APR 4.0 Fuel Rail Upgrade Kit
Discussion in 'Performance and Tuning' started by Torspd, Mar 30, 2012.
  1. Mar 30, 2012 at 11:14 AM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Here are the stats from APR, for their fuel rail.
    APR 4.0L Toyota Fuel Rails
    APR Fuel Rail kits are high-performance fuel delivery system that is designed to properly
    supply the additional fuel needed for high boost/performance applications. The kit can be
    ordered in various stages from rails only to a fully assembled set of rails with a high flow
    adjustable regulator that will support our massive 386L in-tank fuel pump.
    These kits are direct bolt-on replacements of factory fuel rails, complete kits include all
    stainless steel braded hoses and AN factory style quick disconnects for quick and easy
    installation. Utilizes the factory fuel dampener to prevent unwanted pulsation pressures,
    there are two 1/8” female pipe taps for pressure transducers, gauges or additional fueling
    devices. APR Fuel Rails are machined out of aluminum and are hard black anodized for
    protection.
    The 4.0L fuel rails are offered in 5 different configurations:
    1) $389 Fuel Rails Only – includes all mounting hardware and four -6AN rail end fittings
    2) $569 Complete Fuel Rails less regulator – includes all parts needed to assemble and install (less regulator)
    3) $689 Complete Fuel Rails – includes regulator and everything needed to assemble and install
    4) $749 Assembled Fuel Rails - SS hoses are cut and assembled, includes regulator and everything needed to install
    5) $928 Assembled Fuel Rails and 386L pump
  2. Mar 30, 2012 at 11:27 AM
    Torspd
    Tor
    The Great America!
    I will be getting mine next week. WOOT!
  3. Mar 30, 2012 at 9:17 PM
    toon714
    toon714 Well-Known Member
    toon
    So. Cali to H-town
    2010 turbo lowered prerunner
    garret Gt 35R front mount turbo, TR lowering kit, Work wheels, all the go fast goodies!
    get me one! ;)
  4. Mar 30, 2012 at 11:41 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Work of art.....
    Toons, that signature rocks BTW.
  5. Mar 31, 2012 at 1:43 PM
    Torspd
    Tor
    The Great America!
    Get boost, and make a reason! :D
  6. Mar 31, 2012 at 1:46 PM
    Torspd
    Tor
    The Great America!
    Put it on the car. Win win!
  7. Mar 31, 2012 at 1:48 PM
    Torspd
    Tor
    The Great America!
    I need to meet that chick! :D.
  8. Mar 31, 2012 at 1:50 PM
    Torspd
    Tor
    The Great America!
    I see the problem. I have a strong feeling that there is one on the market already for what you have then. ;)
  9. Apr 1, 2012 at 11:50 AM
    toon714
    toon
    So. Cali to H-town
    hahaha. ya thats the best sig i got. :p
  10. Apr 4, 2012 at 3:55 PM
    Torspd
    Tor
    The Great America!
    Ordered mine today. Should have it sometime next week. Woot!
  11. Apr 8, 2012 at 6:38 PM
    ModernPopeye
    ModernPopeye Well-Known Member
    Hampton Rds,Va
    12 DBL Cb Sport LB
    I've bought the TRD Supercharger for my 12 (awaiting fit kit & other parts) and I'm pretty sure I'll be going with the UCON EMS. That being said what's the difference from this kit and the URD fuel pump upgrade "kit". Pro's and con's of this as opposed to the URD one. Thanks for your insight.
  12. Apr 9, 2012 at 6:27 AM
    Torspd
    Tor
    The Great America!
    The fuel pump kit from URD is the Walbro 255lph fuel pump, and external fuel filter.
    It is not the Walbro 255 HP (High pressure), which can handle larger increased fuel pressures. It is to quite simply supply the extra fueling needed when adding boost, due to the fact that the factory fuel pump will cause a high rpm lean condition. One, due to it being small, and two, because the factory fuel system is not one that increases. It is always static.
    It is also a great upgrade for when your factory fuel filter gets clogged, and it needs to be replaced. Spend ~$500 at the dealer, or $150 for the URD kit.
    The APR fuel rail is for those that either really want it, and or are pushing their limits of the factory fuel system. It is larger, so it has more volume.
    Factory injectors, as well as aftermarket injectors will work with it the same. It was CNC'd specifically for the 1GR engine. It uses the factory fuel damper, to prevent fuel oscillations.
    The pump that you can get with the kit, or separately through them, is one that can handle rising fuel pressures. And it is even much larger than the Walbro 255, so it can supply a much greater volume of fuel. The 1:1 risinig fuel pressure regulator means that as you increase in each psi of boost, then so will your fuel pressure by the same psi. Higher psi means that your fuel atomizes better, as well as increases the "effective flow rate" of the Injector you have. Meaning that it becomes a larger Injector as the fuel pressure increases.
    So the fuel rail kit, is a performance upgrade to the fueling system at the front end of the vehicle, minus external filter(which yiu can easily add in), and the URD upgrade kit is for improving the factory pump/filter at a very reasonable cost, while also making you safe for boost.
    The Walbro in the URD kit will start fluctuating at 12+ psi increased fuel pressure over stock, of our 43.5 psi. Tested and datalogged by me. The 385 is a high pressure unit meant to handle high fuel pressures, and will not have that problem.
    One other note, I do not know of what the factory fuel rail is designed to handle, as far as psi. Not telling when it could pop at increased pressures.
    I hope all of that helps. If there are more questions, I will do my best to answer.
  13. Apr 10, 2012 at 7:52 AM
    ModernPopeye
    Hampton Rds,Va
    12 DBL Cb Sport LB
    Thank you very much Torspd ! That's exactly what I was looking for. It's nice to have someone that shares their experience and knowledge on here. Rep sent!
  14. Apr 10, 2012 at 10:32 AM
    Torspd
    Tor
    The Great America!
    You are very welcome my friend. :thumbsup:
    That is what these forums are for though right? ;)
  15. Apr 10, 2012 at 11:07 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I'm getting mine very soon as well as ID 1000 injectors. I'll more than likely upgrade the pump down the road. :D
  16. Apr 24, 2012 at 4:52 AM
    ModernPopeye
    Hampton Rds,Va
    12 DBL Cb Sport LB
    A little late for my response time, eh? You're exactly right. If you need to know anything about a PWC,ATV, or motorcycle let me know lol.
  17. Jan 11, 2013 at 7:41 AM
    Torspd
    Tor
    The Great America!
    Still haven't installed mine, but here is my latest fuel rail update.
    All Aeromotive fittings because of their smooth internal transitions.
  18. Jan 11, 2013 at 7:50 AM
    Torspd
    Tor
    The Great America!
    Forgot to mention. Dezod is currently feeling out if others might be interested in a similar fuel rail. Since this particular one is no longer made.
  19. Jan 28, 2013 at 12:24 AM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    count me in, Im interested
  20. Feb 1, 2013 at 10:34 PM
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
