AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Nov 29, 2020 at 9:11 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Ok, I think my rifle has a standard flash hider, welded on. How would I put on a muzzle device?
    Beretta4x4[QUOTED] likes this.
  2. Nov 29, 2020 at 9:15 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It's just threaded on. If you are having "muzzle flip" with a 5.56 AR you need to work on shooting technique, not bandaid it with some fancy muzzle device. The standard birdcage the Oracle comes with is more than enough.
    Beretta4x4 likes this.
  3. Nov 29, 2020 at 9:20 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    o_O ok 1st time I ever shot a gun..err riffle!! Ima lenrnin' tho! JFC
    cubie and Beretta4x4 like this.
  4. Nov 29, 2020 at 9:23 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    All good. A 5.56 AR is one of the softest shooting rifles you can find. I'd say get used to it as is and not worry about the extras that aren't needed. I know that's hard for guys like is that take a perfectly good Tacoma and strap a few thousand dollars of extra crap on it that we might not really need.
    Chew likes this.
  5. Nov 29, 2020 at 9:34 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    I highly recommend Q
  6. Nov 29, 2020 at 9:51 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Sorry, but this just showed up in my feed
    127561619_3504616419623352_4288947244115_6902d247bb1e28af9e35007d879384c8b2a190b7.jpg
    rmepilot, cubie and crazysccrmd like this.
  7. Nov 30, 2020 at 6:20 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Geissele makes a braided wire spring/buffer that eliminates the "thwang" sound when firing. It's great!
    Taco 422, llibrm, 4WDTrout and 3 others like this.
  8. Nov 30, 2020 at 7:03 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    I have the JP silent capture system. I always thought they were just a gimmick but I bought a lower with one installed already so I figured I'd try it before selling it off. Well I must say it makes recoil way smoother and you don't hear the spring moving around in the buffer tube like you would a standard ar during recoil. They are pricey for what they are but since mine came with the lower I'm keeping it. I see them regularly used for $80 so I may pick up another. For the price of the armapec one it may be a great contender in the market. Let us know how it shoots.
  9. Nov 30, 2020 at 7:12 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Get a good stance and grip. If the muzzle flip is too much for you you might be too vertical in your stance or even leaning back so the recoil is also pushing your top half back causing the muzzle to rise even more. That's the main thing I see when I see new shooters fire any thing for the first time. Bad stance and recoil sends the top half of their body back while the bottom stays and it sends the muzzle to the sky.
    Chew likes this.
  10. Nov 30, 2020 at 7:24 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    I have one and it served its purpose...Shooting suppressed with the full A2 Style butt stock, the recoil spring would make this really loud "TWANG" noise. It is all but gone with the armaspec. To be honest I can't notice any difference in the recoil than vs standard setup.
    From what I researched. the Armaspec is identical to the original JP model at half the price.
    95 taco[QUOTED] and cubie like this.
  11. Nov 30, 2020 at 8:20 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    I'm running one on a two stamp gun for the same reason. I don't have a whole lot of rounds through it and haven't played with the buffer weights (both uppers I run on it have SLR adjustable gas blocks) but I've been very happy with it.
    95 taco[QUOTED] likes this.
  12. Nov 30, 2020 at 8:24 AM
    Enigma8246
    Lee
    Central Arkansas
  13. Nov 30, 2020 at 8:25 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    The old m16s we shot in Air Force had that twang, but i dont notice it in the newer ARs
  14. Nov 30, 2020 at 12:37 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I'm older than dirt and shake like a dog shittin' peach seeds. ;) My preferred stance is sitting down or using a rest. Mostly sitting in my truck and shooting out the winder. When doing so and I have time to aim carefully my left arm is under my right and holding the steering wheel. Gun is resting on the window with a pad. It's a very solid hold but the gun is not held down sooo.. muzzle rise. I can do this with my Rem 700 .223 HB and watch the bullet impact thru the scope. Can't with the AR. That make any sense?
    If a brake will help. and if the birdcage is threaded, I'ma give it a shot.
    Thanks for the reply, much appreciated.
  15. Nov 30, 2020 at 12:39 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
  16. Nov 30, 2020 at 12:40 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    It coz yer old and can't hear no mo. :p
  17. Nov 30, 2020 at 12:43 PM
    Enigma8246
    Lee
    Central Arkansas
    Only YouTube channel I have ever bothered to turn on notifications for.
    CurtB[QUOTED] and Beretta4x4 like this.
  18. Nov 30, 2020 at 1:44 PM
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    You are correct sir. My "New A2" only twangs with the suppressor. (Or is that the only way you notice it?) I have an old colt A2 "sporter" from 1985...no twang.
    My SBR with a suppressor & collapsible stock does not twang. I somehow thing it has to do with the A2 stock is hollow and amplifies the twang. I even stuffed the cleaning kit compartment with a sock to try and dampen it.
    wilcam47[QUOTED] likes this.
  19. Dec 1, 2020 at 4:35 PM
    kcuv
    kcuv Well-Known Member
    kcuv
    USA
    TRD Off Road
    hold me bros my mag release sprung out while shooting and had to hold mag in for every shot afterwards for the day. put in new button and used lactate. check everything that screws boys.
    edit: loctite. used loctite. not lactate.
    Casper66, 4WDTrout, cubie and 5 others like this.
  20. Dec 1, 2020 at 4:44 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    :rofl: @ lactate
    MAG GRY TACO15, Chew and wilcam47 like this.
