AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Dec 4, 2021 at 7:30 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    When I got the 9mm it had the KAK on it. First impressions it’s light, pretty sturdy, and cost effective. I don’t shoulder a brace but even holding against your cheek it’s pretty close and when shooting initially the rigid rear surface was not comfortable hitting my collar bone. I switched to the SBA3 and solved that issue
    TomTwo, Tacodog and Sig45[QUOTED] like this.
  2. Dec 4, 2021 at 7:34 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Yah, seeing that back edge of that KAK, my first thought was that it would not be comfortable in the event it's shouldered...hehe.
  3. Dec 4, 2021 at 8:06 AM
    BulletToothTony
    BulletToothTony [OP] You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Do yourself a favor and pass on the KAK shockwave, just get a SBA3 or 4 from the get go and you’ll be happy.
    if you get the sba3 look at these https://warhorseconcepts.com/product/sba3-straps/
    and these https://www.dirtyjdesigns.com/products/plug-for-sb-tactical-sba3-brace?_pos=1&_sid=1c497055d&_ss=r
    -Rorschach-, Chew and Sig45[QUOTED] like this.
  4. Dec 4, 2021 at 9:33 AM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    I ended up putting an upgrade strap on my sba3 warrior poet makes one, I think I got mine from phase 5 it really did a good job stiffening the arm split in the brace.
  5. Dec 4, 2021 at 9:42 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I have several A.R. pistols as you saw from the one I just posted a couple days ago, and I have actually never stuck my arm inside one of those arm braces. I’ve always shouldered it,
    Sig45[QUOTED] likes this.
  6. Dec 4, 2021 at 10:29 AM
    Sig45
    Mark
    Maine
    Thanks for the input. Going to stick with my original plan for now and am willing to change later. I just got my hands on a SBM4 and I think that'll work fine. Plus, that 2nd link you provided, they make an end plug for that too, so thanks for that link.
  7. Dec 4, 2021 at 11:34 AM
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Just keep in mind these plugs are for storage/transportation only.
  8. Dec 4, 2021 at 12:16 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    Note: All NFA rules apply. This plug may constitute a re-design of the stabilizer brace. We recommend only installing with a barrel length 16" or above or on registered SBR's.
    montijo505 and Sig45 like this.
  9. Dec 4, 2021 at 12:23 PM
    Sig45
    Mark
    Maine
    I'll probably end up Form 1ing this as an SBR anyway.
    montijo505 and Akkording[QUOTED] like this.
  10. Dec 4, 2021 at 12:59 PM
    Akkording
    Pete
    Houston
    Length of pull limiter options as well but your belief may very, that's a personal choice I suppose depending on your mods for folders or upgraded rifle length tube like the Vltor a5...
    https://youtu.be/rmj_EgcDbcE
  11. Dec 4, 2021 at 1:34 PM
    Dr. Doom Says
    Dr. Doom Says Well-Known Member
    SE TN
    2019 TRD OR
    Spent some at the range today but forgot to take pics. AR47 ran great with no hiccups and had the Vortex 3x prism sighted in pretty fast.
  12. Dec 4, 2021 at 4:49 PM
    Sig45
    Mark
    Maine
    Another quick question. Going to run an MRO on the AR Pistol. Would like to keep it as low as possible (I run full co-witness on most). There's a Trijicon low mount. Are there any iron sights (fixed or folding) that would full co-witness with the low mount/Optic?
    May run fixed front & folding rear
    Rail to Optical Axis for that setup = .990" per Trijicon website.
  13. Dec 4, 2021 at 5:40 PM
    Dr. Doom Says
    SE TN
    2019 TRD OR
    Scalarworks absolute cowitness mount.
    https://scalarworks.com/shop/quick-detach-mounts/leap-05/
    edit:Nvm I think I misunderstood you. I don’t know of any low profile irons that will work with basically a flush mount Mro. Having it that low may give you issues with cheek weld; I had a similar issue when swapping out braces on a CZ scorpion.
  14. Dec 4, 2021 at 5:57 PM
    Sig45
    Mark
    Maine
    Yah, I'm not having any luck with my search for lower sights. Probably go with standard height and a full co-witness mount.
  15. Dec 4, 2021 at 6:33 PM
    OnePuttBlunder
    AZ
    I've got a lower 1/3 co witness larue MRO mount I'd be willing to part with, I'm going the opposite direction and want the NV height Scalarworks mount
    Sig45 likes this.
  16. Dec 4, 2021 at 6:35 PM
    OnePuttBlunder
    AZ
    Optic still needs some cure time for the paint to harden, but couldn't resist seeing it all together
    Aero M5 18 inch .308 stainless steel barrel atlas r one handguard m5 lower larue 2stage trigger
  17. Dec 4, 2021 at 8:05 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Look for sights designed for the H&K 416, which has a slightly higher rail and slightly lower sights. I think Troy makes some. That being said... your cheekweld will probably suck with them that low.
  18. Dec 5, 2021 at 3:13 AM
    Sig45
    Mark
    Maine
    The solid or cantilever version?
  19. Dec 5, 2021 at 6:50 AM
    OnePuttBlunder
    AZ
    Cantilever.
  20. Dec 5, 2021 at 7:30 AM
    Sig45
    Mark
    Maine
    Incoming PM
