AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Oct 9, 2020 at 9:13 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    No, I'm looking for how tall to make the risers fit my face. AR needs to be taller. My other rifles have stocks with a drop at the comb. AR does not. If that makes any sense.
    wilcam47 likes this.
  2. Oct 9, 2020 at 9:48 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Viking Tactics, and a home made BFG Vickers clone. N both work fine
  3. Oct 9, 2020 at 9:53 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    There’s no universal way for a magnified optic. The common height over bore for magnified optics on an AR is 1.4 (iron sights height) to 2.?? inches. Usually it’s a trial an error thing depending on your cheek weld. Most cantilevers get you pretty close. I’ve used a .55 inch 20 moa riser with low rings as well and have came out ok.
  4. Oct 10, 2020 at 5:18 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    The average height for a scope mount on an AR15 is 1.5”.
    You can also get 1.93”. That puts your optic pretty heigh but if it fits you better then go for it. Just remember your you will have a lot of height over bore at close range.
    wilcam47 and db6598 like this.
  5. Oct 10, 2020 at 5:49 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What rings are you using now?
  6. Oct 10, 2020 at 7:47 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    The C to C of bore to scope is 2.75 inches. Bell of scope is ~1/2" over the barrel.
  7. Oct 10, 2020 at 7:48 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I can't remember and I see no name on them. I have CRS ;)
  8. Oct 10, 2020 at 7:55 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    wilcam47 and geekhouse23 like this.
  9. Oct 10, 2020 at 7:55 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Can always get the carry handle then mount scope on top of that
    db6598 likes this.
  10. Oct 10, 2020 at 8:26 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    :thumbsup::rofl:
    wilcam47[QUOTED] likes this.
  11. Oct 10, 2020 at 9:28 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    Little helpful info from the Dead Center of Precision.
    Tall (LT660)
    Allows a 1/3 cowitness with the Iron Sights on M4 Carbine and AR-15 Flattops.
    Absolute (LT751)
    Provides absolute cowitness with the Iron Sights on M4 Carbine and AR-15 Flattops..
    Medium (LT660HK)
    Provides Lower 1/3rd Co-witness with iron sights when using HK Height iron sights.
    Short (LT661)
    QD Mount for Aimpoint Micro Sight. Gets the Micro down low to use on Shotguns, PS90's and AK's
    TomTwo, DrMark and 95 taco like this.
  12. Oct 10, 2020 at 9:46 AM
    95 taco
    95 taco Battle Born
    That looks pretty high already.
    These are regular “medium height” rings, perfect for regular rifles but very low for the AR.
    And then this is the replacement AR cantilever setup that’s 1.59”.
    wilcam47 and Fernando like this.
  13. Oct 10, 2020 at 10:08 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Gun has no iron sights.
  14. Oct 10, 2020 at 10:09 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    What;s the measurement from the top of the stock to the bottom of the eyepiece on the 2nd pic?
  15. Oct 10, 2020 at 10:14 AM
    95 taco
    95 taco Battle Born
    It’s right at 1 3/8”
  16. Oct 10, 2020 at 4:54 PM
    swtaco10
    swtaco10 Well-Known Member
    Dave
    South of Tampa
    2010 Tacoma TRD off-Road
    Bilstein 5100's, LED interior and puddle lights, 17" XD revolver's, Grabber A/T2's
    @CurtB those look like UTG or leapers mounts
  17. Oct 10, 2020 at 9:15 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Thanks. Mine is 1 1/4 still too low for me. My face is scrunched against the stock and slimline muffs grind against it. I may have to research cantilever mounts. The scope could be just a little more forward.
  18. Oct 10, 2020 at 9:16 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Nah, they're Amazon mounts. ;)
  19. Oct 10, 2020 at 9:36 PM
    wilcam47
    Will
    Bourbon state
    might look goofy but maybe a rail riser and then higher scope mounts
    https://outdoors.natchezss.com/bestsellers/Picatinny-Riser
  20. Oct 10, 2020 at 9:41 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
