AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Oct 8, 2020 at 2:41 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    You don’t know his struggles
  2. Oct 8, 2020 at 2:43 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Whats the theory/method behind the super tall mounts?
    Chew likes this.
  3. Oct 8, 2020 at 2:46 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Nods
    Something most people don’t have to worry about here. Aimpoint has there own NVG height mount as well as many of the after market people.
  4. Oct 8, 2020 at 3:03 PM
    95 taco
    95 taco Battle Born
    If I’ve got NVG money I might as well get a DBAL or something similar, keep the optic a little more streamlined for daytime use.
    rmepilot likes this.
  5. Oct 8, 2020 at 3:13 PM
    BulletToothTony
    BulletToothTony [OP] You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    You would think that but actually bringing the rifle up you don’t have to “turtle” or drop your head down any. Red dot is right there where is needs to be, just dry firing it was very comfortable. Will get to the range next Tuesday and try it out on steel and paper.
    and the nvg thing is a bonus too :spy:
  6. Oct 8, 2020 at 3:37 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    I went with ATPIAL. I tried lining up my tube with an Eotech but it's slow to find it and line up a shot. Not interested in raising the sight.
  7. Oct 8, 2020 at 3:44 PM
    dfanonymous
    Bullettoothtoney is correct. The issue is people don’t have good technique so things like turtling are accepted and no one is none the wiser when you come on to these type forums. However very few people are training 10 hour days for weeks doing rehearsals but I can tell you that not only are you more streamlined but you get less neck fatigue.
    On normal height optics, say a Eotech, I rotate the rifle about a 35 degree to get the right height to keep my neck in the right position.
    Dbals/peqs/ or things like them are fine if you know how to use them or know when they are bad ideas. CQB distances and angles is where you will find heartache with your $1000 dbal between target blooming and laser offset.
    Beretta4x4 likes this.
  8. Oct 8, 2020 at 4:01 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I was wondering if there would be an advantage to raising the sight to help with neck cranking and shit lol
  9. Oct 8, 2020 at 4:26 PM
    BulletToothTony
    They exps3 sits higher then most mounts anyway but even then i still had to drop my head too much for my liking, and when wearing full on larp gear it was even worse. Ive got high hopes that this will fix almost of my little issues, if not i'll be on the search for something else i guess.
  10. Oct 8, 2020 at 4:37 PM
    dfanonymous
    Try turning the rifle inward a little. About 10-30 degrees.
  11. Oct 8, 2020 at 4:55 PM
    BulletToothTony
    I’ll try that next time I’m home. Thanks!
    dfanonymous[QUOTED] likes this.
  12. Oct 8, 2020 at 10:29 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    What’s everybody running for slings? Looking at a magpul QD right now. But I need to get a new stock first with a QD mount.
  13. Oct 9, 2020 at 1:51 AM
    BulletToothTony
    I had a few magpuls and they were ok, I got the new one T. rex released and like it more then the magpul.
    YotaOverAll[QUOTED] likes this.
  14. Oct 9, 2020 at 5:25 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Magpul, vtac, blue force gear
  15. Oct 9, 2020 at 6:57 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    My scope is too low on my AR. Seemed ok offhand, but not so much on the bench. Any suggestions on how to determine what height to get?
  16. Oct 9, 2020 at 9:49 AM
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    That is one tall saddle:D
  17. Oct 9, 2020 at 4:36 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Love my Magpul MS4
  18. Oct 9, 2020 at 7:12 PM
    db6598
    db6598 Well-Known Member
    NC
    I'm running an Edward Sherman Design sling. I like it better than the magpul ms4. It's easier to adjust.
  19. Oct 9, 2020 at 8:38 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Put this another way, how far above the bore center is the center of the scope? 3x9x40, anyone have that mounted on an AR?
  20. Oct 9, 2020 at 8:41 PM
    dfanonymous
    You looking for bore height for a ballistic solver or something?
