AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 30, 2021 at 7:19 AM
    strider98
    strider98 Rather Large Member
    2018 Taco DCSB SR5 V6
    bupkis
    I do know combloc countries used corrosive powders/primers for much longer than western countries (for the most part) and those corrosive elements are more stable over time, from what I understand.
  2. Apr 30, 2021 at 11:54 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I think we can agree that proper surplus ammo is sealed well. Berdan primers and powders aren’t going to be come volatile over time. It’s not nitro glycerin.
  3. Apr 30, 2021 at 2:27 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    So i just learned a little more about Project Eldest Son. While they "say" the program ended, I wouldn't doubt them started it back up. Even if we haven't, other countries have. https://militaryhistorynow.com/2016...-secret-u-s-scheme-to-sabotage-charlies-ammo/
    And as for the round being combloc, there are a lot more combloc weapons in enemy hands than you know, especially if you get into frankenguns. A lot of countries would like to reduce those numbers.
  4. Apr 30, 2021 at 2:48 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    If I wanted to change up one of my .308's into one of the 6mm variants, which one, and just the barrel and magazines need to change? Just a paper target gun, looking to go 600 yards plus.
  5. Apr 30, 2021 at 2:54 PM
    dfanonymous
    Make sure the bolt face matches. Since this is ar15 thread I’m assuming you mean to switch to the 6mm creed, but the 6mm dasher and BR should fit the same bolt face as well.
    Gearheadesw[QUOTED] likes this.
  6. Apr 30, 2021 at 2:57 PM
    Gearheadesw
    Davenport Fl
    I thought I would need a different BCG to fire the different cartridge.
  7. Apr 30, 2021 at 3:14 PM
    dfanonymous
    Depends on the cartridge. Most of the short action cartridges use the .473 bolt face. The issue you run into is the pressure differences since the .308 is relatively low pressure. A HP bolt helps with a smaller firing pin diameter. That what I run and I’ve never had any primer problems. I load my ammo over max.
  8. Apr 30, 2021 at 10:55 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    US military was (still is?) using .50BMG ammo with head stamps from the 1940s up until recently. They made a LOT during WW2.
  9. May 1, 2021 at 3:43 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Makes sense. But, SLAP rounds were developed in the 80s and rolled into service during Desert Storm. Not sure what could put a milsurp round that is maybe 30 years old over 50% over pressure though.
  10. May 6, 2021 at 7:24 AM
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    I picked up an AR soft-sided case, a metal 30-round magazine (to separate range metal vs non-range Magpul), added some flip up sights, threw some stuff into my new “free” range bag from NRA, and added a little “bling”.
    994E77E7-A668-4CE8-BDC1-0E27B79B493B.jpg 38A7F861-BF1A-48C0-B9C8-A0DD07BFB225.jpg F33FA0D5-65A6-4161-8CE5-68A49E1BF615.jpg 1E8499FD-3BC5-429F-9380-6B9BD6F65108.jpg
  11. May 6, 2021 at 5:31 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Finally got my barrel back from pin/weld and my buddy's takeoff 1-8.5 came in same day. This thing weighs 10lbs 2oz as pictured, and I've got another 12oz of YHM Turbo K sitting in jail waiting for it.
    Redeemed, -Rorschach-, Chew and 2 others like this.
  12. May 11, 2021 at 8:34 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
  13. May 11, 2021 at 5:50 PM
    2008taco
    chris
    san diego
    So I'm at work making parts for a company that starts with a B and rhymes with Garret, and my boss has informed that no, I do NOT get 30% off these parts....
    cubie and wilcam47 like this.
  14. May 11, 2021 at 5:53 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :eek::goingcrazy:
    2008taco[QUOTED] likes this.
  15. May 11, 2021 at 6:47 PM
    2008taco
    chris
    san diego
    It's ok, there's more than one way to skin a cat. There's the always better 5 finger discount, just got to make sure to avoid the all seeing eye in the ceiling. Otherwise I might get an all expenses paid trip to one of those gated communities.
    Fohu and wilcam47[QUOTED] like this.
  16. May 11, 2021 at 6:50 PM
    wilcam47
    Will
    Bourbon state
    We used the term: NRTS...Not repairable this station.
  17. May 11, 2021 at 8:39 PM
    Redeemed
    Redeemed Well-Known Member
    Jeff
    Southern Maine
    05 SR5 with a "TRD Off-Road" sticker
    Does anyone happen to have any insight into BCM’s lack of stock on their website?
    I have contacted them, but haven’t got much of an answer.
    Who else would you all recommended for M-lok handguards?
  18. May 11, 2021 at 8:41 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Midwest or Troy
    Coma 13 and Redeemed[QUOTED] like this.
  19. May 11, 2021 at 9:02 PM
    2008taco
    chris
    san diego
    I'm betting it's demand. Guns and gun accessories are a hot ticket right now. We're making 700+ handguards a day, and apparently it's not enough because they started more of us on 12 hour shifts this week.
    Redeemed[QUOTED] and wilcam47 like this.
  20. May 11, 2021 at 9:17 PM
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Ghost firearms
