AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 8, 2020 at 3:16 PM
    Thompson486
    Thompson486 Well-Known Member
    Sherwood Park, AB
    2022 AC Off-Road Blue Crush
    Just finished building a MK18 Clone.
    gotta ditch the optic (Vortex SPARC) though and get a real optic. It’s just on there cuz I got it with some other parts...
  2. Apr 8, 2020 at 4:07 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    10.3" barrel?
  3. Apr 8, 2020 at 5:12 PM
    Thompson486
    Sherwood Park, AB
    Yep!
  4. Apr 8, 2020 at 9:03 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Sandman S looks promising. And comes with a brake to coincide with the QD system
    95 taco likes this.
  5. Apr 10, 2020 at 4:54 AM
    woollypullover
    woollypullover Well-Known Member
    2019 Tacoma Sport
    Now I need a milpsec collapsible stock and I’m debating swapping the afg for a vertical.
    95 taco likes this.
  6. Apr 10, 2020 at 5:38 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Going SBR?
  7. Apr 10, 2020 at 8:07 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I'm biased so take this with a grain of salt and at the end of the day it's your decision.
    The Xplorr 300 from Griffin is over 30% lighter, .4" longer (edit: its .4” shorter, not longer), $30 cheaper, and despite being smaller and lighter they meter very similarly. The griffin also includes a muzzle device and has no barrel length restrictions so it'd very comparable to the Sandman S.
    If you like the dead air, go for it, I want too make sure you look at the numbers before you buy.
    Also, I'm not sure if you have seen this video, more data=Better.
    https://youtu.be/iL2Q2DIX76o
    This is a good channel.
    https://www.youtube.com/user/fireman1291
    As is this.
    https://www.youtube.com/channel/UC_x4X9FgLx-RsSSZ8e6fIFQ
    EubeenHadd likes this.
  8. Apr 10, 2020 at 8:28 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    After doing some looking at the tubeless options on the market it's hard to argue against a tubeless Sig or GA can. They're lighter and quieter for the same size, and often not much more expensive if they even are more expensive than their rivals.
    95 taco[QUOTED] likes this.
  9. Apr 10, 2020 at 8:35 AM
    woollypullover
    2019 Tacoma Sport
    Done been gone SBR! I guess it’s not technically an sbr yet but I have my stamp and I had the barrel laser engraved.
  10. Apr 10, 2020 at 8:37 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    barrel or lower engraved?
    Chew likes this.
  11. Apr 10, 2020 at 8:38 AM
    woollypullover
    2019 Tacoma Sport
  12. Apr 10, 2020 at 8:57 AM
    svermilyea
    Scott
    East Tennessee
    The last two I did required the lower to be serialized
    Chew and 95 taco like this.
  13. Apr 10, 2020 at 9:10 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I'm not a lawyer enough to know, but engraving the barrel might make sense. Suppressors and Autosears turn the whole firearm into an NFA item once attached and only when attached, so theoretically serializing the upper/barrel makes a bunch of sense. Whether the ATF sees it that way I don't know, but it's a really cool idea nonetheless.
  14. Apr 10, 2020 at 9:13 AM
    svermilyea
    Scott
    East Tennessee
    https://www.atf.gov/firearms/firear...rms-ammunition-firearms-verification-overview
    I rescind my statement about the frame being a requirement. Upper/lower/barrel are all acceptable to the AFT. Most commonly the lower is used, as it has to be visible to an inspector without disassembling the weapon.
    Chew, 95 taco and desertjunkie760 like this.
  15. Apr 10, 2020 at 10:18 AM
    95 taco
    95 taco Battle Born
    I was extremely impressed by the performance of the Sig 30 cal QD can on a 9” 300BLK, Griffin has a video on their YouTube showing meter performance and the Sig van was very close to the griffin cans and then pulled ahead for 300BLK sub Sonics, I think Sig tuned their can to sound optimal on the rattler hence the slight gain there but slight loss against .308 and other calibers.
  16. Apr 10, 2020 at 10:36 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Man that link is confusing. The serial number seems to have different requirements than the rest of the markings. I'm not sure if the barrel is a kosher spot for the serial number by that link. CTRL+F for barrel shows every marking other than the serial number can be on the barrel, but the serial must be on the frame/receiver.
  17. Apr 10, 2020 at 10:49 AM
    svermilyea
    Scott
    East Tennessee
    I was confused too (that is the beauty of an archaic document written in the 30s - requires an interpreter every time you need clarification), so I pulled the manual (ATF weapons are nothing to leave to chance). Normal serialization for an AR is done on the receiver only. NFA markings can be on the reciever (upper/lower) or barrel. They are required to be at least 1/16 in height and visible without having to disassemble the weapon. They are to include the trust/owners name, city and state.
  18. Apr 10, 2020 at 10:59 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    If I'm understanding this right, the NFA requirements do not include a serial number then?
  19. Apr 10, 2020 at 11:09 AM
    svermilyea
    Scott
    East Tennessee
    In order to complete the Form One. The receiver must have a unique serial. The NFA markings are separate from the serial number
  20. Apr 10, 2020 at 11:10 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Interesting, I'm starting to understand now.
