AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Sep 6, 2012 at 7:00 PM
    #2541
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Are you building a pistol or a registered NFA weapon? Otherwise, a rifle with a buttstock has to have a 16" barrel to be legal.
    And if you are building a pistol or an SBR, yes - Del-Ton makes upper assemblies that will work, like these 3 (well, 2 - don't know why the first one is labeled as a pistol upper)
    http://www.midwayusa.com/find?users...&itemsperpage=20&newcategorydimensionid=14657&
  2. Sep 6, 2012 at 7:19 PM
    #2542
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    this
    :popcorn:
  3. Sep 6, 2012 at 7:59 PM
    #2543
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    DelTon, UTG... are we talking about real AR15s or airsoft?
  4. Sep 6, 2012 at 8:14 PM
    #2544
    Sleeper362
    Sleeper362 One Convenient Locations ......In Africa
    Corporal
    K-Vegas NC
    06 SR5 4X4 DC Shortbed
    With this guy.
    I have an 8.5 upper and. Building a 4.5" upper too but I am speshul.
  5. Sep 6, 2012 at 8:28 PM
    #2545
    Polymerhead
    Missouri
    :rolleyes: I agree with UTG but DelTon sells a wide range of stuff, from entry level to mid-tier. As long as you know what you're getting you can buy a quality rifle or upper from them.
  6. Sep 6, 2012 at 8:36 PM
    #2546
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    I had no idea about that.
    This is what I am going off of when I said 11.5"
    http://www.bravocompanyusa.com/BCM-BFH-11-5-Carbine-Upper-Receiver-Group-p/bcm-urg-11%20bfh.htm
    Thank you for shedding that little bit of light of info for me. 16" it is!
    I feel pretty derpy right now :eek: What is the set length(s) for carbine? I have tried to research the hell out of this question but get so many different responses and according to bravo company, the 11.5 is carbine but should really be considered a pistol upper? holy shit... I am just trying to build a legal gun for home defense and occasional plinking. :frusty:
  7. Sep 6, 2012 at 8:44 PM
    #2547
    Rich91710
    Rich
    Los Angeles
    08 Base
    Shortest you can go without getting the NFA tax stamp for an SBR (and whatever state hoops you need to jump through) is a minimum of 16"
    That measurement CAN be met on a 14.5" barrel by pinning and welding a 2" flash hider or compensator, so you can go a little shorter, but NFA laws still apply to the short upper and if you have a lower already in your possession, you can not take possession of the 14.5" barrel unless it has already been permanently converted to 16"+
    The flash hider/comp must be mounted AFTER the barrel nut and gas block are installed, so you need to decide what options you want before having it built up because once it's on, it's on forever.
    But seriously... An Ar15 is not the best weapon for home defense.
    You would be better off with an 18-20" barrel 12ga shotgun loaded with #1 or larger buckshot... birdshot will not penetrate denim and leather and still retain enough energy to disable an attacker.
    Back up the shotgun with a handgun, 9mm or larger, but not so large that you can't afford to practice and can't handle it well.
  8. Sep 6, 2012 at 8:46 PM
    #2548
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    You know... with the current AR craze going on, I wonder how many unintentional felons there are out there with NFA violations...
  9. Sep 6, 2012 at 8:47 PM
    #2549
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    Why?
  10. Sep 6, 2012 at 8:49 PM
    #2550
    Rich91710
    Rich
    Los Angeles
    08 Base
    Thousands I'm sure.
    Now add to that those that are in violation of state assault weapon laws...
  11. Sep 6, 2012 at 8:49 PM
    #2551
    Polymerhead
    Missouri
    Rich covered it well. Just look for a carbine with a 16" barrel and you'll be Ok. I sometimes wonder with the popularity of online sales, how many illegal short barrel rifles are floating around out there with owners who are clueless that it's a crime.
  12. Sep 6, 2012 at 8:49 PM
    #2552
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    gonna need to build and upper soon... kinda wanna build some scratch....... post some pics of what you got pls :) and a short description of the upper.
    and gotta be in regulation with california laws................ -_-
  13. Sep 6, 2012 at 8:56 PM
    #2553
    mntbiker2008
    Aaron
    Cincinnati, OH
    Thank you for the info. I already have the lower. The upper is all I need to complete the project. Basically... to confirm what you are saying, LEGALLY, I am safe to buy an assembled 16" upper without wrinkling any of the feds undies?
    Edit: Polymerhead answered before I submitted this
    x2.... Hell, if I hadn't said something I would have potentially gotten myself in to some deep shit. :eek:
  14. Sep 6, 2012 at 8:57 PM
    #2554
    Rich91710
    Rich
    Los Angeles
    08 Base
    Daniel Defense 14.5 with Smith Vortex flash hider.
    Troy TRX rail.
    Bought the upper receiver from a guy on Calguns who was cleaning house.
    Assembled and the FH pinned and welded at Riflegear in Fountain Valley.
    30rd mag bodies are drilled, blocked, and riveted to 10rds (actually screwed up and one only accepts 9).
    With the buttstock collapsed (or removed) it's just a smidge over 30", so with the bullet button it's fully Kalifornistan-Legal.
    Barrel would have been legal with a slightly shorter flash hider, but the OAL would have come in under 30" so it would be a California SBR.
  15. Sep 6, 2012 at 9:01 PM
    #2555
    AsianAnts
    AnT
    very nice lookin'
    where the hell did you get that paint scheme
  16. Sep 6, 2012 at 9:05 PM
    #2556
    Rich91710
    Rich
    Los Angeles
    08 Base
    100% A 16"+ upper is never a problem on the federal level.
    And on the federal level, now that a stripped lower is written up on the 4473 as "OTHER", you're actually in the clear on a shorter barrel as long as you have never installed a buttstock on the lower (and have no other "long gun" lowers).
    This was not the case a few years ago, a lower was input as a "long gun" or "handgun"... and that is what brought rise to the older "pistol" marked lowers... it ensured that the dealer would write up the 4473 as a handgun.
    Now, it is sold as an "other" and remains an "other" until assembled.
    The BATFE considers a "rifle" to be a receiver that has had both a 16" or longer barrel and a buttstock installed.
    On the federal level, your lower is still not yet a "rifle" since the upper has not been installed, however, Ohio law may be more strict.
    California has all kinds of BS requirements, and the most common way of building an AR pistol is to machine your own 80% lower.
    We can't buy an AR pistol lower from a dealer since it's off-roster and can not be made roster-exempt.
    We CAN buy a completely assembled AR pistol by having it assembled under the single shot, dimensionally complaint exemption. Once we get it home, we can remove the single-shot sled and run it as a semi-auto with 10rd mags.
  17. Sep 6, 2012 at 9:07 PM
    #2557
    Rich91710
    Rich
    Los Angeles
    08 Base
    Fishnets from my wife's 1985 wardrobe :D
    That's Brownelle's Aluma-Hyde-II rattlecan.
    I spent over a month on it... a full week to cure between colors and another week between the final color coat and the matte clear.
  18. Sep 6, 2012 at 9:12 PM
    #2558
    AsianAnts
    AnT
    well it looks hella nice.. though for me, there is a bit too much light colour... :)... would love a digi camo, that would be cool.... LOL
  19. Sep 6, 2012 at 9:31 PM
    #2559
    mntbiker2008
    Aaron
    Cincinnati, OH
    Great! thank you very much for the info. I am glad I was stopped before doing something illegal. lol
  20. Sep 6, 2012 at 11:27 PM
    #2560
    Dirty5Thirty
    Dirty5Thirty TW's BAD MF'er Squad
    Dean
    Auburn, CA
    2003 4Runner SR5
    Dog hair
    Rich is correct. Dealers CAN build you an AR pistol, but that requires the lower to be DROS'd as a pistol, which we won't really do. The only way around it is by charging a 12% excuse tax. Otherwise you're limited to either buying a complete AR pistol, are starting from an 80% lower
