AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 7, 2020 at 6:22 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    What's form 2, chopped liver?
    will.i.was and 95 taco[QUOTED] like this.
  2. Apr 7, 2020 at 6:24 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    To us mere mortals, yes. I left it out because it’s for FFL’s only.
    boston23 likes this.
  3. Apr 7, 2020 at 6:47 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Im still trying to understand how that nfa trust works
    95 taco likes this.
  4. Apr 7, 2020 at 7:01 PM
    95 taco
    95 taco Battle Born
    rmepilot and boston23[QUOTED] like this.
  5. Apr 7, 2020 at 7:27 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Ok yeah I kinda thought I had form 1 and 4 right in my head lol supposedly the store closest to me is gonna be getting a kiosk. I’d rather go through that than have to get my prints done and send them off and what not. Need to continue my research on suppressors now...
    95 taco[QUOTED] likes this.
  6. Apr 7, 2020 at 7:42 PM
    BulletToothTony
    BulletToothTony [OP] You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    No kiosk close to me so I had to do the finger prints and mail them in. Only added two days so it’s not bad.
    YotaOverAll[QUOTED] and 95 taco like this.
  7. Apr 7, 2020 at 8:02 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  8. Apr 7, 2020 at 8:14 PM
    95 taco
    95 taco Battle Born
    My first can I didn't have to do prints and it was awesome, my second can I used a kiosk and it was stupid simple.
    YotaOverAll[QUOTED] likes this.
  9. Apr 7, 2020 at 10:08 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Put about 200rds of garbage steel cased Tullamo through the new AR pistol. I sighted in my Red dot and iron sights. Things I learned
    1. That steel cased ammo ran like garbage In my PSA 10.5 and in my buddies Aero Precision 10.5” Pistol. Both of our guns had SEVERAL failures to eject, light strikes & failure to feed, and also failure to lock open on empty mag. Both rifles were VERY DRY. I sprayed some ballistol in the BCG and upper receiver & racked the charging handle a dozen times and then had absolutely no other failures.
    2. I will keep my AR “wet”
    3. I’ll probably stick to brass manufactured ammo just to reduce the frustration that ultra cheap steel cased can cause but it was probably all due to the fact that I never even cleaned/lubed the AR before taking it out.
    will.i.was and YotaOverAll like this.
  10. Apr 7, 2020 at 10:15 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Looking to use a BCM KMR with a Surefire Warden. Wanted to know if the outside diameter of the Warden exceeds the inside diameter of the KMR? Essentially, can I have a little overlap between the two? From the pics I've seen this won't work but I wanted to confirm. Let me know!
  11. Apr 7, 2020 at 10:16 PM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    I too keep my rifles relatively wet and almost never experience failures due to steel cased ammo. That being said, they arent dripping in oil lol. My 5.56 gun loves that cheap shitty ammo! However my old 10.5” upper didn’t like it. Weird how that worked out.
    Have a 9mm pistol now and need to sight it in.
  12. Apr 7, 2020 at 10:20 PM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    This is my very first AR & I’m not an “excessively oiled” kind of guy. I keep my guns on the dry’er side generally. I also only use Ballistol exclusively, which helps keep everything easy to maintain/lube without “gumming up” anything with other types of lube
    LivinLoud[QUOTED] likes this.
  13. Apr 7, 2020 at 10:20 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Won’t work
    BCM lists inside diameter as 1.3 and the Warden is 1.5 if you don’t have the QD, 1.6 with QD
  14. Apr 7, 2020 at 10:23 PM
    desertjunkie760
    Shane
    Check My Sig.
    I realized almost immediately the the QD system of the Warden will create and issue of its own.
    thanks for the input though!
    JimBeam[QUOTED] likes this.
  15. Apr 7, 2020 at 10:25 PM
    JimBeam
    JB
    2015 Tundra
    There is a direct thread version
  16. Apr 7, 2020 at 10:29 PM
    desertjunkie760
    Shane
    Check My Sig.
    I did see that. Might be something to look into but still won’t allow clearance with that particular hand guard.
  17. Apr 7, 2020 at 10:36 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    No prints on the first, why not? Also, any 556-30 cal suppressors you recommend I look into? Preferably with a QD option
  18. Apr 7, 2020 at 11:16 PM
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    I basically drench my shit in CLP.
    Once a year i tear everything down, remove every spec of carbon with good cleaner and a brush/patch/ect and then bathe liberally in CLP. Then throughout the year its usually just a boresnake and quick field strip/clean/lube of the BCG and wipedown of everything else (with more CLP of course). Always have gone a little dryer if i need to on my "in between session" maintenance depending on conditions (dusty fields, rainy forest, bench at the range, ect). Been doin that for about 5 years now. Although my tempo has slowed down the last year or two b/c of other priorities (like flee'ing CA)
    For the life of me i cant remember the last failure of any kind i had with any of my AR's (even my nostalgia cheap-o PSA A4 clone, which admittedly only has about 1k through it). Over 10k rounds of (almost exclusively) PMC x-tac and federal 62g... And i cant remember a failure.
    Then again, only shooting 1-2k at the most between field strip style cleanings, i guess id be pretty bummed if i was having problems lol
  19. Apr 7, 2020 at 11:38 PM
    woollypullover
    woollypullover Well-Known Member
    2019 Tacoma Sport
    I've got my eye on the Griffin Armament Optimus.
    95 taco likes this.
  20. Apr 8, 2020 at 3:59 AM
    95 taco
    95 taco Battle Born
    It was back before the amendment that required fingerprints for trusts.
    For the budget range YHM has good options, the Turbo, Turbo K, Resonator, and Resonator K are great options in the sub $600 range, they’re the cheapest that I would consider going without going direct thread.
    For the $600-750 dollar range you have the Griffin Recce 5 and Recce 7, they’re solid cans but are an older design (they have had revisions over the years) so they’re heavier than some of the newer options but they have great durability.
    Above $750 Griffin also has some good options such as the Explorr series (the .224 Explorr is actually under $750) and @45acp can tell you his experience with the Explorr series. Or you can get into the user serviceable rifle suppressors when you get closer to 1K.
    Rugged and dead air also have some good options in the $650-1,000 range.
    I got one as my first centerfire can and I really like it, I run the mid length version to keep my SBR shorter and it sounds good.
    I will warn you, don’t expect to go to the range and expect to switch configurations “on the fly” the can will have to be ambient temp to get anything unthreaded and I’ve had the pistol assembly “cage” get stuck inside the can requiring a vice to hold the can while I popped it loose.
    It is a very good suppressor and because of the versatility I know that I don’t shoot my pistols suppressed very often, I would rather wear ear pro than shoot more than a mag or two with the suppressor attached because it changes the feel of the pistol so much.
    YotaOverAll[QUOTED] and 45acp like this.
