AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Jul 18, 2022 at 5:36 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Since you are going through the effort of disassembly and doing a solid color have you considered duracoat or alumahyde?
    TomTwo and cubie[QUOTED] like this.
  2. Jul 18, 2022 at 6:10 PM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I have not. Is that something you can buy as a kit and do it yourself, or do you have to ship yours parts to someone to do it? I thought of using Brownells Alumahyde.
    TomTwo and Casper66[QUOTED] like this.
  3. Jul 18, 2022 at 6:34 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    The original duracoat ( I think that’s the name of it I’ll look it up) is a 2 part system and you sprayed with compressed air and a pad it gun. They came out with self contained aerosol kits though so no special tooling needed you just spray like you would Rustoleum. I’ll try and find it
    cubie[QUOTED] likes this.
  4. Jul 18, 2022 at 6:38 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Here’s an example
    https://www.midwayusa.com/product/1841197060?pid=813706
    I believe they make a large amount of colors this is just an example. The sprayer is a “Preval” sprayer you can usually find at a decent auto parts store that sells paint or get it in a kit like this.
    or this from Duracoat
    https://www.duracoatfirearmfinishes.com/duracoat-standard-colors-metallics-p/dcmetal-aerosols.htm
  5. Jul 18, 2022 at 6:40 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I never did like duracoat…always seemed way too thick for gun paint
    cubie, dfanonymous and Casper66 like this.
  6. Jul 18, 2022 at 6:45 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I’ve never used it. It does look thicker but having never used it I’ve never milled it to test thickness. It strikes me like an epoxy from what I can tell it’s very durable, hence the name I guess. You can always control your spraying with lighter coats as well I guess. Have you dealt with a gun coated in it? As much as you deal with them I’d think maybe so and your first hand knowledge is, well, more than I have with it
  7. Jul 18, 2022 at 6:53 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I think it chips too easy for the price too. I rather just sea sponge over a base of krylon.
    Anything actually worth doing I rather use Gun cote or cerakote. Or just leave it alone.
  8. Jul 18, 2022 at 7:14 PM
    JimBeam
    JB
    2015 Tundra
    I’ve dealt with a few guns sprayed with it…and it’s difficult to strip off if you change your mind
    I’ll stick to krylon or rust oleum…I’m not paying cerakote prices
    Gunshot-6A and Chew like this.
  9. Jul 18, 2022 at 7:19 PM
    dfanonymous
    If you have a shop oven it’s not hard to do it yourself. As a matter of fact, they have an air cure option of cerakote now as well.
    Gunshot-6A and wilcam47 like this.
  10. Jul 18, 2022 at 11:25 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Always good to keep the neighbors confused :rofl:
  11. Jul 19, 2022 at 1:32 AM
    TomTwo
    Bill
    I-85 Southbound
    I think I will remove my handguard and FDE it and reinstall it just to get my nerve up then it will match some other parts
    Casper66 and cubie[QUOTED] like this.
  12. Jul 19, 2022 at 8:26 AM
    kevinRR
    kevinRR Well-Known Member
    Milwaukee, WI
    2022 Toyota 4Runner
    I'm going to be swapping out the quad rail for a lighter mlok so I decided to paint the quad rail earth brown. Turn out pretty good kind of like the RIS II I had years ago. I ended up painting 3 mags today the same color.
    Casper66, montijo505 and cubie like this.
  13. Jul 19, 2022 at 8:30 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Is that a JPE flash hider?
  14. Jul 19, 2022 at 8:39 AM
    kevinRR
    Milwaukee, WI
    2022 Toyota 4Runner
    Surefire 3 prong.
  15. Jul 19, 2022 at 8:48 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    Thanks, looks just like a JPE.
    kevinRR[QUOTED] likes this.
  16. Jul 19, 2022 at 11:51 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Molyresin
    https://www.norrells.com/
    Casper66[QUOTED] likes this.
  17. Jul 19, 2022 at 2:24 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
  18. Jul 22, 2022 at 6:18 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Here's the main squeeze. Also a reminder that mags are cheap and available at this point in time; act accordingly.
    Get lucky
    It's been bullied and used. Working sloots > safe queens.
    Sig45, 4WDTrout, p1smo and 10 others like this.
  19. Jul 22, 2022 at 4:08 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Its been a LONG time that Ive run my 300blk SBR and havent changed a thing about it. Well i finally decided to change that. Now mind you, this thing was built before M-LOK was a thing and keymod was still fairly new.
    This is how it was. Note that it had a Magpul UBR stock on and was in the process of removing before i took the picture (hence it looking funky stock wise).
    The main change was removing the UBR and going to a CTR. The UBR was nice, but its a heavy stock (Gen 1 mind you). But also swapped in a Radian Raptor SL charging handle (from a mil-spec one) and a BCM QD end plate. And lastly just getting rid of the AFG and light. And also the pic rails they mounted to.
    Just for kicks I took some measurements. The UBR set up (with JP silent captured spring) was a good 2lb 2oz. The new CTR (with a new JP silent spring gen2) came in at 1lb 4oz. So almost a pound right there. The light, afg, and rails were another 10oz. So quite a good amount of weight removed. Last thing to do is to probably swap the rail to something else. The texturing on the rail is a bit rough for my liking to be able to hold on to.
    And apparently i need to shoot it more. Who knows how long this dude has been (dead) in there. Was a bit of a surprise when i took the can off!
    kmwilt, wilcam47, szidls and 2 others like this.
  20. Jul 23, 2022 at 9:38 AM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    New muzzle brake. For $20 it was worth trying out. Still looking to eventually replace the Magpul stock with a B5 SOPMOD and add a flashlight
    D495399E-0B64-47BD-BAAB-D3600B5C0FF0.jpg 1C345500-CA92-40C6-ABBB-F10F05F691C0.jpg
    Casper66, kmwilt, Sig45 and 5 others like this.
