APR X-One Engine Controller
Discussion in 'Performance and Tuning' started by Chopperness, Sep 6, 2010.
  1. Sep 6, 2010 at 7:35 PM
    Chopperness
    Chopperness [OP] Active Member
    I am considering purchasing some sort of controller or calibrator but not sure what to get. I have intake and exhaust with plans to get headers. I know there are other cheaper products out there but I like to have the best. Would this product be worth it? How easy/hard is it to tune? I don't know anything about tuning but I think I could figure it all out with a little direction.
  2. Sep 6, 2010 at 7:40 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    The X1 is the best option for aftermarket engine management for the 1GR.
    It is a fully adaptive controller that will "learn" much like the factory ECU will. You don't have to "tune" it like other controllers. You get up with APR or URD and they will setup a map for you, and the ecu will make fine adjustments as conditions change.
    It is a nice add on for a modded N/A setup but really flexes its muscles on FI setups
    If you ever plan to add a S/C you wont have to reflash because the X1 can handle it and the blower can come back off if you sell or trade
    Contact Gadget at URD and he can give you the full scoop
    Justin
  3. Sep 6, 2010 at 7:58 PM
    Chopperness
    Thanks for the great info. As of now I don't plan on a s/c, bit I'm not counting that out.
  4. Sep 7, 2010 at 6:51 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not sure what you have, but the X-1 still does not support 09+.
  5. Sep 7, 2010 at 7:37 AM
    Chopperness
  6. Sep 7, 2010 at 9:12 AM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    It makes driving your tacoma feel like it should have been out the factory..
    If you got the cash, it is a must buy.
    Also, Tech support from APR and URD is outstanding.
  7. Sep 7, 2010 at 12:50 PM
    Chopperness
    Sounds great, what is the installation like?
  8. Sep 7, 2010 at 1:56 PM
    roxspin72
    NC
    Oh Yeah!!!
    But not bad at all... Hardest part is the cam gears. But, the instructions on APR's website are awesome. Take your time and it's totally do:cool:able
  9. Sep 7, 2010 at 2:00 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    if i had the 1grfe id stop saving for a lift tires and bumper and buy an apr :(
  10. Sep 7, 2010 at 3:24 PM
    Chopperness
    What are the cam gears for? Do you really need to install them?
  11. Sep 7, 2010 at 6:54 PM
    roxspin72
    NC
    Oh Yeah!!!
    They retard the cam timing, and most importantly the XTune Calibration file is dependant upon the cam gears.
    Read this link, it tells it all:
    http://www.xr-underground.com/forum/showthread.php?t=38009
  12. Sep 8, 2010 at 11:04 AM
    Chopperness
    after looking at that site, I am sure glad I looked into things first, but I always do. Looks like I will be tearing into the manifold soon enough.
    One more Q? What's with the new thermostat?
  13. Sep 8, 2010 at 12:14 PM
    roxspin72
    NC
    Oh Yeah!!!
    Its a 170 or 180 deg thermostat. Cooler temps allow for better performance. The APR site has this information broken down by parts:
    http://www.aprpower.com/ECU_mainpage.html
    Enjoy...
  14. Sep 24, 2010 at 10:05 AM
    scott20054
    scott20054 Active Member
    tuned TRD supercharged taco
    TRD Supercharger, IPT High Performance Transmission, DTLT long headers, APR X-1 tuner, Full fiberglass body, E85 injectors, APR 7th injector, Walbro 255 fuel pump, Pulstar Performance Series Spark Plugs, 2.7" pulley, Flexalite Electric Cooling Fan, Cooler Thermostat System, Timing gears, Pro Comp Traction Bars, K&N Cold Air Intake, Airaid PowerAid Throttle Body Spacer, Aero Turbine 2525 with custom piping true duals, Grillcraft MX Series upper and lower grill, Redline Tuning Hood QuickLIFT ELITE, 20% tint front, 5% tint back, tinted headlights, tail lights, fog lights, and mirrors, Debadged, ... So YES this truck is "STOCK" ;D
    hey jw but what is that price range your looking at for one? i have a trd s/c and a unichip but i'm losing the unichip and gunna get this but work is the price range?
