AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Aug 3, 2012 at 10:20 AM
    #2081
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    anyone running a 14.5 inch barrel with a pinned and welded flash hider?
  2. Aug 3, 2012 at 10:46 AM
    #2082
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    In California no less ;)
    Daniel Defense 14.5, Smith Vortex FH
    "Surprise Cockfag" laser engraved on the inside of the dust cover :D
  3. Aug 3, 2012 at 11:50 AM
    #2083
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
    Is that cerakote I see? Where did you get the template for that paint scheme
    BAD ASS BTW
  4. Aug 3, 2012 at 12:28 PM
    #2084
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Nice Rich, Carbine gas system right?
  5. Aug 3, 2012 at 12:38 PM
    #2085
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    fishnet pantyhose.
  6. Aug 3, 2012 at 12:39 PM
    #2086
    SACTOWN
    Greg
    That is sexy!!!
  7. Aug 3, 2012 at 1:31 PM
    #2087
    Rich91710
    Rich
    Los Angeles
    08 Base
    Brownell's AlumaHyde-II.
    Base coat of Coyote, which is a dead even match for Magpul and Vltor's FDE, even though it appears a shade "olive" due to the lighting and flash.
    Let it cure for 2 weeks.
    Assembled everything, pulled on the fishnets, and freehanded the tan.
    Using paper plate templates cut to leaf and "stick" shapes, shot the forest green and brown Krylon Camo.
    Pulled off the fishnets, and disassembled, gave the whole thing 2 coats of clat clear AlumaHyde-II
    Spent 3 hours with files and sandpaper cleaning the crap out of the takedown and selector holes and off of the pins and selector... it's THICK paint!
    Midlength!
    Runs like a champ. Right out of the box it deposits the casings in a nice little pile at 4:00 whether I'm running XM193 55gr or 62gr steel core ATI.
    I kinda like the way the liiine runs up the back of your magazine..... :D
  8. Aug 3, 2012 at 1:46 PM
    #2088
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Double nice. I'm probably going to switch my barrel out for a 14.5. It has a 16" carbine on the upper at the moment.
  9. Aug 3, 2012 at 1:54 PM
    #2089
    Rich91710
    Rich
    Los Angeles
    08 Base
    The 14.5 is nice, but be aware that once the FH is mounted, it's done.
    You can't change the gas block or barrel nut once it's assembled.
    Also, if you don't have a lower that is clear for assembling as a pistol, you run into constructive possession issues if you take possession of the short barrel. I used my drill press to machine out a functional pistol lower before I ordered the barrel.
    If you don't have a pistol lower, you'll need to get everything you want together before getting the barrel, then take the box down to Riflegear and have David assemble the upper and pin the FH on.
  10. Aug 3, 2012 at 2:16 PM
    #2090
    SACTOWN
    Greg
    Lmfao
  11. Aug 3, 2012 at 2:20 PM
    #2091
    Rich91710
    Rich
    Los Angeles
    08 Base
    "I've always kinda liked those high caps too....."
    Of course, those 30rd bodies are blocked to 10. I screwed up and one is a 9rd mag.
  12. Aug 3, 2012 at 2:21 PM
    #2092
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    My plan was to buy the dd 14.5 barrel from riflegear and have them pin and weld it for me and probably have them assemble it.
    I'm still on the edge about tho because after all that everything on there is permanent.
  13. Aug 3, 2012 at 2:24 PM
    #2093
    Rich91710
    Rich
    Los Angeles
    08 Base
    Exactly.
    David called me 3 times before he welded the FH on to be sure it was configured the way I wanted.
    3rd call, I asked "Okay, the gas block is a Midway low-pro, and I bought the TRX from you... is there something I should know before you pin it?"
    "No... just don't want to have to undo it when you change your mind and want a Daniel rail.
  14. Aug 3, 2012 at 2:33 PM
    #2094
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    I just finished this one for the 2nd time :) (Cerakote, new stock, other parts.)
  15. Aug 3, 2012 at 2:51 PM
    #2095
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nice. I love the AAC Blackout.
  16. Aug 3, 2012 at 7:48 PM
    #2096
    Sleeper362
    Sleeper362 One Convenient Locations ......In Africa
    Corporal
    K-Vegas NC
    06 SR5 4X4 DC Shortbed
    Nice boomstick.
  17. Aug 3, 2012 at 7:58 PM
    #2097
    ladysmith223
    ladysmith223 Member
    2011 Tacoma Double Cab TRD Sport
    All Pro Offroad front steel bumper
    Rock River makes the AR-15 that i have. I love it. Very well made, theres no play or unaligned movement between uppers and lowers, even after alot of heavy use at the range. Shoots 5.56 and .223. I didnt do too much to it. Still has the iron sights. I only added a sure fire light to the rail. Also, EWL (extreme weapons lubricant) seems to be my new favorite when it comes to cleaning that rifle.:rolleyes:
  18. Aug 3, 2012 at 8:00 PM
    #2098
    ladysmith223
    ladysmith223 Member
    Heres a photo when a few of us went to the range with them :D
  19. Aug 3, 2012 at 8:10 PM
    #2099
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I ordered 15, 30 round boxes of 5.56 from PSA. They sent me 15, twenty round boxes. Kinda pissed and of course they are closed for the weekend.
  20. Aug 3, 2012 at 8:12 PM
    #2100
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Watch the gas key. My RRA's gas key came lose after less than 1k rounds
