Aquarium Hobbyists
Discussion in 'Pets' started by mrbee2828, Jun 26, 2012.
  1. Apr 4, 2024 at 5:01 PM
    #521
    Kwikvette
    Fresno County
    4 run, 2 don't
    Definitely fun!
    Just got done testing an hour ago as this would be 6hrs after having added ammonia.
    I'm at around 1ppm now already down from 2ppm this morning.
    Nitrites and nitrates still at 0ppm (as expected)
    And since I had tested for pH levels, I'm at what looks like 7.4
    ssd_dan and Rock Lobster[QUOTED] like this.
  2. Apr 8, 2024 at 11:16 AM
    #522
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, a few things to add to this thread
    My water hardness test arrived so I was finally able to test that. Did it twice to confirm and the results were
    5 kh
    6 gh
    Those parameters tell me I'm set to house anything really
    I won't bore anyone with each test result as I did two daily but today's was a tad different because I am finally above 0ppm as far as nitrites go
    Little hard to see, but in person it's a real light lavender compared to the light blue I've seen day in and day out
    For just a few days, I think that's rather quick already
    Ph levels still coming in at 7.4, and my plants are beginning to melt (as expected) so I'm happy to say things are moving along as necessary!
    Rock Lobster likes this.
  3. Apr 10, 2024 at 2:00 PM
    #523
    Kwikvette
    Fresno County
    4 run, 2 don't
    She's progressing pretty quickly :cool:
    JKU3000 likes this.
  4. Apr 11, 2024 at 8:49 AM
    #524
    Kwikvette
    Fresno County
    4 run, 2 don't
    And last night, a sudden change (for the better)
    Ammonia had moved up to and hovered at 2ppm for the last few days, however today it seems to be dropping again as it looks closer to 1ppm
    Nitrite levels almost quadrupled to 2ppm
    And nitrate levels are real close to 10ppm
    Blame the climate-controlled house with great insulation, or the great water from the tap lol but these numbers are great for only being on day 9 today.
  5. Apr 13, 2024 at 4:35 PM
    #525
    Kwikvette
    Fresno County
    4 run, 2 don't
    The latest, added two more plants and another ornament
    Two java ferns, one anubias, and two ludwigia sp live plants -
    Ammonia drops pretty fast, so waiting to see nitrites drop as quickly but everything is moving as expected!
  6. Apr 26, 2024 at 10:54 AM
    #526
    Kwikvette
    Fresno County
    4 run, 2 don't
    The Anubias Congensis had slightly yellowed, and shortly got back to green which suggests it was simply acclimating
    Microsorum Pteropus gained a little bit of browning/black (doesn't rub off) but hasn't changed since
    The Ludwigia have shot out tons of adventitious roots (more noticeable on those on the right side of the castle)
    Recently added is the Vallisneria so it's looking a little yellow at the moment, same with the Mayaca Vandelli
    And we'll see how well the Phyllanthus Fluitans do seeing as how I'm running a lid on my setup
    Nitrites are consistently below 0.25ppm, and even with dosing 2ppm of ammonia daily, it gets converted to nearly 0 within 12 hours
    With as heavily planted as I am, nitrates can't even reach 5ppm
    Had I not dosed ammonia this morning, I could've gone out and added some livestock already so I might go shop around today and do a pick up for tomorrow
  7. Apr 26, 2024 at 3:52 PM
    #527
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Looking good! I was wondering when we would hear another update. I've only got one anubias nana that I moved from my small 20g tank to the bigger one. It's got some more room to grow now. I had never done plants and read that this one was pretty easy. It's got some ugly leaves and some healthy ones, but I get that slime algae that covers them and I need to clean off the leaves more regularly.
    My lights died so I just got a Hygger brand one that has a 24 hour mode that seems pretty cool. Hopefully better for the plants!
    Kwikvette[QUOTED] likes this.
  8. Apr 26, 2024 at 4:31 PM
    #528
    Kwikvette
    Fresno County
    4 run, 2 don't
    My tank is on day 25 as of today, so it's fair to say if some would've died...they would've been showing signs of that already.
    The Anubias shown there had gone yellow shortly after introducing it to my tank. What shocked me most was that it was an emmersed plant, and like any emmersed plant, they go through a phase of dropping leaves and melting back when being submerged.
    Mine never went through that phase and instead perked right up without dropping any leaves or melting back.
    Here it is when I first added it -
    And here it is as of a day ago -
    You will see however that the Java Fern there did gain a few 'black spots' that do not look like they can be rubbed off. I haven't tried it to be honest but chalking it up to the whole 'melting back' process as these too were emmersed before going into my tank.
    As for the Ludwigia, they were already living in a tank (from my LFS) when I got them and as you can see, they're doing well as they really opened up and have developed many more roots and shoots to propagate from if I wanted -
    Ludwigia do well in a low tech, low light tank, which is why I went with them but I hear if you give them too low of a light (as well as not providing additional iron) the reds aren't as strong as they can be.
    Still, they're doing really well.
    I'm just waiting for my vinyl tubing and suction cup setup to arrive so I can open up another 'ceiling' above the set on the right as the floaters have really provided a lot of shade -
    All I can say is, there's no reason why anyone should skip having live plants in a tank!
    Not only do I enjoy checking out my tank (even though I haven't added fish yet), it does great at providing plenty of filtration by itself.
    ssd_dan likes this.
  9. Apr 30, 2024 at 3:23 PM
    #529
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ammonia has been 0ppm for a week and a half, nitrites have been at 0ppm for a few days, and nitrates are at 10ppm as I did a water change yesterday and today
    With that said, I introduced these two
    Sunset Gourami
    Here's to hoping they weren't too stressed during the move and don't show any signs these next few days
    MGMDesertTaco likes this.
  10. May 2, 2024 at 10:32 AM
    #530
    Kwikvette
    Fresno County
    4 run, 2 don't
    Digging these little guys
    ssd_dan likes this.
  11. May 10, 2024 at 11:33 AM
    #531
    Kwikvette
    Fresno County
    4 run, 2 don't
    Harlequin Rasbora added to the tank; everyone's a happy little family
    Voracious little eaters
  12. May 14, 2024 at 9:56 AM
    #532
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ignore the wiring, I've yet to purchase or make something to place the power strip in and hide everything.
    Made a small, decorative sign to go above the tank.
  13. Jun 8, 2024 at 4:49 PM
    #533
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    IMG_0782.jpgMy nano tank lol
  14. Jun 9, 2024 at 11:44 AM
    #534
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Had a light failure. :mad::mad::mad:
    A 70 dollar chinesium replacement is still cheaper than springing for what should have been a $500 fixture. :anonymous:
    Kwikvette likes this.
  15. Jun 9, 2024 at 5:25 PM
    #535
    Kwikvette
    Fresno County
    4 run, 2 don't
    The Hygger has treated me well
    Fat kid eating his veggies
    Rock Lobster[QUOTED] likes this.
  16. Jun 9, 2024 at 5:43 PM
    #536
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    That's what I got this time, a hygger that is the exact duplicate of a hytuiang that I ordered 2.5 years ago.
  17. Jun 9, 2024 at 5:46 PM
    #537
    Kwikvette
    Fresno County
    4 run, 2 don't
    The 24hr feature is nice, and although I have no algae I still shut the light off completely versus letting the moonlight feature run its course
    So far I dig it and the plants are all flourishing
  18. Jun 9, 2024 at 5:56 PM
    #538
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    My current program has sunrise at 6:30 am, sunset at 6:30pm, blue moonlight from 7 to 10pm.
    I'm hoping that the hygger can mimic that.
  19. Jun 9, 2024 at 5:58 PM
    #539
    Kwikvette
    Fresno County
    4 run, 2 don't
    There's a video that walks through programming as it's fully programmable; recommend watching that versus reading and following the included instructions
    I've just been too lazy to mess with it and especially since the tank is thriving, doing a manual on/off is no biggie
    I'll have to buy another light as I plan to add a 50 gallon tank
    The current co2 setup will go towards the bigger (future) tank and that DIY setup you hooked it up with will either go to the 20 gallon or maybe a smaller, extra tank
  20. Jun 9, 2024 at 6:01 PM
    #540
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Rock Lobster I'm an idiot, it's a Finnex
    My vacuum is a Hygger :rofl:
    But Hygger does have a fully programmable light as I had asked about it and only got my specific questions answered after having ordered the Finnex
    Had asked on another forum about the two and their features (not specificity mentioned in the ad)
