Aquarium Hobbyists
Discussion in 'Pets' started by mrbee2828, Jun 26, 2012.
  1. Jun 17, 2025 at 10:51 AM
    #601
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah that thing is overkill, and definitely don't need a filtered kit built-in.
    Just more curious about a strong "box" to handle the water weight. The filter media layout will all be DIY.
    I did look at EDPM liners, and I can see why you recommend them. Will be going that route for a liner.
    And depending on the size of the plastic bin (for the filter) will determine the add-on enclosure built against the pond.
    Goal is to stay away from gravity fed (from box to pond) and use a pump to push water from the filter box up to a "waterfall" back into the pond.
    Goal is to hide everything within the wooden built enclosure.
  2. Jun 17, 2025 at 11:06 AM
    #602
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Anything wrong with just getting these then? I'm not really sure why you feel like you need an external filter box for something that small - it's just going to add failure points
    1. https://www.amazon.com/TetraPond-Submersible-Filter-Ponds-Gallons/dp/B0024EFYU6
    2. https://www.amazon.com/Danner-02477-Pro1000-Pond-Waterfall/dp/B001B4F4AK
  3. Jun 17, 2025 at 1:35 PM
    #603
    Kwikvette
    Fresno County
    4 run, 2 don't
    Being my first outdoor pond, I may be looking at this stuff the wrong way which is why I came here for suggestions.
    I really like that filter box you just linked, but the reason for an external setup was to create a sort of sump tank. I ran a 20 gallon sump tank to my +100 gallon fish tank but it was all indoors.
    I thought having a small reservoir of water, along with filtering of my own, would really help the pond but it seems overkill I guess due to the size of the tank itself?
    I'll be around 150-200 gallons but don't expect to have more than 5-6 fish in it to give them room to grow. Maybe a submersible with a large volume of water for the tank itself could be the better alternative.
  4. Jun 17, 2025 at 2:33 PM
    #604
    treyus30
    Trey
    Mesa / AJ, AZ
    Maybe time for some diagrams haha
  5. Jun 17, 2025 at 2:35 PM
    #605
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm just gonna have to shoot you my number :rofl:
