APR X-1 Launch Control
Discussion in 'Performance and Tuning' started by XrunnIT, Feb 15, 2009.
  1. Feb 15, 2009 at 6:57 AM
    XrunnIT
    XrunnIT [OP] Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
  2. Feb 15, 2009 at 8:22 AM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Out Frickin Standing:D
  3. Feb 15, 2009 at 8:34 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    0-60... 5sec? Dammmn
  4. Feb 15, 2009 at 8:37 AM
    Snyperx
    Snyperx Seniore Marcos
    What was done to the engine cause that thing sure as hell didn't sound stock to me.
  5. Feb 15, 2009 at 8:56 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Don't worry.. its faster then that. Right now the LC (launch control) is still choking the motor. I'm still tuning it, once its done, I hope to have the 0-60 in about 4.5-4.9 seconds (the truck is capable of it).
    TRD boosted, as seen in the beginning only 6psi of boost right now, plan on running 10psi when all is said and done.... :biggrin:
  6. Feb 15, 2009 at 9:03 AM
    dually
    dually Low and slow
    I will only dream of running 13s @ 10psi with my turbo setup!
  7. Feb 15, 2009 at 9:07 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    10psi, with good driving you should be able to hit 13's them first gen tacos are light, especially the 4cyl.
    I should be mid 12's at 10psi of boost. :burnrubber:
  8. Feb 15, 2009 at 9:12 AM
    dually
    dually Low and slow
    Schweeeet!
  9. Feb 22, 2009 at 10:21 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    just out of curiosity what made you go with the apr X-1 over urd
  10. Feb 22, 2009 at 3:21 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    what do you mean? Over a URD maf cal or AIC?
  11. Feb 23, 2009 at 12:41 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    why did he go with the x-1 versus urds map-ecu2?
    I'm curious what the x-1 has over the map-ecu2 as its almost double the price.
  12. Feb 23, 2009 at 1:06 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    sexy, how did u fight axle wrap at such high accelerations? Is there something about the X-runner's rear suspension that I dont know about? Or did u just weight down the bed? get stiffer springs? Thanks! I love your truck
  13. Feb 23, 2009 at 2:18 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
  14. Feb 23, 2009 at 3:54 AM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    damn! im jealous :(
  15. Feb 23, 2009 at 7:57 AM
    roxspin72
    NC
    Oh Yeah!!!
  16. Feb 23, 2009 at 9:03 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    The X-1 is superior over the ME2. The X-1 comes with exhaust timing gears and 170* t-stat for one (can't get those with the ME2). It also houses bonus programs that you can't get with the ME2 - Launch Control and Engine Guardian (a fail safe mode when it detects issues with the fuel delivery).
    It is also plug and play out of the box, you don't need to spend an additional $300 for a harness like the ME2. The APR X-1 was designed SPECIFICALLY for the 1GR ECU, where as the ME2 is a universal one. So you are going to have a lot more control over the ECU.
    I've swapped the factory leafs with the Sittin Sic composite drop leafs (higher load capacity then stock), and i'm currently running some slapper bars to help with the hop.
    Well there ya go, some more features unique to the X-1. :thumbsup:
  17. Jun 1, 2009 at 6:03 PM
    kris219
    kris219 Well-Known Member
    Kris
    miami
    tacoma trd
    spindle lift with dakar leaf pack, blacked out headlights and tailights, satoshi, debadged, HID headlights n fogs, flowmaster 40 single in dual out
    is the apr x-1 easy for an inexperienced person to use?
  18. Jun 1, 2009 at 6:31 PM
    jaxchrisfla
    flooriduh
    lots
    its not to bad. basic things like air fuel ratio are pretty simple to change. but you need a understanding at what your looking at, and what your looking to do.
  19. Jun 2, 2009 at 6:26 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Yes. X-1 install is cake, plug-n-play. Cam gears are a sensitive install. But the X-1 comes pre-loaded with a map, and is self tuning for new mods. So once its installed, you don't really ever have to do anything with it again if you don't want to (unless you do a major upgrade like boost).
  20. Mar 26, 2010 at 6:11 PM
    09TRD
    09TRD it is what it is
    Oakwood GA
    09 TRD Off Road
    Not yet,
    I want mine to do that....... lol
