AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 21, 2022 at 10:30 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I've had good experiences with Win White box stuff in pistol calibers...
    ReturnOfTaco and cubie like this.
  2. Apr 21, 2022 at 10:45 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I have too. They have always gone bang, but damn if ain't some dirty ass ammo!
    ReturnOfTaco likes this.
  3. Apr 21, 2022 at 11:41 AM
    ReturnOfTaco
    ReturnOfTaco Well-Known Member
    Virginia
    2018 MGM DC TRD OR MT6 Stubby Bed
    Yakima HD Overhaul 68” LED interior swap Clazzio covers KDMax Pro
    I been using Rem UMC mostly. Had bulk buy stuff around for a long time. Not doggin WWB, just not my thing. But I have stuck with NATO cals in most. 9mm and .45. I dont use much ball ammo in the .45’s. Mostly fancy hopped up HP’s (cc).
    No disputing that dirt, haha.
  4. Apr 21, 2022 at 11:58 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    A couple of strips of painters tape and a proper punch and brass hammer work better than trying to use a plastic hammer on those roll pins
    Double up the painters tape and don't hammer like a gorilla...no scuffs or streaks
  5. Apr 21, 2022 at 12:03 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I use channel locks to squeeze in my bolt catch pin. Works amazing! No marks on your receiver from hammering in that tight little spot.
    CowboyTaco likes this.
  6. Apr 21, 2022 at 12:57 PM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    I tried that and scratched the hell out of my receiver. The painter's tape along the receiver that @JimBeam recommended along with using a little electrical tape to hold the pin on the punch did the trick for me. Hold the pin on the end of the punch and wrap electrical tape around both of them with about 1/8" on the pin and the rest on the punch.
    Edit:
    https://www.youtube.com/watch?v=F219B7oQVuk
  7. Apr 21, 2022 at 1:05 PM
    kmwilt
    kmwilt Well-Known Member
    Kevin
    Springfield, IL
    2017 Quicksand TRD
    Bilstein 5100's w/ OME 888 fronts Bilstein 5100's & Deaver AAL rear T-Rex Grille Rough Country 30" LED in the grill Rough Country 2" cube ditch and fogs
    I use a pair of plier wrenches for starting the bolt release and gas block pins, they work great and are non marring.
    cubie likes this.
  8. Apr 21, 2022 at 1:12 PM
    r_ben65
    r_ben65 Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Front Runner load bars, Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue 270 degree XC awning, Four Wheel Campers Project M, CBI Baja Front Bumper, Warn VR EVO 10S winch, Baja Design OnX6+ 20 inch LED Light Bar, WeBoost
    For the time being, the Army is only going to be issuing the new 6.8mm weapons to combat units like Infantry, Scouts and Combat Engineers. The rest of us POGS will still be using the 5.56mm stuff for a while. I don't see the ammo price going lower too much.
    https://www.armytimes.com/news/your...er-to-build-its-next-generation-squad-weapon/
    For tools, get some roll pin punches (3/32 size for sure). They will look like a regular punch but will have a nipple at the tip. A brass or nylon hammer, safety glasses. I've also used Duct Tape to protect the lower when you install the magazine catch roll pin. They also sell a roll pin starter punch. Nice to have but not necessary.
    If you're having difficulty, file a slight angle on the tip of the roll pin to help direct it in the hole easier.
    I also took an old needle nose pliers and drilled a hole at the tip. It holds the pin for you when you start to tap it in.
    Not so much for the lower but a nice tool to have. Soft jaw pliers.
    https://www.amazon.com/Proto-Soft-C...eywords=Soft+Jaw+Pliers&qid=1650574802&sr=8-9
    I'm at work right now but if anyone wants a picture of what I'm talking about, I can see if I can download something when I get off.
    My second round in the military was Small Arms/Towed Artillery Repair - Armament Maintenance Supervisor.
  9. Apr 21, 2022 at 1:23 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Engineers are just slightly more retarded general contractors that uncle same let’s play withs C4 and blasting caps, many of who larp on the internet pretending to be EOD techs. :anonymous:
    Tacodog and ReturnOfTaco like this.
  10. Apr 21, 2022 at 1:39 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I applied painters tape to one side of the bolt catch section and squeezed it in with no marks. I started the pin as best as I could, and squeezed it the rest of the way in. I’ve had great success doing it this way building 6 or 7 lowers already. There is more than one way to skin a cat!
  11. Apr 21, 2022 at 1:41 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    I used some Milwaukee pliers and just taped the jaws up with painters tape.
  12. Apr 22, 2022 at 8:13 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Off with the old, on with the new. Now there’s almost no shadow cast by the can.
    118FA4C0-F457-459B-9741-A7CBE8BE9E1B.jpg EC92E162-E43E-4F41-95A8-13268D716EF4.jpg
  13. Apr 22, 2022 at 8:18 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I need to start thinking on which can to get for the 10.5" sbr.
    montijo505 and 95 taco like this.
  14. Apr 22, 2022 at 8:19 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    LOL get in the back of the line :facepalm:
  15. Apr 22, 2022 at 8:22 PM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    still rocking that old optimus too I see :thumbsup:
    95 taco[QUOTED] likes this.
  16. Apr 23, 2022 at 5:25 AM
    95 taco
    95 taco Battle Born
    Lots of good options out there, I’m partial to the Griffin Armament stuff.
    Yup, it has the Gen 1 baffles for now, I want to shoot the Optimus and my other cans side by side and then I’ll send it in for the baffle upgrade. When it comes back it’ll pretty much be a pistol only can though.
  17. Apr 23, 2022 at 12:39 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  18. Apr 23, 2022 at 7:03 PM
    95 taco
    95 taco Battle Born
    I wanted to run the Resonator K on the 13.9 for the shortest length but the larger diameter contacts the handguard so I guess for now the Recce 5 will be on the 13.9 and the Resonator K will be on the 11.5”. I’m very excited to run some rounds through them tomorrow.
    0824B68E-086C-4AEB-87B6-E4B5483CDEFF.jpg 5F5476C1-C00F-47D7-823B-09FCBF3D2A95.jpg
  19. Apr 24, 2022 at 5:40 PM
    Sleipnir
    I'm a horse
    Asgard
    Yea I'm still rocking the gen one baffles too. Definitely deserves an upgrade but it's at the bottom of the nfa priority list.
    windsor likes this.
  20. Apr 26, 2022 at 9:35 AM
    TomTwo
    Bill
    I-85 Southbound
