AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Jun 8, 2021 at 5:10 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    That's the first I've heard of that. I've owned many many variants of ARs over the years and shot with friends that have ARs, and have never seen pins walk out. I've never owned a PSA lower either though. I currently have an Anderson, Ruger and Larue lowers and they have all been great with the MBT triggers dropped in em.
  2. Jun 8, 2021 at 5:12 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    This is correct as the barrel needs to seat before final torque
    JustJon likes this.
  3. Jun 8, 2021 at 5:14 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Out of stock everywhere.
    I may just swap my anti-walk pins over to the good gun and use the LaRue pins on the old one. Nothing magical about all the other small parts, although I'd like an ambidextrous safety. Some kits come with the anti-walk pins, but man, some are like 80 bucks! Crazy times, but I am in no hurry, just fidgety.
    cubie[QUOTED] likes this.
  4. Jun 8, 2021 at 5:39 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    I built another psa gun for a friend for his bday and the pins in it where fine. Sometimes you just get one that the quality control officer was hungover that morning haha. This was a factory built lower btw.
    Non of the other many lowers of various brands have this issue
    JustJon and cubie[QUOTED] like this.
  5. Jun 8, 2021 at 5:58 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I do have a PSA upper on my wife's Anderson lower. That gun shoots sub MOA surpisingly.
  6. Jun 8, 2021 at 6:18 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    ive always done 50 as a middle ground, but it all depends - some require proper timing to install the handguard
    even radian stated 50 in their handbook
    vekMzETC6dpk3wJjhb1vYLjPbuEsOVIhaYZTWwMU_ee9bcb617a2e45741536c50a0f7a799f390672b9.jpg
  7. Jun 8, 2021 at 6:58 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Please sir my poor eyes are blinded
    inesshell[QUOTED] and JDAM like this.
  8. Jun 8, 2021 at 7:06 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    My wife’s SPR pins used to walk out. I think it was more of the cmmg problem though because it doesn’t walk out after I threw a Triggertech in.
  9. Jun 9, 2021 at 12:54 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Like many manufacturers, PSA outsources the machining of a lot of their parts. In terms of sticking to tolerances however, they are the least demanding of the manufacturers that I've seen. Barret goes way over the top, and rejects parts for the slightest reason. There is a box of Barret lowers and handguards sitting in the vault at work with tiny blems that PSA wouldn't even glance at... There are a few dimensions on Barret handguards that must be within +/- 0.0003", while pretty much everything on a PSA handguard is within +/- 0.003-0.005" though I've seen some go at +/- 0.010" over nominal.
  10. Jun 9, 2021 at 9:01 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    So I’ve been wanting a 12.5… now I’m thinking I might as well find someone to pin and weld a 13.7 for me and miss all the paperwork that goes with a 12.5 lol
  11. Jun 9, 2021 at 10:01 PM
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    My thoughts exactly
  12. Jun 10, 2021 at 9:55 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Most factory blowback guns use buffers that don't weigh nearly enough. This will beat the hell out of the FCG, among other things Try a heavier buffer and the pins won't move as much because the bolt isn't getting violently slammed back and forth.
    I have 10oz buffers in all my 9mm blowbacks.
  13. Jun 10, 2021 at 10:11 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    There is a spikes 9mm buffer in there now. it's heavier and longer.
  14. Jun 10, 2021 at 10:43 AM
    golfindia
    Yes.
    pickup truck
  15. Jun 10, 2021 at 11:00 AM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
  16. Jun 10, 2021 at 11:29 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
  17. Jun 10, 2021 at 11:42 AM
    golfindia
    Yes.
    pickup truck
    The gun will work with lighter buffers. Mfgs use them because they're cheaper and most people don't really know when their gun is getting beat to shit. But bolt velocity is way too high and port noise is much worse when there's too little weight. The potential for out of battery ignition is also higher. I learned most of this trying to get my 10mm AR working. I went back and revisited all of my other blowbacks; 9, 40, 45 and was shocked how much better they run with more weight.
    It's not just guesswork either, there's some real physics and math behind it. Every blowback gun I have pretty matches this website
    https://10mmautocombat.wordpress.com/blowback-bolt-calculations/
    My 10mm AR buffer is 2.1lb.
  18. Jun 10, 2021 at 12:10 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    2.1lb holy.... Thanks for the knowledge. I'll try out the KVP 10oz
    Thanks
    cubie likes this.
  19. Jun 10, 2021 at 7:19 PM
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    GOA's link for commenting on ATFs proposed pistol brace ban...refresh the page to get slightly different messages and subject lines, or write your own.
    https://www.gunowners.org/na06102021/
    JDAM likes this.
  20. Jun 11, 2021 at 9:42 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    AR pistols have dropped as much as $200 around here and some of the emails I am getting about the same
    smugly and wilcam47 like this.
