Aquarium Hobbyists
Discussion in 'Pets' started by mrbee2828, Jun 26, 2012.
  1. Sep 8, 2024 at 3:20 PM
    #561
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Beautiful tank. Your anemones look fantastic! I never had much luck with them, but strangley I had success with soft corals.
  2. Jun 5, 2025 at 2:33 PM
    #562
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Switching hobbies so figure I would list this here if anyone was interested. Have learned a lot and it's been really engaging. Set up is pretty self sufficient. No feeding, just topping off the water about once a week. On top of the main components, I have a lot of extras and hardscape which you know is the most expensive. Link below for the craigslist. Located in Denver, CO.
    https://denver.craigslist.org/for/d/denver-full-aquascape-aquarium-setup/7855888454.html
  3. Jun 5, 2025 at 2:40 PM
    #563
    ssd_dan
    ssd_dan Well-Known Member
    Daniel
    2012 RC 4x4 5spd
    shell, skids, sliders, suspension, bumper, winch, lockers
    Beautiful set up!
    Hope you are gonna feed those fish tho ;)
    edit: nvm, read the link
    Voltron4x4[QUOTED] likes this.
  4. Jun 5, 2025 at 2:43 PM
    #564
    ssd_dan
    Daniel
    2012 RC 4x4 5spd
    Btw, are you anchoring the rock work somehow or just stacking it?
  5. Jun 5, 2025 at 2:53 PM
    #565
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    F'that...
    Chick came home with a huge tank for African cichlids,
    then 1 tank turned into 4 tanks...
    then we started strapping on large external canister filters, bitch led lights, etc....
    Electricity bill got pretty stupid so after a few years when we moved, we ditched it all....
  6. Jun 5, 2025 at 3:24 PM
    #566
    Voltron4x4
    Denver, Colorado
    This and that...
    Superglue when setting it up. It becomes inert when it drys. Learned a lot from this channel. Was just interesting to watch and then I just had to try.
    https://www.youtube.com/@MDFishTanks
    ssd_dan[QUOTED] likes this.
  7. Jun 6, 2025 at 12:03 PM
    #567
    ssd_dan
    Daniel
    2012 RC 4x4 5spd
    But you can leverage that stupid-high power bill into justification for a big battery-solar set up.
    At least you can try to limit recharging off the grid to off-peak hours.
    In for a penny…
  8. Jun 6, 2025 at 12:16 PM
    #568
    Kwikvette
    Fresno County
    4 run, 2 don't
    Folks living in areas that get hit with hot temps - are you running a pond outside?
    A part of me wants to run an above ground pond/tank out in the backyard, mainly to fill some room in the backyard.
    We just got some concrete poured to extend our covered patio, as well as some artificial grass as this is all for our small family to hang out in. The grass is mainly for the kid really.
    On the top right of the picture to the right of the concrete, I've got some 3' (wide) x 15' (long) of dirt that I originally planned to cover with a weed barrier and rock. But I'm also considering in adding a pond in a sort of planter box style setup.
    Just worried about the 100+ degree weather we get in the summer, how deep of a pond do I need in order to maintain some sort of safe temperatures for a few fish. I understand the temperatures will vary with certain species but something like a gold fish or the sort with live plants. I mentioned the dimensions because that will narrow down the actual width of the tank being inside an enclosure.
  9. Jun 6, 2025 at 12:33 PM
    #569
    ssd_dan
    Daniel
    2012 RC 4x4 5spd
    You would have to monitor the situation.
    1 thing is the spike in day time temps, but another big factor is how much cooling down overnight can occur.
    Generally the time it takes to water to heat up gives the fish enough time to acclimate.
    Volume is your friend. Shading the water can help.
    Fountains are important to help cool but also aerate the water which is critical because warm water holds less oxygen.
    Having said that 3x15’ is a pretty good chunk of real estate. If you can get an average depth of 3-4’ (shallow end at 1-2’ —>4-5’ at the deep end) the depth will help shield the pond form direct exposure. And that fairly substantial volume will resist rapid temp changes.
    Goldfish/coi are natural choices, but alternatively you might be able to keep some hardy tropical fish.
    Kwikvette[QUOTED] likes this.
  10. Jun 6, 2025 at 12:55 PM
    #570
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    sun exposure will likely play a bigger part in the temperature than water volume. if you can put at least part of the pun under ground level, the ground temperature will do wonders for water temp regulation. goldfish and koi are hearty animals, so they will tolerate higher summer temps and colder winder temps well. it's more about fast temperature swings. another alternative if you have a fully above ground pond would be to run a pump for a waterfall feature. you'll need something regardless to agitate and oxygenate the water. from the pump, run a a long length of hose, that you burry a few feet under ground, and then have it return to the waterfall, back into the pond. that's essentially a year round temperature regulating "radiator".
    i keep koi, jumbo golds, Plecostomus, and mosquito minnows in out pond. it's three tiers. the upper two tiers are probably only 20 gallons each. they have aquatic plants that help filter, but are really just there for aesthetics. third tier is about 450 gallons 5'x4' x3'deep. the front and both sides are mostly above ground, but the back is not. we don't get much more than the mid 90s during the summer, but we have a very long summer. Frequently have 80 degree Christmases
    we've gotten snow twice in the last 10 years however, this past January being one of those. all of the fish survived.
    ssd_dan and Kwikvette[QUOTED] like this.
  11. Jun 6, 2025 at 12:59 PM
    #571
    Kwikvette
    Fresno County
    4 run, 2 don't
    The only plus side is that the temperature doesn't exactly spike. I'm constantly watching the temps on all our devices for the outdoors and earlier at 9am, it was 67. It hit the mid 70s by 10am and now at 1pm, it's 84.
    When it's hot during the day, it's warm in the evenings still. Think if you went outside last night at like 10pm, it was still in the 70s - 80s.
    But you are right about water depth, I do know I need a good amount to allow for a "cooler" area at the bottom, I just don't know the numbers side of it to see what is safe.
    I think I'll revisit this idea once we get a gazebo in place; I'll have to watch if there will be any exposure to sunlight there.
  12. Jun 6, 2025 at 1:03 PM
    #572
    Kwikvette
    Fresno County
    4 run, 2 don't
    @colinb17 you just touched on something I need to consider but didn't mention originally.
    Sun exposure, so once we get a gazebo in place I'll have to monitor like @ssd_dan mentioned.
    Then I can come back to you guys with more information.
    I had only considered gold fish due to koi fish getting really big. I know gold fish do as well but not as large as many koi when given the room.
  13. Jun 6, 2025 at 1:12 PM
    #573
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I've loved having koi in my pond. don't count them out, especially since 3x15 is far bigger than mine.
    Sun is tough because it's great for the plants, but can cause algae to grow like crazy, on top of the temperature risk. if the pond is under the gazebo, you won't have much to worry about. if your plants struggle, it'd be easy to add a plant light, but i doubt you'd need that.
  14. Jun 6, 2025 at 4:47 PM
    #574
    slater
    San Diego
    You couldnt give me solar.....:crapstorm:
  15. Jun 11, 2025 at 11:11 AM
    #575
    Kwikvette
    Fresno County
    4 run, 2 don't
    @colinb17
    @ssd_dan
    Just a quick question - so that area is closer to 4' wide from the fence to the cement, and just over 15' long.
    I won't be using the entire space as that'll be too large, but a good idea of what I can work with as far as a slightly shorter pond if I go even wider/longer.
    Since it's dirt right now, should I take any extra precautions with getting it leveled/stamped? As in, I want the space to look nice and I have my landscaper coming by later today but I'd like to know what to ask for. Wondering if just a nice leveled ground will suffice or if I should also get pavers on top or something?
    I just don't want the thing to sink in any weird manner and I won't be digging into the ground to install the pond at all below ground level.
  16. Jun 11, 2025 at 12:50 PM
    #576
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Do.you know how the pond will be constructed? Are you using a hard shell, pond liner, etc?
    Regardless, I would put the pond on top of bare (compacted) ground. That will give you the most brnefit of the coller ground temperatures. If you pour a concrete slab or lay pavers that are both out in the open and also under the pond, it will act like a heat sink and when the sun beats down on the concrete/pavers, that heat will bleed under and up into the pond.
  17. Jun 11, 2025 at 12:55 PM
    #577
    Justintheegreat
    Justintheegreat Well-Known Member
    Northern CA
    06 DCSB Sport
    Hello from NorCal. i have a 150g Peacock and hap tank.
    Kwikvette, ssd_dan and MGMDesertTaco like this.
  18. Jun 11, 2025 at 12:57 PM
    #578
    Kwikvette
    Fresno County
    4 run, 2 don't
    Concrete is not a consideration at all hence not mentioning it.
    The pond would be constructed similarly to yours - wood frame all around with a pond liner. Which reminds me, what's the best way to ensure the pond liner is fitted/attached to said enclosure?
    I'll be having someone build the "boxes" while I do everything else myself.
    I'll just need to map out how big I need to make the pond then if we go for nicely compacted ground.
    I only mentioned pavers as I'm going with a budget-friendly approach to covering the ugly dirt on the right corner. The area around the pond will be covered with river rocks or some other smooth rock to fill space.
  19. Jun 12, 2025 at 1:22 PM
    #579
    ssd_dan
    Daniel
    2012 RC 4x4 5spd
    Rock work can help hold the edges of a pond liner in place.
    The liner should extend onto the “shore” a fair bit and then buried (just) above the waterline.
    I may have seen planters set in place with aquatic/semi-aquatic plants along the edge that can do the job too.
  20. Jun 12, 2025 at 1:40 PM
    #580
    Kwikvette
    Fresno County
    4 run, 2 don't
    My ADHD causes me to throw in extra unnecessary details :rofl:
    The rock was mentioned as used for covering the ground on the dirt.
    But a design like this should suffice easily right?
    To aid with bringing in fresh water, I think it'd be smart to add some sort of tote in it's own wooden enclosure to draw water from?
