Mar 22, 2023 at 6:56 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Mod the tires, then wait a year to decide what’s next.
    hiPSI likes this.
