AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. May 7, 2020 at 9:28 AM
    GATacoRookie
    GATacoRookie Well-Known Member
    Phil
    Atlanta GA
    MGM TRD OR DCSB 4x4 AT. Mall Rated sticker
    Toytec Fronts. 18x9 Fuels on 285/65/18 TerraGrapplerG2's. LEDs everywhere.
    Cut that bitch... :sawzall:
  2. May 7, 2020 at 9:34 AM
    Ncpi007
    Ncpi007 Well-Known Member
    Charlotte, NC
    2018 Tacoma TRD Off-Road
    Got it..... it looks like the handguard had been epoxied, I just popped it with a screwdriver.
    odomandr[QUOTED] and JimBeam like this.
  3. May 7, 2020 at 10:06 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Hate being so scared to fuck something up that I don't do anything at all... I have been there and will be again
  4. May 7, 2020 at 10:13 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    The forward front sight (gas block) is definitely pinned (pins are tapered driven left to right to remove). If the front break is pinned, the pin can be drilled out and the muzzle break unscrewed. If you are uncomfortable with either of these processes, you will need to take it to a gunsmith or risk destroying the gas block and/or barrel. The cost of a gunsmith and replacement hand guard will outweigh replacing the upper in total. Radical Firearms, PSA, and CBC all make a milspec upper that will meet your requirements at a very reasonable price ($200-250).
    Ncpi007 likes this.
  5. May 7, 2020 at 10:13 AM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    So, I got a Q Trash Panda for my 308 Bolt and it is amazing for that. It also came with a 1/2 x28 cherry bomb so I put that on my 18" AR barrel. The AR has an adjustable gas block and suppressor optimized charging handle. I took it off after 6 months and a bunch of trips. I just don't think suppressing an AR has high upside and it comes with a list of minor annoyances. A suppressed AR is still loud and will always have the sonic crack and the noise from cycling. It wont be AS loud but buying your first suppressor for an AR will make you really question suppressors value.
    Next, if you are hanging a 30 cal can on the end of an AR barrel (especially a big one like a Q) you will absolutely notice the extra length. AR people like a 14.5" pin and weld over a 16" because they care about 1.5". Now add 8" plus the weight and it turns your AR into a bench only gun. So I took my nice ultralight 18" barrel build and turned it into a cumbersome gassy beast just so I could be slightly quieter (and look cool, to be honest). I gave it a fair try and found it wasn't worth it for me.
    All that said, as a 3rd or 4th suppressor I'd absolutely consider a dedicated 556 can. Something short and light, knowing that it will take a little edge off but not make a huge difference. I love my 308 bolt with the Trash Panda, it makes a real difference. I love 22s suppressed, that is truly Hollywood quiet and what I would recommend to anyone as a first suppressor. Suppressing 556 feels like a low value proposition and best left for later (or done as an experiment with some sort of hybrid can). If you really want a suppressed 556 as a home defense gun I'd go for a pistol build and run a dedicated can on it. Or consider a PCC 9mm with a pistol can on it... you don't have rifle power but you do get hearing safe.
    Good Luck and happy shopping
    JCOOR likes this.
  6. May 7, 2020 at 10:24 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    That's the thing, I'm not putting it on either rifle expecting hearing safe or AR optimized, just less loud so I don't have to double up on earpro to come away without a headache after a day on the range. I plan to pick up other suppressors down the line as well, but my main goal is that it be mountable to the AR, with general purpose use on multiple hosts in mind. I will absolutely pick up a dedicated 5.56 can for the thing down the road, combined with a shorter barrel for dedicated suppressed use, but for the interim I'm willing to deal with the issues a 30 cal can on an AR creates. In this case, the can bumps my OAL to around that of a 20-22" rifle, which I'd still rather have than any of my other options inside my house. The vast majority of the round count is going to be primarily Appleseed type range time and precision rifle use, with the others being tertiary. When I take an HD rifle/upper seriously and put a short combo together for such needs, it'll likely be a very short 300blk because a short barreled 5.56 is pretty worthless below 10.5.
  7. May 7, 2020 at 10:54 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    have you thought about electronic hearing protection? i have some and they work great. it cuts all noise above certain Db.
  8. May 7, 2020 at 11:08 AM
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I have, and love them. I'd prefer to run them solo over muffs and plugs, and provide everybody in the vicinity some level of hearing protection whenever I'm shooting. I can say 99% of my shooting can be boiled down to times where I'm there with other people and communication is ongoing, or in situations where I don't want to blow my ears out because I had to take a shot without ear pro.
  9. May 7, 2020 at 2:19 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Presents waiting for you after a hard days work is always nice.
    TomTwo, whitebread, Chew and 3 others like this.
  10. May 7, 2020 at 6:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Well worth the extra few bucks!
  11. May 8, 2020 at 4:22 AM
    clc clc
    PA
    Definitely. I wanted a TT sling but i couldnt find one on their site.
  12. May 8, 2020 at 7:50 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I’ve never been a big fan of 20 round magazines (they don’t drop free like my Pmags do, plus I like moar capacity) but man it’s nice to have for this use.
    Sig45, 45acp, rmepilot and 2 others like this.
  13. May 8, 2020 at 11:48 AM
    clc clc
    PA
    I love 20 rd mags. I have a pile of vietnam era colt 223 mags. Never had a problem but i dont beat on them being antiques and all.
  14. May 8, 2020 at 2:12 PM
    95 taco
    95 taco Battle Born
    We have a few but we jumped from 10’s straight to 30’s when we moved to a free state, the biggest issue I have with ours are they don’t drop free which is aggravating to me.
    Motofox likes this.
  15. May 8, 2020 at 5:40 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Few easy essentials added to the new BCM this evening. Still waiting for Trijicon MRO to arrive (on backorder).
    Geissele BUIS - fit & finish as expected
    Rail Covers
    QD Sling Mount
  16. May 8, 2020 at 5:43 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    What rail covers are those?
  17. May 8, 2020 at 5:45 PM
    Sig45
    Mark
    Maine
  18. May 8, 2020 at 9:04 PM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    SilencerCo Hybrid-46
  19. May 16, 2020 at 6:57 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Never touched an AR before, in any capacity, but, nonetheless.. ordered this little darling tonight.
  20. May 16, 2020 at 7:01 PM
    rmepilot
    Rob
    Huntsville, AL
